Question about Ricoh FAX4410NF Plain Paper Laser
Network setup for 4410NF
The "printer features:" screen is not visiable under the "User Tools:", hence can't config IP, subnet mask, gateway, etc. Any idea why? I have the ethernet cable plugged into the 10BaseT interface on the fax machine.
Thanks,
Vincent
  • wangvh Oct 31, 2008
    I was able to configure the IP information on the Fax. Your help is much appreciated. Now, I need to get the rest of the features working.
    Take care!
Ok, heres how to get to network preferences on this printer
USERTOOLS
2.fax features
4. key op tools (password might be 2222)
15. network
I hope this is enough information to help you out a little bit
Posted on Oct 29, 2008
Ethernet cable network doesn't work on my MP4000
You can use wifi OR ethernet, configure in user tools. -Carl
Mar 26, 2014 | Ricoh Office Equipment & Supplies
What is the default ip address for powerconnect 5212
You must assign an IP address to the switch to gain management access over the network. You may also need to a establish a default gateway between the switch and management stations that exist on another network segment. You can statically configure a specific IP address or direct the switch to obtain an address from a Boot Protocol (BOOTP) or Dynamic Host Configuration Protocol (DHCP) server when it is powered on. Valid IP addresses consist of four decimal numbers, 0 to 255, separated by periods. Anything outside this format is not accepted by the CLI program. notice.gif NOTICE: By default, the IP address is assigned to VLAN 1 through DHCP. If you select the bootp or dhcp option, IP is enabled but does not function until a BOOTP or DHCP reply has been received. Requests are broadcast periodically by the switch in an effort to learn its IP address. (BOOTP and DHCP values can include the IP address, default gateway, and subnet mask).
To display assigned IP settings using the CLI:
  1. From the Privileged Exec or Normal Exec level mode, type show ip interface and press <Enter>.
The assigned IP address and subnet mask displays.
  1. From the Privileged Exec mode, type show ip redirects to display the assigned gateway IP address. Press <Enter>.
The following example displays IP settings assigned by bootp or dhcp using the CLI.
Console#show ip interface
IP address and netmask: 10.1.0.1 255.255.252.0 on VLAN 1,
and address mode: User specified.
Console# show ip redirects
ip default gateway 10.1.0.254
Console#
Before you can assign a static IP address to the switch, you must obtain the following information from your network administrator:
  • IP address for the switch
  • Default gateway for the network
  • Network mask for the network
To assign a static IP address to the switch:
  1. From the Privileged Exec level global configuration mode prompt, type interface vlan 1 to access the interface-configuration mode. Press <Enter>.
  2. Type ip address ip-address netmask, where ip-address is the switch IP address and netmask is the network mask for the network.
  3. Type exit to return to the global configuration mode prompt. Press <Enter>.
  4. To set the IP address of the default gateway for the network to which the switch belongs, type ip default-gateway gateway, where gateway is the IP address of the default gateway. Press <Enter>.
  5. To save your configuration changes, type copy running-config startup-config and then press <Enter>.
notice.gif NOTICE: Only one VLAN can be assigned an IP address. If you assign an address to any other VLAN, the new address overrides the original IP address. The following example shows how to set a static IP address using the CLI.
Console(config)# interface vlan 1
Console(config-if)# ip address 192.168.1.5 255.255.255.0
Console(config-if)# exit
Console(config)# ip default-gateway 192.168.1.254
Console(config)#
To configure the switch for DHCP or BOOTP:
  2. At the next prompt, use one of the following commands:
    • To obtain IP settings through DHCP, type ip address dhcp
    • To obtain IP setting through BOOTP, type ip address bootp
  3. Press <Enter>.
  4. To save your configuration changes, type copy running-config startup-config, and then press <Enter>.
Nov 26, 2012 | Computers & Internet
Having trouble adding printer canon ir3300 thru ethnet connection. directly to laptop. This printer isn't on the current network. So, I'm not sure if I need to add it first. Can you please advise.
You will need to buy a "Crossover Ethernet Cable". A ordinary straight through ethernet cable will not work. When you connect the crossover cable the laptop will see it and assign an IP address as though it was on a network. You then need to create a standard IP Port. take a config printout and look for the ip address. Add a single digit one to the address and make that you std IP Port.
Install your network driver and it will look for the printer on your new network (your laptop and printer). providing it does then all should work ok.
Good luck.
Aug 22, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
I just configured my MFC 490cw for wireless printing. It works but now I have IP address conflicts across all computers XP & Windows 7) and X-box in the house. If I turn the printer off, the network...
When configuring an address for the printer, the IP configuration might look like (just an example):
IP Address - 192.168.1.2
Subnet Mask - 255.255.255.0
Default Gateway - 192.168.1.1
It's important to note that even though you are not using any IP addresses in the default range for DHCP, the Subnet Mask and Default Gateway addresses will be THE SAME.
If you have another device on your network that will be assign a fixed address, you would use for example:
IP Address - 192.168.1.3
For any other devices, just increment the IP address by one, 192.168.1.4, 192.168.1.5, etc and use the same Subnet Mask and Default Gateway.
(see the owners manual or site for steps on configuraing the printer TCP/IP information). This should take care of any conflicts.
Jan 29, 2011 | Brother MFC 490cw Color Inkjet...
