Question about Garmin StreetPilot c530 GPS Receiver
Unit no longer powers on
It was calculating my route and got stuck at 35% and turned off. Garmin told me to leave it unplugged for two days and plug it in, which didnt work.
SX2150KE aiwa t.v. service mode
Posted on Jun 23, 2008
Cannot Calculate the route - Garmin Nuvi 3760
My probleme:
When you want to select (established) a route (Finding Location or Planing a Trip) the device machine can not calculate route and displays the following message: "Route waypoint memory is full". The device is Garmin 3760T.
I found the solution:
1. Start the device.
2. Touch "Wiew Map or Map"
3. Touch on bottom right of screen (Speed)
4. Hold your finger on top center of screen for 5-10 seconds (the speed semicircle between Trip A and Trip B). The unit would go into "Diagnostic Page".
5. Select "Clear all user data" and confirm.
Warning: will erase all user-selected data (Home, Recently Found, Favorites, Trip Planner, ....).
Mar 04, 2014 | Garmin Nuvi 3790T 3790 3760T 3760 3750...
I have a garmin street pilot c530 after i power it up and agree to the disclaimer the screen reads as follows no deailed maps found that support routing street pilot cannot be used without them the unit...
I just purchased my c530 a couple of days ago and had been loving it. I had added some custom POI's to my sd card using POI loader version 2.4.0 and that had worked fine. Then the other day I tried to load some new custom POI's, but POI loader got hung up and froze. After disconnecting the c530, I restarted it. After it started, a screen came up that said "No detailed maps found that support routing. The Streetpilot cannot be used without them." I contacted garmin, here is the site for contact info since I am unsure where you are. the tech support at Garmin. They said that somehow the files on my c530 must have gotten corrupted. The person I talked to at Garmin was very friendly and walked me through several things trying to get my unit to work. He was very apologetic and said that this should not have happened. He told me I would have to return it and get a replacement. Sorry Hope this helped.
Jun 09, 2008 | Garmin GPS
Can you in put a pre selected route in to the Garmin Nuvi 1310 GPS so that i can have the route in turn by turn before i leave home
Sure and your doing the correct thing good thinking, always check the route before you go there are way to many ways to get there....
When you input the destination let it calculate then press the green bar on top where it says which way to turn.... it will then let you see which way its traveling, you can arrow down turn by turn or on bottom of screen press show map and give you the route highlighted with a green flag and checkered flag
Nov 11, 2010 | Garmin nuvi 1310 Car GPS Receiver
My 775t gets hung up at 23% when calculating a simple route
look for a small hole in bottom of unit. insert a small pin or paperclip and hold down for 15 seconds. try turning on again. Are you sure you have the correct set of maps for europe? you may need to manually switch to the correct map set as the unit may not switch automaticlly.
Sep 13, 2009 | Garmin GPS
Garmin Nuvi Unable to calculate route No roads near starting poin
Its a problem you need to address with Garmin on this model before warranty runs out
Please rate our help to keep the FREE service onlinew++++Thank you for using FIXYA
Sep 11, 2009 | Garmin nuvi 350 GPS Receiver
The nuvi 500 loaded with garmap 2009. Route calculation problem
good day sir
have tou dun a firmware update on the unit
if you have done so can you please send a copy of the route to me please
Werner Trollip
Office: +27 11 251 9999
DIR +27 11 251 9956
Fax: +27 86 544 3972
Jun 05, 2009 | Garmin nuvi 500 GPS Receiver
Route calculation Error on Garmin GPSmap 60CSx
Try re-setting your gps by simultaneously pressing the Enter and Page buttons while turning it on if that doesn't work check your firmware i found the latest one v 3.90 would shut off my gps when recalculating v 3.70 is stable Garmin know that the new firmware can cause problems
Mar 09, 2009 | Garmin GPSMAP 60CSx GPS Receiver
Garmin c530 Streetpilot
I just called tech support at 1-800-800-1020 and I was told that the battery on the unit may be so low that it won't power on even with a power source. The unit actually uses more power than it's taking in from the car charger. I was told to plug it into the computer using the USB cable and give it a few hours to replenish the battery. Apparently it should be plugged into the computer ever so often to keep the battery from getting too low.
May 09, 2008 | Garmin StreetPilot c530 GPS Receiver
Garmin c530 won't turn on
Have a c530 I purchased 11/2006. In 12/2006 had 3 instances where I shut unit off and it would not turn on. Garmin had me do resets which did nothing. Had to leave unit to discharge for 3 days, then plugged in USB and it powered up and was fine (for a week or so). They gave me a new unit and at the same time a system software upgrade was available. The c530 was perfect through all of 2007. Then in Jan 2008, the same failures occurred 3 times. I discharged it 3 times and it now works, but for how long? My advice is to get anoher model. I have 5, c330's for over a year and they have had 100% reliability. l
Jan 25, 2008 | Garmin StreetPilot c530 GPS Receiver
Route calculation error
I was having the same problem and contacted Garmin support.
What I had done was turned off the Basemap that came with the unit. I only had the mapsource map street map on which I had purchased separately.
The technician basically said the unit needed the basemap to "locate itself". Somehow the basemap supports any maps you purchase separately. That seemed odd but once I turned the Basemap back on it calculated the routes and the error message went away.
If you have the Basemap off, try turning it on from the Map Setup - Information window.
Hope this helped.
Oct 01, 2007 | Garmin GPSMAP 60CSx GPS Receiver
Garmin StreetPilot c530 GPS Receiver Logo
61 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
