Question about Garmin StreetPilot c340 GPS Receiver
My Garmin c340 turns on then shuts off even when plugged in
I've had it for almost a year and it's been fabulous until five days ago.  It had a full charge, was plugged in, but now, won't turn on.  Any ideas?   Thanks, Acequia
  • zperacha Jun 23, 2008
    I have the same problem as well. Had mine for two years. Can anyone help?
  • Anonymous Jun 25, 2008
    I have the same problem. Unlike you however, my garmin is only 4 months old now.
I have had the same problem. When I connect my unit to my computer through the USB I can get it to turn on. I already tried to do a reset and that didn't work. I am going to try to replace the battery next. If that doesn't work, I guess I will need to buy a new GPS since my unit is 1 1/2 yrs old and out of warranty.
Posted on Jul 02, 2008
Remove the faceplate (should be able to do this with your fingernail). On the right of the unit you will see a reset button. Press and hold for about 10 seconds and then try to power the unit on again.
Posted on Jul 01, 2008
I have same problem, in the middle of a trip my c340 stopped working... maybe Garmin ought to replace or refund our money so we can buy a Tom Tom
Exact same problem! Worked well for 9 months now won't turn on. Any suggestions?
Posted on Jun 29, 2008
  • doc547 Jan 23, 2011
    I have had mine for about 3 years and got great service from it. But now it either doesnt turn on or it turns on and then shuts down within about 20 seconds. I need to know if there is a quick fix otherwise I will buy a new GPS.
I have the same problem. I have had it for only 4 months.
Posted on Jun 25, 2008
Garmin is unresponsive. Won't power up or turn
I have a Garmin c340 that would not turn on.
I found the hidden reset button and it works now.
With the display unit facing you, the aluminum cover plate has the the word GARMIN on it. Use you fingernail under the word Garmin and the cover plate comes off. The left part of the cover stays attached to GPS and the right side lifts up exposing the RESET button. I pressed RESET and POWER together and it works now.
Mar 10, 2010 | Garmin StreetPilot c340 GPS Receiver
My Garmin Street Pilot c340 does not turn on
try calling Garmin and ask their tech department for help or go to their web site and explain problem they should get back to you right away.
Oct 03, 2017 | Garmin StreetPilot c340 GPS Receiver
Cannot turn the power on.
I have bot this Garmn c340 at year ago. I couldnt turn my Garmin c340 GPS , even i have pu on charger more than 4 hours. Please let me know what should i do?
May 24, 2009 | Garmin Nuvi 350 Car GPS Receiver
2 Garmins, BOTH shut off right after they are turned on
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
>>>>>Posted by judyferris82 on Mar 15, 2009 "My Garmin nuvi 650 stopped keeping a charge for more than 60 seconds. It is still connected to the car charger. Will a battery replacement fix this problem? I have had this unit for 2 years."
<<<<<REPLY: In your case, the battery seems to be getting weak. You must change it.
Mar 15, 2009 | Garmin StreetPilot C330 GPS Receiver
We cannot get our garmin c340 to acquire satellites.
turn it on and use it more ,even if going to grandmoms house ,for some reason they lose satelites when not in use.i found useing it or at least turning it on every day has cured the problem.hope this helps
Dec 28, 2008 | Garmin StreetPilot c340 GPS Receiver
Frozen touch screen on
hold down the power button when you turn it on until the calabaration screen comes up and that might fix your problem
Nov 01, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin c340 went black and can't get it working
The battery was completely dead. I must not have had the cord plugged in to my lighter, or maybe it wasn't sitting properly on the cradle, and it was running on battery power. I found that when I charged it by the computer, it was ok. It is working with no problems, now.
Mar 10, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin 340 streetpilot won't even turn on?
I had the same issue with mine during a trip. Probably needs to be reset. See page 31 of the users manual on Resetting your c340. Once I did this it worked fine.
http://www8.garmin.com/manuals/StreetPilotc340_OwnersManual.pdf
Nov 28, 2007 | Garmin StreetPilot c340 GPS Receiver
Garmin c340 gps freezes up
Avoid buying Garmin GPS. Their units have a non user replaceable battery that last about 2 years. After that, you have to send the unit to Garmin to replace the battery and be hit with at least $150 plus shipping. Possibly more if they need to fine tune something else. Look at other brands with easier battery replacement such as Sony, Navigon, etc. Garmin is a total rip off.
Sep 08, 2007 | Garmin StreetPilot c340 GPS Receiver
Garmin StreetPilot c340 GPS Receiver Logo
279 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
