HP DV2120US Notebook pc and screen on bootup has pink at top, then Windows in middle and another colour at bottom. Once booted up, the screen is useable, but there is quite a lot of orange in it. Hope you can help. Gloria x
    Novelist:
  • 108 Answers
Only thing you can do in these circumstances, besides moving your screen around position wise to see if it's a loose wire, is send it in for repair.....
unless of course, if you feel confident with opening the machine up, you may want to check to see if the cable connecting the screen to the motherboard is plugged in properly, and not loose/coming off. In my experience, this is most often the case when you have extreme discoloration- the pins can become loosely connected over time. However, opening the laptop up will void any warranty you may have on the machine.
Posted on Jun 23, 2008
Screen is orange and pink where it should be white
Try updating graphic drivers from the HP website.
HP has a lotta tools inside, maybe one lets you run an updater HP Pavilion dv6405us Notebook PC Drivers Download
Feb 28, 2014 | HP Pavilion DV6405US Laptop
My V2000 won't boot. It starts to power up, beeps twice stops at the Compact sign in the middle and "press [esc] to change boot order, press [F10] to setup, press [F12] to boot from lan" at the bottom....
probably keyboard connector is loose so, no imput from keyboard is coming in so it halts bootup. please check the connector [opening of a computer is requied probably]
Oct 30, 2009 | HP Compaq Presario V2000 Notebook
I have to boot twice. Thn the computer runs fine.
This could be because of the static
Press the power key down for less than 2 minutes once you start the computer
then start the system normally.
Regards
Jun 16, 2009 | HP Pavilion dv2120us Notebook
Dv2120us keyboard buttons light but screen black, won't boot
Hello Atty
I understand that your Notebook is not powering on. Your Notebooks , that is dv2120us is having a manufacturing defect. So HP accepted that the Notebook will be serviced under the plan "One Time Service Enhancement" . Even if the Notebook is out of warranty your Notebook may be serviced. For more information log on to the chat support .
.http://welcome.hp.com/country/us/en/contact/chat_1.html
They will assist you with the details and the procedure, how to send your Notebook to HP for service.
Feb 16, 2009 | HP Pavilion dv2120us Notebook
Ram capacity on HP Pavillion dv2120us
nope....that 2 gig is true..and the reason it may be invisible is that it is not seated properly, or, it is mismatched..
Oct 16, 2008 | HP Pavilion dv2120us Notebook
Laptop dv2120us
There is one screw on the bottom of the machine that removes the CD right above the memory cover. It may even have an icon of a CD for it. then it should slide out the side.
Dec 20, 2007 | HP Pavilion dv2120us Notebook
No Display
First make sure everything else is getting power and operating okay, and that it is only the LCD display that is non-functional.
If you get no video signal or power at all, even at boot time, you probably have a dislodged ribbon cabling or power connection. Usually when LCD monitors go bad they show colour banding or all white, etc., but usually continue getting power.
As a last resort, try disassembling the lower case (with the power disconnected and the battery out of course) to expose the LCD monitor mounts, and then following the wiring from the screen into the laptop and check for anything loose or disconnected. You could also have a loose ribbon cable going into the LCD array, which will require disassembling the LCD cowling and mounts.
If you are handy and comfortable with electrics and find nothing loose, put the battery in and test the power line going to the LCD backlight, which should be getting above 7V (I think). Below that and you either have a bad video controller or bad wiring/solder joints somewhere. Otherwise, if the unit has been dropped or had a hard life generally, it could also be the connections between the LCD connector bus on the monitor array and the array itself. As a last resort, try unplugging and reconnecting all ribbon and connector cables, cleaning the exposed brass coloured runners lightly with rubbing acohol or even a pencil eraser.
Good luck...
Oct 16, 2007 | HP Pavilion dv2120us Notebook
Computers & Internet Logo
Brian Sullivan
Brian Sullivan
David Payne
David Payne
