Question about Minolta magicolor 2300W Laser Printer
Paper jam, cleaner kit
"error paper jam" but there is no paper jamed it will not print ,also i was looking for a cleaner kit thought that might help .is ther one for the 2300w or how do i clean it on my own??
If the paper is not situated perfectly in the tray, and it cannot grab the top sheet easily, mine will give the paper jam message. I just adjust the paper in the tray, then open one of the doors, front or back, and close it again, and it usually fixes the "Jam".
Posted on Dec 02, 2008
I need need a picture on how to remove a paper jam in xerox 4118 machine right now please
Well open the printer where you can(the closest point to the jammed paper) attempt to remove the jam by attempting to pull the Jamed paper in the direction it would normally exit the machine.thats about as far as I can get you with the information I have--Good Luck.
Feb 01, 2013 | Xerox WorkCentre 4118 Network Kit - 1 x...
Installed new maintenance kit for 9050 printer. Trying to reset page count and now the printer is jamming error code 13.02.00.
No relate with paper jam & page count resetting. Might be maintenance not installed properly..Remove paper jams, restart printer,if error 13.20 appears check some paper/paper particles jammed.. 1. Print from manual tray.
A. If paper is jamming, check registration assembly, clean it,best method for cleaning is vacuum cleaner in this area. chk..
B. Take out registration assembly, check clutch gears, driving gears, solenoids..
2. Check pick up rollers are properly installed in tray 2 & 3..
3. Check PIU unit for paper jams
4. Check Fuser sensor flags.
To reset the counter: Hold enter button & switch on the machine, wait till display shows cold restart, scroll to reset maintenance kit with help of arrow buttons & enter. Printer restarts & counter will become Zero..
Jan 07, 2013 | HP LaserJet 9050 Printer
Paper jamed in front roller where paper is taken from
It sounds like your paper pickup roller is worn down and can't grip the paper to pick it up. This roller is located on the bottom of the printer. Pull the paper tray all the way out and turn the printer over and you can see it as seen in the attached picture.
This roller comes in a kit along with the separation pad and the charge roller. When you replace one its best to replace them all. The roller kit is available here:
http://www.ccl-la.com/catalog/product_info.php?cPath=24_41_42&products_id=71
I hope this helps, if so please rate my solution.
BuddyMc
Oct 17, 2009 | HP LaserJet 1320n Printer
Carriage jamed....
good ! that u have mentioned the name of ur printer
paper jam error message appers whenever the pick rollers that helps in pulling the papers are dirty but you will not be able to clean those rollers as you may tru to do a power drain :
1:disconnect the power cable from the back of the printer
2:hit the power button for 10 times when the power cable is disconnected
3:reconnect the power cable and try to see the error again
4: try to clean the rollers on the printer that is there at the back of the printer and front of the printer with a cotton cloth or a lint free cloth with some water
this is for paper jam
carriage jam:
1: try to move the carriage manually for 10 to 15 times and if that is moving then its ok otherwise your printer funtionality has gone bad as because if the carriage will not move then you will not able to print
so service your product
Aug 03, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Paper Jammed Error
sensor might be dirty ,actuator might not be flagging or wrong paper size in properties
Apr 24, 2009 | Brother DCP-8040 Copier
Printer paused-unable to read
HI there,
1. First, clean your printer. Get some spray-n-wipe cleaner and a clean cloth and clean the entire inside of the printer. Also ensure your paper isn't dirty. Now print a test page. Does the symptom persist?
2. Remove all jammed paper. Check the paper tray first. Look closely at the paper rollers nearest where the paper exits the printer; this is a common source of jams. If you’re trying to print labels, they will often jam just before exiting the printer.
3. Try to print a test page. Does the printer still jam? If you can find no source of the jamming, check the printer's message display window and refer to your user’s manual to look up the printer error code.
Oct 04, 2008 | Brother HL-2070N Laser Printer
Cannot print anything. Paper goes in halfway and then says 'paper jam'. Checked back - no jammed paper. Keeps on doing this. Have been in to cancel print but keeps saying paper jam. Have tried a print test...
Dear Customer,
you ahve to use batter quility papers for prints,
cause when paper fixed up your printer says its jammed but as realesed its says printing but when ALL THINGS DOIN VERY FAST JAMMING & PRINTING ITS SEEMS LIKE PAPER JAMED ALSO SAW YOU AS PAPER JAMED,
so try to check your inner cartrige,ink & paper rolls,batter quility papers you ahve to use,
THNX
May 18, 2008 | HP Computers & Internet
Paper jam
hi this is some small pieces of paper which had gone inside in ur printer when u prints. this one have to contact printer engineer to clean the printer
Mar 02, 2008 | Lexmark X8350 Print, Scan, Copy and Fax...
Paper Jammed
Remove all the cartridges and look around. There may be a small piece of paper torn off inside the machine on a sensor.
It is possible a sensor has come loose or a spring has come off of one of the actuators.
Check carefully.
Feb 11, 2008 | Sharp (SHRAM900) All-In-One Laser Printer
Media Jam- Fuser
thx m8. Media jam: Fuser i had...
new there was no paper jam so looked about for the sensor and found that the little arm thing that gets liffted up as the paper pass was not falling back down so it thought the paper had jamed. i just took the back panal off and put a small bit of soft foam under it so it always got pushed back up.
works a treat now.
thx again
Oct 02, 2007 | Konica Minolta magicolor 2430 DL Laser...
Minolta magicolor 2300W Laser Printer Logo
352 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
