Question about KitchenAid KTT570 4-Slice Toaster
The locking mechanism in our 2 slice Kitchenaid toaster does not work. Is there a way to fix this?
    Genius:
  • 1,036 Answers
Very often it's simply crumbs in the wrong place.
Unplug it and take it outside. Remove any little drawers you have completely, and brush them out with a stiff brush.
Turn toaster upsidedown, and bang the sides with your flat palm to empty crumbs. Because of the design, this doesn't get everything out, and you may need to do it upright, and upsidedown again.
While upsidedown, press the levers fully down, and agitate them on the bottom stop.
This should remove the crumbs from the electromagnet armature.
This operates when a flat plate rests on the elecromagnet. If there are crumbs in the way - it wont hold.
If there is still a problem after this, please contact again, or rate so that other may follow the advice given. Thank you.
Posted on Jun 25, 2008
Kitchen aid 2-slice toaster stopped working. It is plugged in to a good outlet.
The wiring is probably the problem. Check the connections. And then the elements . It may be burned in two.
Jan 27, 2013 | KitchenAid KPTT780ER 2-Slice Toaster
Received 2 slice toaster (kitchenaid) as a gift - from the very 1st time it was used, only the outer coils would heat up, so only 1/2 of each slice ever gets toasted!!! Anyone who could help solve this...
I think it is set to cook bagels. Check the control settings.
Most toasters have a bagel setting which only cooks the
sliced side of the bagel. This model is designed to accept bagels. Hope this helps.
Jul 22, 2011 | KitchenAid KMTT200OB 2-Slice Toaster
The lever button does not stay down,so the toaster does not come on. Even if I hold the lever button down,the toaster does not come on.The toaster is cleaned on a regulas basis.
My toaster did the same thing. I cleaned the contacts on the mechanical switch with emery cloth and that problem was solved. Now I'm trying to figure out how to stop the breaker points on the mechanical switch from arcing - which I assume caused the problem in the first place.
Jun 26, 2011 | KitchenAid KTT340 2-Slice Toaster
My toaster flashed a "2" and the lever won't stay
My toaster is blinking on 2 and not working? My booklet to it doesn't say anything about this problem.
Mar 21, 2011 | KitchenAid KTT261 Ultra Power Plus 2-Slice...
Sunbeam 3831 Toaster (2-slice) -- toast/carriage won't stay down
great ! its a great fealing when you save a appliance from the junkyard .
Mar 30, 2009 | Sunbeam 3831 2-Slice Toaster
T-Fal Avante Bagel Tpaster - 4 slice
Energized coil (Magnet) which holds down lever mechanism may be coated and in need of scraping for it to make full contact
May 01, 2008 | Tefal Avante Deluxe 4 Slice Toaster
KitchenAid KTT570 4-Slice Toaster Logo
290 people viewed this question
Top KitchenAid Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Appliances - Other Expert? Answer questions, earn points and help others
