Question about Dishwashers
How do I clean the inside of my dishwasher, it smells!!!!!!!!
    Novelist:
  • 121 Answers
Try and run a full cycle with the dishwasher empty. Run it with the correct deterent and jet dry. This should take care of the smell issue. Also make sure the makesure screen is clear of food. If you found this solution helpful please rate it.
Thanks - Tech101
Posted on Jun 24, 2008
There is a stale smell inside the dishwasher. How do I clean the inside of the dishwasher to get rid of that smell?
Try dishwasher cleaner (Finish is one brand). Available at Sears, Home Depot and most hardware stores. Follow directions on package.
Apr 03, 2015 | Dishwashers
LG dishwasher LDS 5811 WW smells really bad has a slime film everywhere it was coated all over the upper arm and lower spray arm- dishes are not getting clean- and it smells so bad- any ideas?
it sounds like the problem is your water. go to www.dishwasherfilter.com and check out the dishwasher filtration system. it will solve your problem and works amazing. it is guaranteed or your money back.
May 14, 2013 | Dishwashers
My dishwasher smells inside
Have you tried running the hot cycle with just a dishwasher cleaning product inside?
Aug 05, 2012 | Kenwood KDW243A Builtin Dishwasher
The Vent on the front of my Kenmore Elite Dishwasher is giving off a very strong smelling odour when the dishwasher is going through the entire cycle. The inside of it is fine, no smell. It smells up my...
There is a product sold at home depot that is called AFFRESH made for cleaning smells of stagnant water and other smells as well. They make two different kinds of this product one is for a dishwasher and comes in a yellow bag the other is for front load washers but can also be used on top load washers as well in a green bag. Basicly you use a tablet and run the dishwasher on its hottest setting. Unfortunatley I am unable to smell the smell that your smelling if it were a burnt wire smell then I would ask that you turn off the electrical breaker to the dishwasher whereas I have seen on LG units a couple years ago a type of black goey insulation that LG used to use as a form of insulation on the wires in between the the two panels for the door. Unfortunatley this type of insulation ended up corroding the wires and eventually makeing them short against the door of the unit. Also at least once per year you should also clean out the chopper area in your dishwasher this is the part of the dishwasher that shreds up any large debris or food particles in a dishwasher. It would really depend on if it smells like a stagnant water smell, a old food type smell, or an electrical type of smell. I very much reccommend using the AFFRESH though as even the toughest smells of mold or stagnant water can be alleviated with this product. Using two tablets usually remedies the smell. If you have any further questions message me back and please remember after our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future Thanks
Rick
p.s if you need a schematic showing the location of your chopper message me back the model number to your machine and I will locate your schematic
Aug 11, 2011 | Kenmore Dishwashers
Terrible smell inside the dishwasher. Bad drain smell
Hi
The smell usually comes when the unit is unable to drain water completely, you can run your dishwasher at its hottest temperature setting with 2 cups of vinegar inside the unit. After this take off the lower front panel and clean the drain pump assembly completely, also clean the drain hose, the smell should disappear after doing all this. Hope this helps...please post back for further assistance.
Daniel
Aug 05, 2011 | Dishwashers
Odd odor coming out of dishwasher upon opening it. Smells like rotten milk. What is the best cleaning solution?
After a dishwasher is installed the hose rarely comes to mind - unless a problem occurs and a repair person comes out to inspect the job. If the hose was installed improperly, or if it is lying in a position that does not let it drain, stagnant water will create a bad smell. Examine the hose that is probably inside the kitchen cabinet beneath the sink. If the hose is lying in the bottom of the cabinet, it is probably full of water. A film begins to form inside the hose and the odor begins to grow. The next time the dishwasher is used, the stagnant water ends up on dishes, and in the meantime it can cause a bad smell inside of the dishwasher. Hang the hose at an angle on supports in the back of the cabinet. This alone might get rid of the bad smell inside the dishwasher.
Check the Seal
A dirty dishwasher seal can be a source of a bad smell. Before deciding the dishwasher needs to be replaced, check the seal - especially at the bottom. Old food and grime builds up in these areas and can cause a particularly bad smell. Clean it with a solution of diluted bleach and hot soapy water. One teaspoon of bleach for each quart of water is sufficient to kill germs and the odors they create.
NB I decided to add a little bit of vinegar to the machine after I unloaded it. Sure it would smell pretty strong for a while but then the smell would dissipate. Voila! For two weeks now my dishes have not smelled whatsoever.
Jun 23, 2011 | Maytag MDB6709AW Builtin Dishwasher
KitchenAid KUDP01FLSS A bad smell inside the dishwasher
Here is a tip that will help you with how to clean that dishwasher up and get it smelling good again...
Dishwasher Maintenance
heatman101
Nov 23, 2010 | KitchenAid 34 in. KUDP01FLSS Stainless...
There is a foul smell when we run the washer. There is also a lot of black residue inside the washer.
heatman101
Oct 14, 2010 | KitchenAid 24 in. KUDS02FRSS Stainless...
Bad smell in my dishwasher
try running a load through witha shallow bowl filled with vinegar on the lower shelf, this should clean out anthing built up in it. does it drain into a garbage disposer hook-up? clean that out with vinager as well if you do
Feb 19, 2008 | KitchenAid 24 in. KUDS01FLSS Built-In...
Dishwashers Logo
301 people viewed this question
Top Dishwashers Experts
