Question about Panasonic Palmcorder PV-GS9 Mini DV Digital Camcorder
PV GS9 Blue lines appear in the viewfinder during playback and when the camera is turned on a prompt to push the reset button appears. When that is done often the same prompt reappears but sometimes the camera will work intermittently.
    Master:
  • 638 Answers
Its definately a battery problem .i hve gone through thesame problem few months back .replacing the battery solved the problem hope it helps u too.wish u success.
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
Posted on Jun 23, 2008
    Master:
  • 848 Answers
Replace a new battery ......because the battery has to supply power to display , flash ,motor etc..........
  • gopinath pasupathy Jun 23, 2008
    if battery replacement doesnot work try this
    One possible cause is that the playback is interrupted by dirt
    or dust that momentarily adheres to the heads
Panasonic video camcorder PV-GS9 purchased 10/2004. I am unable to view playback tapes. Unit is rewinding but no video shows. "Push reset button" continues to show although it will go off after...
This is usually caused by an oxidized, misaligned or defective Audio/Video drum. You can try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be serviced by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Sep 09, 2011 | Panasonic Video Cameras
During playback there are 5 horizontal blue lines that display. Can I fix this myself?
try with head cleaning cassette 2 or 3 times if problem presists change video head assembly
VEG1731
May 20, 2010 | Panasonic PV-GS150 Mini DV Digital...
Panasonic PV-GS39 -- Eats Tape, Reset Button, Playback Problems
ya sounds like a bad tape loader. your estimate sounds about right. tape sensors also go bad so I would have them check it also.
Jun 01, 2009 | Panasonic PV-GS19 Mini DV Digital...
Blue lines appear across screen during video playback.
thank you for choosing Fixya.com.
it seems that some parts in your Cam are Dirty.
please try to use the head cleaner disk first.
let me know if any changes happen.
goodluck
please don't forget to rate our answers properly.
Mar 03, 2009 | Panasonic Palmcorder PV-GS12 Mini DV...
Thick dark vertical lines appear on the video taken during playback.
It is problem of dirty / clogged video heads, use good quality video head cleaner in your camera and clean video head. Problem will be resolved.
Nov 10, 2008 | JVC GR-D250 Mini DV Digital Camcorder
Choppy recording and playback
If the heads become dirty, “NEED HEAD
CLEANING” appears during recording. During
playback, moreover, the following symptoms
appear.
≥Mosaic-like noise appears partially or the
sound is interrupted.
≥Black or blue mosaic-like horizontal stripes
appear.
When normal playback cannot be performed
even after the head cleaning
One possible cause is that normal recording
could not be performed because the heads were
dirty at the time of recording. Clean the heads,
and perform recording and playback again. If
normal playback can be performed, the heads are
clean. Before an important recording, be sure to
conduct a test recording to make sure that normal
recording can be performed.
≥If the heads become dirty soon after cleaning,
the problem may be the tape. If so, try another
cassette.
≥During playback, the picture or sound may be
interrupted momentarily, but this is not a
malfunction of the Camcorder. (One possible
or dust that momentarily adheres to the heads.)
Mar 27, 2008 | Panasonic PV-GS150 Mini DV Digital...
Zoom is stuck and reset button not working.
one of the two motor of the lens of your camera is stuck up that why push reset is alway appearing and the power is blinking....only a technician can fix your problem....
Jul 09, 2007 | Panasonic Palmcorder PV-GS9 Mini DV...
PV-GS9 mini dv playback problem
I covered several threads that recommended buying a Mini DV cleaner and running it up to 4 times. They also suggested to change to change your video tape as it may have been the cause of the original problem.
These solutions may have worked for many but not me. My camera was becoming progressively worse. It went to blue bars and no sound to no picture at all...just blue. After using a cleaner 4 times I became frustrated to the point I was going to buy a new camera.
However, with the camera still playing, I did the typical guy thing and rolled up my fist and gave it a good hit along side of it. Remarkably it went back to just the blue bars. I hit it again and it went back to a perfect picture. I'm not saying this will work for you and hitting it too hard could make things worse but I was at a point where I didn't care any more and took a chance that paid off.
Dec 30, 2006 | Panasonic Palmcorder PV-GS9 Mini DV...
Panasonic Palmcorder PV-GS9 Mini DV Digital Camcorder Logo
116 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
