Issue: i tried to log in to facebook from my phone and when i enter my info and
click ok it only takes me back to home screen and says i need to log
in. i tried loggin in on someone else\'s account and it worked. what
could it be?
Causes and solution:
1) There are chances that the Facebook Account login account and Passwords has been mistyped.
2) There are also chances of the Facebook password hacked.
Note: I recommend you try logging into the FB account in the Computer and check if it is working.
If not the passwordis hacked and you need to answer the security question then get back the access. DON'T FORGET TO CHANGE THE PASSWORD AS SOON AS YOU LOGIN.
You can also check this link: http://www.facebook.com/mobile/ Use that application in the mobile and try logging using that.. remember to uninstall the previous application you're using before you're installing this.
The above following steps should resolve the issue.
Revert me if you have any problems or need more attention on this issue :)
If you can't log into Facebook and need to reset your password:
