Question about Samsung HL-R6167W 61" HDTV
How hard is it to change a color wheel
Is it that technical to change out a color wheel
No, it is one of the three parts that can be changed by the consumer. My husband changed out ours but the TV still doesn't work. Now it has been suggested that we try a new ballast, we have already put in a new lamp as well.
Posted on Aug 08, 2008
  • mmsort Aug 08, 2008
    Didn't realize that this model had two different color wheels, our model take the L6 but what we ordered was the L3. Hopefully when the new color wheel arrives we will have a working TV
My samsung tv is have technical issues ; i've changed the color wheel before and also the lamp a couple times i am thinking its the "digital board" but i need a second opinion from a professional.
Please advise as to what the technical issue is. What is the TV doing? Or not doing? Also please include the model number of the set. Thank you.
Feb 18, 2016 | Samsung Televison & Video
My Smasung projection TV keeps flickering, also every hour or so the screen turns to a green flicker. I have to unplug the power cord and that temporarily fixes the problem. How do I stop the flickering?
The tv colors wheel is dying,replaced the tv colors wheel,will solved this problems.Hire a tv Tech.to change the tv colors wheel,it pretty hard to change the colors wheel in this tv.Because u require take out many machanical parts before u even can come to the tv colors wheel itself to change it.
Nov 08, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Started making a humming or vibrating sound, and the color and resolution went bad at the same time. Now when I attempt to turn it on, I get the same vibration sound and nothing else.
This tv have a colors wheel,it dead.Require changing.Humming or vibrating sound,Flashes pictures black&white.The colors wheel is dead and it not spinning in it axis motor correctly anymore.Hire a tv Tech. to change the colors wheel,it very hard to change the colors wheel.Because u have to take out many machanical parts,even before u can get to the colors wheel itself.
Oct 14, 2010 | Samsung HL-R5656W 56" DLP HDTV
Color
U hear grinding noises,squiling noise,before colors fades in&out,turn to Black&White picture,than died?Yes,than ur DLP tv have a colors wheel,it defective,require replacing.The colors wheel is spinning off of it motor axis.The tv tech,should be hire for changing the tv colors wheel.
Jul 24, 2010 | Sharp 65DR650 65" Rear Projection...
No color
This tv have a colors wheels it dead,it spinning off of it axis.That why u getting black&white picture.Hire a tv tech. to change the colors wheel.Because it hard to change the colors wheel,u never done it before.Have to take out alots machanicals parts before even can get to the colors wheel to change it.
May 14, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
When i turn on my tv i can hear a noise coming from the back. it appears near the fan and power supply area. after maybe 20 minutes the tv shuts off.
You have a bad color wheel that will have to be replaced. If you donot have a technical bend of mind, They are a bit difficult to fix and you may end up dmaging it. be very careful and make sure you have the correct color wheel. A bearing change of switching the color disc will not produce good colors and also fail again soon as this wheel spins at nearly 7000 rpm.
Feb 17, 2010 | Sharp 56DR650 56" Rear Projection HDTV
I have a samsung rear projector tv model HLS4288WX/XAA
this sounds as if the color wheel is going out. the color wheel cost between 120.00 to 200.00 dollars online if you have the technical knolage you could change it yourself or a repair shop will do it I would guess around 300.00 but thats where I live
Jan 25, 2010 | Samsung HLS4266 TV
Picture is black and white and fleckers. changed
In most cases this is due to the fact that the color wheel has shattered into pieces and will need to be replaced. Replacing the color wheel is not too easy, but if you are technically handy it isn't that tough to replace either. The part number for the color wheel is BP96-00250A and will run between 80-130 dollars for the part.
Nov 11, 2009 | Samsung HLN5065W 50" Rear Projection...
Just changed color wheel on the DLand red temp light is blinking
For technical help from samsung just plug this web address in to your address bar. http://www.samsung.com/us/info/contactus.html# Pick the DLP television section and put in your model number and fill out the form for technical assistance. Or you can call this number for telephone assistance 1-800-726-7864. Hope this helps you with your problem.
May 14, 2009 | Samsung DLP HL-P5663W 56" TV
Mitsubishi wd 62725
Color wheel - light engine assembly is bad, must be replaced. New assemblies not available, try ebay. You''ll need technical expertise or you'll need to hire a tv service shop. MOst shops will NOT sel you a used color wheel assembly, but they will install one if you buy it.
Jan 20, 2009 | Televison & Video
Samsung HL-R6167W 61" HDTV Logo
Henry  Thomas
Henry Thomas
