Question about 2wire 2700HG-B Router (2700HGB)
Lock 2wire gateway from embarq i would like to know how i could lock down my system when i'm not home so that my kids can't get on to the internet and chat sites
Take the power supply with you :)
Posted on Jul 27, 2008
3600hgv lost password
-How to Change the Settings on a 2Wire Router
Instructions
    • 1
      Open your "Start" menu and go to the "All Programs" section. Open the Command Prompt program in your "Accessories" menu.
    • 2
      Type "ipconfig" in the Command Prompt and press the "Enter" key. Make note of the default gateway address that is displayed here.
    • 3
      Open Internet Explorer and type the default gateway in the address bar to load the 2Wire router's interface.
    • 4
      Click on the "System Password" link if you do not know your password for the 2Wire router. You will be asked to reset it with the system key printed on the router. Or call 2Wire support to get a temporary password.
    • 5
      Navigate to the "Broadband Link" icon to edit the authentication settings used to connect to the Internet. Use the "Home Network" icon to get to the wireless settings. Click on the "Firewall" icon for settings such as port forwarding.
Dec 14, 2011 | 2wire Computers & Internet
Do you have internet explore ip address. it starts 192"?
what do you mean by internet explore ip?? just your computers IP?? or your routers IP??
normally the IP would be 192.168.0.XX submask is 255.255.2550
but if you just need to know your ip for now just go to START>RUN and type CMD that will open command prompt ( quick way is windows sign on keyboard + R ) to open RUN
once in CMD you type ipconfig then you'll see your IP adress, subnet mask and default gateway. hope this helps
Mar 05, 2010 | 2wire Wireless-G 802.11g ADSL Gateway
Connecting 2wire modem./router to extra linksys router
to get this right you must make sure that the 2wire will be configured to be your gateway which means that the 2wire itself will be connected to the internet then set the linksys to DHCP mode because if you dont it will give you a router behind router error , make sure that the 2wire is properly authenticated and connected to the internet to make sure access the gui by typing gateway.2wire.net on your browser and run system set up wizard
Dec 11, 2008 | 2wire Wireless-G 802.11g ADSL Gateway
Switch from WEP to WPA wireless protocol
First have a computer directly plugged into the 2wire
Using windows xp: click on start> then run> then type "cmd" and hit enter.
Type "ipconfig" and hit enter.
You are looking for a default gateway address, usually "192.168.1.254" on 2wire gateways.
Skip the vista section if you are using xp
Using Windows Vista: click start> then click on the search bar and type "cmd" and hit enter.
Once you find the gateway address, you now have the website address you need to get to your 2wire. Open internet explorer and type that default gateway address in the address bar.
This should take you to a 2wire homepage. At the top click on the "home network" or "local network" tab at the top.
Once there, click on the wireless network link at the top. It will prompt for a password, if you do not know the password, click I forgot for a hint. Click I still cannot remember if the hint doesn't help, it will ask for a system key, which is a 10-digit number on the bottom of the 2wire.
After entering the password you will be in the wireless settings window where you can change the security type to any available that the 2wire has, if it doesn't have it available call the provider and see if they have a firmware upgrade available.
Nov 13, 2008 | Gateway Wireless-B Router (wbr-100)
2Wire Wireless Modem 2700HG-G
access gateway.2wire.net
home network icon
wireless setting tab
channel dropdown box=11
save
P.S u should know ur PW to do this
Oct 14, 2008 | 2wire (1000-000057-000) Modem
2WIRE 2701 router
You must log on to the browser interface of the router (usually for 2wire they use 192.168.1.254) run the set up wizard it will come to a screen which asks for a key code, this key code is provided by your ISP, you can try one of these and see if it works
if you have a PPPOE connection (you have a user name and password to log on to the internet with use this one.
5225-26Q4-2262-22AS-B28F
if it is not PPPOE use this
5225-26P4-6262-22AS-B2E7
to manually configure the router use this
5225-2374-WG62-22AS-BJ7P
If these do not work call your internet provider and ask them for the key code.
after that you should be all set.
Aug 04, 2008 | 2wire 2700HG-B Router (2700HGB)
Can't get a connection back on my ISP (embarq).
If you have dial-up, go to tools>internet options>click "always dial my default connection" or if you have broadband click on "Never dial a connection" These settings are found in Microsoft Internet Explorer 5 or higher.
Apr 11, 2008 | Dell Microsoft Windows XP Home Edition
2wire modem home network
go to homeportal/management, or gateway.2wire.net/mdc. on the management and diagnostic console, under troubleshooting, click on resets. then click on the clear button for local network to erase all the devices on the local network. go to device list under local network, make sure you only have the computer or device seen on your device list aside from system.
Apr 06, 2008 | 2wire (1000-000057-000) Modem
2wire 1701HG Gateway Router VPN Setup
Go to http://gateway.2wire.net and click on the firewall icon. Click on firewall settings and, if prompted, enter your system password to reach the advanced settings page. select the computer that will function as the VPN server. In the left column, select PPTP server. click on Add, then done. or try changing the IP scheme to the 172.16.0.0/255.255.0.0 or 10.0.0.0/255.255.0.0 schemes by accessing gateway.2wire.net, go to home network icon, then advanced settings. but if you manually configure or disable dhcp, be sure to write down the subnet mask & IP assigned to the 2wire then click on save. if all else fails, run it on DMZPlus mode, however this solution will allow all inbound traffic to the computer. if it still doesn't work on DMZPlus mode, the VPN is either using the same IP scheme, is using IPSec 50 or 51, or will not work with the 2Wire gateway.
Jan 30, 2008 | 2wire (1000-400108-001) Router
Cannot reset 2wire 1000hw IP
The fact that you receive an IP starting with 209.154.. could also coming from the fact that the DHCP server inside your 2wire has a problem or that your 2wire changed some setting.
I would like you to open internet explorer and put the following address:
http://gateway.2wire.net/management
If the above address doesn't work, press Start, Run, type cmd and press enter.
At the prompt type    ipconfig /all  and confirm that the Default Gateway has an IP address similar to 172.16.0.1 or something else; if there is no value means that there is no communication with your router and we have to verify the hardware.
If there is an IP address on your Default Gateway, try to ping it by typing  ping xx.xx.xx.xx   change the xx with your Default Gateway IP address.
If you are not getting any reply means that the router doesn't communicate again, if you see some reply means that you can probably access to your router by opening internet explorer and entering the following http://xx.xx.xx.xx  where xx is your Default Gateway address again.
Please let me know up to where you can get some result and then we will continue from there.
Oct 30, 2007 | 2wire (1000-400108-001) Router
2wire 2700HG-B Router (2700HGB) Logo
55 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
