Windows error I keep getting the following message when I turn on my computer, and I don't know what to do... "Windows could not start because the following file is missing or corrupt: WINDOWSSYSTEM32CONFIGSYSTEM You can attempt to repair this file by starting Windows Setup using the original Setup CD-ROM. Select 'r' at the first screen to start repair." When I put in the original CD, nothing happens either. Is there any way to also save my files? I have a lot of pictures on there that I want to keep. Thanks!
  • 667 Answers
Hi notsoscrewed- As long as you have your original XP disk you can save everything. First, make sure your pc is bootable from your cd drive. If you know it is good. If not, when your pc boots it should say something like hit F2 or <del> to enter setup. Go into the BIOS and find your boot options and make sure your cd is listed as bootable and listed to boot before your hard drive. Then save and exit. When your system reboots make sure you have your XP cd in your cd drive and your pc will say press any key to boot from cd rom. Press any key and follow these steps:
You must boot from your XP CD. Please make sure it is the same version of Windows that is currently installed on your computer (ex. XP Home cannot repair XP Professional). Place the CD in your CDROM and start your computer. Newer versions will work as well (ie. Windows XP Pro SP2 CD will work on an older WinXP Pro SP1 installation)
Before the Windows logo appears, you will be asked to press any key to boot from CD, so do just that.
A blue screen will appear and will begin loading XP setup from the CD.
Choose the FIRST option, NOT recovery console.
Choose F8 to continue
Next, Windows Setup will find existing Windows XP installations. You will be asked to repair an existing XP installation or install a fresh copy of Windows XP
That should be it. Windows XP will appear to be installing itself for the first time, but it will retain all of your data and settings. Just follow the prompts, have your CD-KEY handy . You may have to install XP updates again and reactivate XP but small price to pay and little time to be able to save all your software and info. Let me know what happens.
If this solves your problem PLEASE rate this as fixed. If you need more help with this just add a comment and I'll be more than happy to assist you further. Thanks.
Jeff
Posted on Jun 23, 2008
I keep getting messages that tell me I have many errors on my computer. One company with whom I accidentally thought was you told me it was going to cost X amount to fix. Norton which is on my computer...
If your computers running OK ignore them they are after your money.If you are running Microsoft Windows do the routine maintenance once a week.Use file checker and the defrag tool
and the delete browsing history tool, also find the add and remove programs tool and remove games and programs you don`t use.But be careful and make sure you don`t remove system files.You will probably still get error messages but ignore them or do a reinstall of Windows and start afresh with a clean system.I don`t like Norton and use the free Microsoft Security Essentials program and have never had a problem.
Oct 24, 2013 | Dell Computers & Internet
Igxprd32 error
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Apr 13, 2012 | Computers & Internet
Mp navigator 4.3 don't start
On Windows Vista, the following error message may appear while scanning:-
"Cannot communicate with scanner.
Code: 2,155,0 (or Code: 53,3,0)"
In such a case, close the error message and confirm that the cable is connected and the printer is turned on. And then perform a scan over again after a while.
Oct 29, 2011 | Canon Pixma MX360 Printer
I always got a Error #2046 on zwinky and i cant play it please help me
There exist many reasons for running into various error messages on your computer; if you've noticed an access runtime error 2046 in recent days, don't despair. You must realize that the lion's share of pc problems may promptly be sorted out although you may lack advanced computer skills. Scan the following few paragraphs and i will explain a quick and effective way to solve this error message problem.
Before you start, it's of great importance that you figure out the root of these problems. With a lot of these occurrences, your windows registry turns out to be involved - this is the location where windows keeps track of your activity. It keeps all records of the programs and hardware you've added, not to mention the links to the files that operate these applications. It is often the case that a broken link or damaged registry can be the reason for an access runtime error 2046 and a variety of other troubles, which can include slow response, lock-ups, and .dll errors.
Several other factors in getting runtime errors are the improper loading or removal of software programs, errors which can be caused by having many different applications on your pc, infections with viruses and spyware, etc. Once more, all of these factors can cause missing or damaged links in your windows registry, thus leading your windows to display all of those troublesome error alerts, or even worse problems
You can solve these problems in a number of different ways; the hard part is that you don't always know which specific program(s), or which specific corrupted registry configuration(s) may be the reason for the problems. In this scenario, particularly if you are not proficient in computer technology, you can choose from two possibilities: take the expensive route and hire a computer specialist, or simply download a specialized registry cleaner.
A registry cleaner is a tool that automatically scans your pc and finds a multitude of abnormalities common in personal computers; the tool does more than just detect these problems, it automatically takes care of the problem and restores your computer to its maximum efficiency. So the next time you encounter an access runtime error 2046, it is recommended to download one of these tools, many out there provide free computer scans and a limited number of free fixes. Now's your chance to eliminate this difficulty with just a few minutes of your time.