How do i set the Gateway, the IP and the Subnet Mask on my Officejet-7310? On Configuration Page, all wireless info (#15-22) is set to "not applicable" Under General Info #1 Network Status is...
on you printe.. press the setup button which islocated above you navigation keys on your printer, after the setup screen come up
step 1 - scroll down to option 8. Network and press ok
step 2 - scroll down to option 3. Advanced steup press ok
step 3 - scroll down to option 2. Ip settings press ok (there will be a warning message but just press OK again
step 4 - scroll down to option 2. Manual press ok
step 5 - Now u just choose which option you want to change, btw there are 3 options (1. Ip address, 2. Subnet mask, 3. Default gateway).
Hope this helps.
Dec 23, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Hi. i cant connect to print server d-link dp301p+ IP to configure it?! who knows what IP by default it have? 192.168.0.10 doesnt work... Thanks, Mike
First find out the IP address , Subnet mask,and Gateway addresses of your ISP ( Internet Service Provider ). According to above addresses, you have to complete the network settings of your printer by mentioning the different IP address .
To find out the above mentioned addresses, first open the control panel -> network connections -> local area connction -> properties -> Internet Protocol Version 4(TCP/IPV4) OR Internet Protocol Version 6 (TCP/IPV6)according to your ISP -> Properties
By the systematic selection as mentioned above you will get the IP address, subnet mask and Gateway addresses.
Suppose your IP address is 192.168.0.10 , the gateway may be 192.168.0.1 Or any number. And the subnet mask may be XYY.XYY.XYY.0.
According to your ISP addresses you have to complete the network settings of your printer. First press the additional functions -> system settings -> network settings -> TCP/IP settings -> fill up the addresses as follows.
IP address : 192.168.0.16 OR any number .
subnet mask : XYY.XYY.XYY.0.
Gateway : 192.168.0.1
Hurray ! the problem about your network connection with the printer to your computer will be automatically solved.
Sep 28, 2010 | Computers & Internet
J4167A jetdirect card not ready LAN ERROR-OPEN
if it is recognizing the jet direct card then the card should be good, not sure if yor network is setup for using dhcp but I usually deal with manual settings on these cards. I'm sure you know what your doing but it doesnt hurt to bounce it off others anyway.
I'll assume you know how to access the eio settings for the jetdirect from the menu screen.
choose manual setup instead of dhcp and keep all the othr settings at default except these other 3
1. You'll need to assign a manual I.P. address
2. you'll need a subnet mask I.P
3. You'll need a default gateway...
If you have other printers online then the subnet mask and default gateway should match the other printers but the actuall printer I.P address will of course be different... Hopefully this will help you out, and if so please write this a FixYa!!
Jul 19, 2010 | HP LaserJet 4100n Printer
How do I convert my C6180 all in one printer from offline to online status using a HP Pavillion dv9000?
Take out the Network Confirguration page from the printer.
To get the page.
Press the setup button.
Go to Network Setup>>>View Network Settings>>Network Configuration page. Press OK to get it printed.
Note down the IP address of the printer.
Then Go to The Printers folder under Control Panel.
Make right click on the printer icon and select Properties or printer properties in case of windows 7.
Go to Ports tab.
Click on Add a Port. Select Create a new port and select Standard TCP/IP
Enter the IP address that you have noted down from the Cofiguration Page.
And complete the Add a port wizard.
Then restart the printer.
. If you are using a DSL router, then enter Manual IP to the Printer.
Make sure it is different from the IP of other devices on network.
You must have default gateway, subnet mask information about the network.
To get the details.
Open Command Prompt on your computer from All Programs>>Accessories.
Enter ipconfig and press enter.
Then note down the IP address, default gateway and subnet mask.
To enter the manual IP to the printer, Press setup button. Go to Network Setup. Select Advance Settings>>>>IP Settings>>>manual IP.
Enter Ip address of priner as 192.168.001.023.
The default gateway must be 192.168.1.1, make sure that first 3 set of numbers are same. like 192.168.1, last 3 should be different from the computer's one.
Enter the same default gateway and same subnet mask
And after adding the manual IP, use ADD a Port option. Restart the printer and then check the status.
To make sure, make a right click on the printer icon and select Use Printer Online.
Apr 29, 2010 | HP Photosmart C6180 All-In-One InkJet...
How to wirelessly print to HP 2410v Photosmart printer
This is the official how-to for network setup from HP:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00781863&lc=en&dlc=&cc=us&product=303759&lang=
Introduction Print the network configuration page and obtain the IP address, subnet mask, and default gateway address for the printer. Printing the network configuration page
  1. Press the Setup button.
  2. Press the arrow buttons to select Network and then press OK .
  3. Press the arrow buttons to select Print Network Configuration Page and then press OK . The Network Configuration Page prints.
Obtaining the IP address, subnet mask, and default gateway address The IP address, subnet mask, and default gateway address are printed on the Network Configuration Page
The manual link is here:
http://h10032.www1.hp.com/ctg/Manual/bpu70241.pdf
Hope this helps:
WizardRepair
Jul 18, 2009 | HP Office Equipment & Supplies
Where do I change the IP/Gateway/Subnet on HP LaserJet 4000
You can set these on the printer using the EIO menu.
Press menu until EIO menu appears.
press item
Config network NO should show. press value YES should show.
press select.
Press item until config tcp/ip NO shows, press value Yes press select.
This should get you into the tcp/ip menu.
use item, value and select keys to navigate to the setting you want to change.
hope this helps
Mar 24, 2009 | HP LaserJet 4000 Printer
Ricoh FAX4410NF Plain Paper Laser Logo
230 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
