Sony SLV 678HF
I just got this machine and can't set up the recording correctly. I've tried all the hook-ups suggested in the manual. I am using the A/V hookup with cable box with many scrambled channels.
I hit the preset and can record, but the playback is fuzzy and it looks like when the monitor is set to tv instead of video. The machine plays pre-recorded tapes fine and broadcast/cable is fine.
pam
    Habit-Forming:
    New Friend:
  • 13 Answers
This is a VHS VCR and should be like any standard vcr to hookup. Did you obtain this VCR recently; and was it used? What are you calling the 'monitor'? Is it a standard TV. Since you said pre-recorded tapes work OK, I think your cable connections are fine. With that in mind, if this is a used VCR, I think your 'recording/playback' heads need to be cleaned. This is not a big deal to someone who can look inside with some competence if they are careful. But the heads are very delicate and can be damaged quite easily. If you want to give it a try or discuss this in more detail, I can guide you (but no guarantees).
Posted on Jul 11, 2017
4 Suggested Answers
SOURCE: DTV Converter hookup
Is it possible to record TV programming on a VCR when using a DTV converter? h1 = document.getElementById("title").getElementsByTagName("h1")[0];h1.innerHTML = widont(h1.innerHTML); Hi,
I had the same problem and found this answer that worked for me. Hope this does the trick for you.
Simple stated, your VCR must be set to channel 3 also. Check it out.
woody
  1. You must have the VCR tuned to record on channel 3.
  2. You must have the VCR connected to output signal of the DTV converter box. In other words, the converter box must be connected between the antenna and the VCR. So, the likely configuration you would use with a coaxial cable is antenna to DTV converter to VCR to TV.
  3. You must tune the DTV converter to the channel you want to record prior to recording. The VCR won't be able to change channels on the DTV converter.
  4. You will be able to use the timed record function on the VCR but you must adhere to steps 1-3.
If this sounds freakishly familiar to recording on a digital cable or satellite set-top box, you are right. It is exactly like recording a signal from a digital cable box or satellite receiver. While it may be inconvenient to perform the steps above, at least the option still exists to record on a VCR while using a DTV converter box.
Disadvantage of DTV Converter: You will lose the ability to watch one program and record another with the DTV converter. Sorry for the bad news.
The reason is the tuner. The VCR tuner is useless with digital except for recognizing channel 3. The digital converter is a single tuner item so it only receives one station at a time.
Posted on Dec 10, 2008
mrphoneguy
  • 7 Answers
SOURCE: Cannot record VCR thru Cable Box
make sure that the cable runs first through the cable box then through the VCR then to the TV.
if you know how to set timers on your cable box (if you have that option), set those in addition to your VCR timer. If you don't have that feature or are not sure, you will, unfortunately, have to keep the cable box on a certain channel before you record.
hope this helps!!
Posted on Feb 13, 2009
dvdcdlaser
  • 1285 Answers
SOURCE: VCR will not record
yes your hook is all correct...but still will not work......unless this is a d-vhs recorder...(and the other way to record hd is dvr)....(note dont throw the standard vcr away) it might and can be use later down road
Posted on Jul 05, 2009
How do i record a show onto a tape?
lets say you are hooked up correctly (cable to VCR in (from cable/sat box) & cable to TV from VCR out) and the VCR is set to Ch 3,, (PLEASE NOTE THE TV MUST BE ON CH 3)
program a recording
the VCR clock / date must be set and not flashing 12:00
then you go to menu, program a recording by imputing the start time / end time of the show and the date it will be recorded and Ch 3...(you might have to set your cable box for the same date/time as the VCR or manually turn to that ch you wish to record that morning or before you go to bed) put a new tape in the machine....
manual recording
a show,game or special comes on and you sitting and want to watch and record and even edit (no commercials) put tape in... press record button get the remote so you can pause (on commercials) and press pause again to resume recording
HAVE FUN
Dec 26, 2010 | Sony SLV-678HF VHS VCR
Sony SLV-775HF issue (power off, freeze, digital cable related?)
These guys have the owners manual and the service manual for your exact model; http://www.user-manuals.com/advanced_search_result.php?keywords=sony+SLV-775HF+manual&forward=plist&osCsid=a4cf756dbc2b6f254269ca22308687e5 Sorry I haven't been able to locate these for free anywhere, Sony do not have them available online. Here is the link to the Wow cable instructions - i couldn't find much in there but you may see something that helps out, check pages 65-67 to be sure you have everything hooked up right; http://www1.wowway.com/cable/pdf/WOWGuide.pdf Here is the link to the user manual for the explorer 3200; http://www.scientificatlanta.com/products/consumers/new_explorer2200.htm and here for the FAQs; http://www.scientificatlanta.com/products/consumers/FAQs.htm Hope this helps, if you get some more ideas but still no solution, please post back and i can try again :)"
Jan 28, 2007 | Sony SLV-775HF VCR
I cant switch to video input and my remote wont work i need help.
Dear FixYa customer,
You can verify the output of the remote by pointing it at your Camera phone. If you see a bright spot like a flash light then you know the IR beam is transmitting.
You will need the remote control "Input" button in order to get the "L"ine input on the VCR. What source are you trying to record from? There may be an alternative if the other device has RF output.
The original remote is no longer available, however, here is a link to a replacement that has the "Input " button.
Thank you
May 09, 2010 | Sony SLV-678HF VHS VCR
Want to record a television program on a channel higher than 16.
there must be a setup feature on the sony for channels that you get in your area?
Dec 18, 2009 | Sony SLV-D370P DVD Player/VCR
Tape hanging up and will not record.
There is a threading arm that has gummed up inside the unit. I suspect that the tape is not being loaded correctly. This is a common problem with the Sony units and requires the removal of that loading arm to remove gummed up grease. Once that is completed, the unit will function correctly. Please note that the height of this swing arm is critical to the correct loading of the tape. I would not suggest you attempt this repair because the tape height adjustment needs to be exact. A local shop should be able to resolve this for you with NO parts required.
Dan
Mar 11, 2009 | Sony SLV-N750 VHS/S-VHS playback VCR
Remote control gives wrong signals
You should goggle the model number and check if they have supplied you with the correct remote control.
Nov 04, 2017 | Sony SLV-ED40 VHS VCR
I want to transfer material from video cassette to dvd. I have a Sony cassette recorder slv- se610g and a sony dvd recorder rdr-gx3. Can you please tell me how?
Though Connection details are available in DVD recorder User Manual, yet here is procedure. Find Video Audio Out terminal on Cassette Recorder SLV-SE610G and hook Yellow-Red-White cable in matching color pins and other end of cable will hook in Video Audio Input terminals at DVD Recorder RDR-GX3 and please note, same color pins will be hooked. Insert desired VHS cassette in VCR and push Playback. select input source at DVD Recorder and confirm playback picture and sound of vcr at TV. Now system is ready to record VHS movie on DVD.
If you need further info, please post back here.
Aug 19, 2008 | Televison & Video
Won't timer record
- Does it have a tape inserted?
- Is the clock set?
- Is VCR off? (has to be off to be in timer mode for many VCRs)
- Is it recording but just plays back blank or does it not even start?
- If recording blank, make sure you are giving it a signal (Is your monitor hooked to the VCR output?)
- If timer doesn't start double check timer settings - they can be very tricky.
Nov 06, 2007 | Sony SLV-N750 VHS/S-VHS playback VCR
Televison & Video Logo
79 people viewed this question
Top Televison & Video Experts
