I have a 1997 model Sony 52" projection tv it plays fine for about 30 minutes then shuts off. I can turn it back on immediately and it will play 15 minutes or so then shut off again.
  • 6,487 Answers
Verify that the main filter capacitor is doing its job. Excessive ripple on the rectified line voltage bus can cause various forms of shutdown behavior. An easy test is to jumper across the capacitor with one of at least equal voltage rating and similar capacitance (make connections with power off!). Use a Variac, if possible, to bring up the input voltage slowly and see if the TV works at any point without shutting down. If it does, this could be an indication of X-ray protection circuit kicking in, though this will usually latch and keep the set shut off if excessive HV were detected.
Hope that helps.......
Posted on Jun 23, 2008
    Sergeant:
  • 260 Answers
It sounds like your power supply went out. If you feel comfortable working on this yourself, then let me know I will help you out. If not, you need a professional to come by to fix this. Please refer to our online list for a professional near you.
Ken
    Master:
  • 788 Answers
It is most likely trying to protect itself from overheating. Make sure to clear any dust away from the vents and ensure that these is proper ventilation space around the TV. You may want to have the unit serviced so that any dust inside can get cleaned out.
Shuts off and on while trying to watch, the power light flashes 30 times when off then the tv comes back on again
Power supply trouble. The TV keeps trying to start then operates for 2 seconds and shuts down. The cycle keeps repeating until eventually the TV will not start at all.
Nov 27, 2013 | Sony KDF-60X5955
RCA D52W20 TV powers on fine, then shuts itself off after 5 - 10 minutes. After 20-30 minutes, I can turn tv back on, but then shuts off again in 5 minutes.
it looks like the problem is in the 16v line..try to take it apart..and there's gonna be a 2200mf cap leaky.
that will solve your problem.
Jan 05, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Our RCA high-def 52 inch TV is shutting off on
It has you Posted as a projection TV and Not DLP, if Fan to Lamp stops running set will shut off to protect Lamp,I had a DLP that would play sometimes 30 mins then shut off drove me crazy trying to firgure it out and it turn out to be Fan would stop running I replaced Fan TV working fine . When you remove back engage toggler switch to up position put a piece of tape on it to hold it is a safty switch ,then turn tv on watch to see if all fans are running also if when tv trys to come on is there a spark coming from Ballast Board if so your new Lamp is defective it does happen if not your ballast board maybe Bad it is what turns on Lamp.If all fans are running Ballast Board.
Sep 22, 2009 | RCA HD52W56 52" Rear Projection HDTV
My RCA Bigscreen HDTV will not turn on.
Thats either the flyback or the HV splitter. If the sound is coming from the rear left side its the flyback. If its coming from the front of the set its the HV splitter. They are both easy to replace. I will post a link where you can get replacements with instructions if you would like.
May 06, 2009 | RCA D52W19 52" Rear Projection Television
Sony 52" flat screen will shut off and then come back on. What is the problem?
please mention exact model number of your Sony 52" tv to provide you help.
Oct 23, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV not working
need mor info the tv when turn on after 15 or 30 minuts works fine ?
Mar 21, 2008 | Pioneer PRO-520HD 53" Rear Projection...
Whine-no picture-audio only,1 channel
bring up the menu screen the tv and auto program the channels this lock out all un wanted and only allow the rf tuner input channel from the box if your using rf cable hook up,if not un plug the unit for 1 min. and try it again.
Dec 11, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
Top Televison & Video Experts