Sep 03, 2011 | Dell Dimension C521 PC Desktop
I have problem in my lg lcd monitor when start computer windows loading then il say out of range 53.5Hz/85Hz. i don't know how to solve that problem.
Sounds like the resolution is set to high which is why that message would come up. When you turn on your computer, keep pressing the F8 button. It will bring you to a menu. Choose "Safe Mode" and press enter. When you get into windows go into the display settings in the control panel. Then go ahead and set the resolution to 640X480. After you do that go ahead and restart the computer and let it boot up normally. That message should go away and once you get back into windows you'll have icons that look bigger then normal. At that point change the resolution to 800X600, if it takes that then try 1024X768 if you want to.
If after you are in safe mode and change the resolution and that error message comes up then you'll need to download the video drivers for your computer and reinstall them.
May 28, 2011 | Computers & Internet
I'm running windows 7 on a Toshiba L455 and I keep getting a prompt that says; can not find "flash.ocx"
Flash is a programming language that many publishers use to create animations, games, and interactive programs for the web. Flash is also used for programs run locally on a users computer. To use these Flash based programs and web applets, the end-user must have Flash Player installed. One component of Flash Player is a file called "flash.ocx." If this file is missing or damaged, you may get an error message.
There seems to be two root causes of this error. A description and solution for each follows:
  • You receive the error message "Cannot find the file flash.ocx" every time you start your computer or each time you open your web browser (such as Internet Explorer). This is usually the result of a missing "flash.ocx" file caused by an incomplete installation of Flash. Here's how to remedy the problem:
    1. Download the Flash Player uninstallrom Macromedia. Save it somewhere convenient.
    2. Run the downloaded program and allow it to finish.
    3. Once the uninstall completes, restart your computer.
    4. Visit the Flash Player website and download/install the latest Flash Player version.
    5. That's it!
  • You receive the error message "Cannot find the file flash.ocx" at seemingly random intervals or when starting a specific program (other than your web browser). First, perform steps 1-4 of the previous solution. This will insure you have the latest version of Flash Player installed. If you still receive the error message, continue with the steps below:
    1. Navigate to the folder "C:\WINDOWS\system32\Macromed\Flash\". In this folder you will see a file named "Flash9f.ocx".
    2. Make copy of the "Flash9f.ocx" file in the same folder as the original (copy the original, then paste the copied file into the same folder).
    3. Rename the newly made copy to "Flash.ocx".
    4. If the previous steps don't eradicate the error messages, change your screen saver to one of the defaults that are included with Windows (such as "3D Text").
if the problem still persist please let me know.
Apr 15, 2011 | Computers & Internet
Error Code: 0x80070002
I think The default security provider in Windows XP has been changed loadTOCNode(2, 'workaround'); To reset the default security provider in Windows XP, delete the relevant registry keys in the Windows registry. To do this, follow these steps:
  1. Start the computer. Press the F8 key during startup to start the computer in Safe mode.
  2. Start Registry Editor (Regedt32.exe).
  3. Delete the following registry keys in the Windows registry: HKEY_USERS\.DEFAULT\Software\Microsoft\Cryptography\Providers HKEY_USERS\S-1-5-20\Software\Microsoft\Cryptography\Providers
  4. Quit Registry Editor.
  5. Restart the computer
Jun 02, 2010 | IBM ThinkPad A21m 2628 Notebook
Keep getting this message <window
  • "Windows could not start because the following file is missing or corrupt:
    <Windows root>\system32\hal.dll.
    Please re-install a copy of the above file."
  • "<Winnt_root>\System32\Hal.dll missing or corrupt:
  • "Cannot find \Windows\System32\hal.dll"
  • "Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears. CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
    Please let me know you have any further questions or concerns.
Thanks.
May 08, 2010 | HP Compaq 6720s Notebook
When i turn on my computer i get a error message which says the computer started unexpectedly or encourntered an unexpected error.windows installation cannot proceed. hit ok to restart installation, hit ok...
you have to keep pressing f8 or f12 on start up untill you get a menu, there is a option in one of those menus to recover laptop on to restore windows the best previouse working order. try using your revovery cd and running from start the recovery process
Nov 29, 2009 | Toshiba Satellite A135-S4457 Notebook
Perpetual windows protection error loop!
use a win ME startup floppy disc. get to DOS and run scandisc.exe on c drive. if still no progress afterward, then repeat but this time, load cd driver and then re-install windows.
Oct 20, 2007 | Computers & Internet
Computers & Internet Logo
150 people viewed this question
David Payne
David Payne
