Question about Canon PowerShot A70 Digital Camera
Helppp when i put my compactflash disk in my camera, it wont turn on. when i take it out of my camera, it turns on but it also says no memory card. i put the compactflash into my computer and it says that it is blank, so i dont know why it wont turn on... please help.
  • Canon Master
  • 4,738 Answers
Remove batteries and card. Look in the card slot for any bent pins. If you see some, use a small/skinny jeweler's flat screwdriver (K-mart, Walmart, and even dollar stores sell these, look in the hardware section) to bend the pin back as close as possible. Take your time and use as much patience as you can muster (take a breather in between if needed).
It doesn't have to be perfect, just as close as you can get it. When it's there, take your flash card and "SLOWLY" insert it. The card itself should fine-align the pin. Remove the card, and verify that the pin is still straightened. If so, reinsert the card and try it out.
Posted on Jul 08, 2008
It wont read the cards
A: Make sure you're using a supported memory card. See the table below for specifications:
Memory Card Type Maximum Capacity CompactFlash Card
(Type I and Type II--3.3V only) 8GB Microdrive (3.3V only) 4GB SD (Secure Digital) 2GB MultiMediaCard 1GB
If you connect a compatible CompactFlash (CF) adapter that can read 8GB memory cards, you can also use the memory cards listed below (with a capacity up to 8GB):
  • Memory Stick
  • Memory Stick Duo
  • Memory Stick PRO
  • Memory Stick PRO Duo
  • xD-Picture Card
  • SmartMedia Card (3.3V only)
Mar 26, 2014 | Epson PictureMate Photo Printer
Formattting again and again my SanDisk Extreme III 4.0 Gb CompactFlash Card
Hi, It may be possible that your CompactFlash Card is nearing its end. You can try formatting it after you have downloaded into your PC all the pictures. Try to use the camera's built-in formatting function. Thereafter plug it back to your PC and use a disk checking utility such as scandisk or Norton Disk Doctor. Do an intensive check including the free space. If the disk check shows any errors, then the CompactFlash Card is no longer a reliable storage media and you are better off purchasing a replacement rather than gamble that it will still work. If for some reason, even your PC can not access the card, you have to use a file recovery program to recover/download/copy the picture files and then try the disk check utility. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 09, 2007 | Cameras
My sony cyber shot camera suddenly is saying that my Lexar 4GB CompactFlash Premium Series 80x needs to be formatted. What about my pictures?
You might have locked memory card. If not first try to connect memory card to PC with memory card reader and try to copy your stuff... then after you take all stuff try to format it.
Sep 16, 2012 | Lexar 4GB Professional Series 80x...
Memory Quit working
Hi there, please check with the Nikon Dealer the 4G card compatibility issue, maybe the card is too big for your camera. Best regards, Arpi
Jun 17, 2007 | Nikon Coolpix 5700 Digital Camera
Card Error
This is from Konicas site. don't know if this will be any help for you since you had posted a long time ago. you most like have a new camera by now. anyway. Question: When a CompactFlash is loaded, a message of "Card Error. OK" appears and remains on the monitor display. Answer: Please follow the procedure below. While the message is displayed, press the center of the controller. The monitor display and data panel will turn off. Turn the Main Switch dial to OFF position and remove the CompactFlash from the camera. - When "No Card" message appears next time when the camera is activated in the recording mode, the camera and CompactFlash are OK. - When "Card Error. OK" appears again, the CompactFlash may be faulty. Use other card.
May 05, 2007 | Konica Minolta DiMAGE S414 Digital Camera
When a CompactFlash is loaded, a message of "Card Error. OK" appears and remains on the LCD monitor.
Please follow the procedure below: 1. While the message is displayed, press the center of the controller. 2. The LCD monitor and data panel will turn off . 3. Turn the Main Switch to OFF and remove the CompactFlash card from the camera. 4. If "No Card " message appears at next time the camera is activated in the recording mode, the camera and CompactFlash card are OK. 5. In case that "Card Error. OK" appears again, the CompactFlash card may be faulty. Use other card.
Sep 15, 2005 | Konica Minolta DiMAGE A1 Digital Camera
ERROR MESSAGE: Corrupted CompactFlash card.
Storing digital picture information to a CompactFlash card (as when a digital image is taken) is similar to storing data on the hard drive of a computer -- if the process is stopped or interrupted, the information stored is not complete and, therefore, "corrupts" the storage media. A computer will display a warning message indicating that the hard drive has errors, while a camera will display a message indicating the memory card is corrupted. The CompactFlash card corruption can be caused by: * Turning off the camera power before the photo information is completely stored on the card. * Removing the card before the photo information is completely stored on it. * Taking a second picture before the camera has finished storing the previous picture. * Camera batteries that are near the end of their life and need to be replaced. Once a CompactFlash card is corrupted, it can be used again only by performing a Format procedure. IMPORTANT! When a CompactFlash card is re-formatted, any pictures stored on it will be lost forever and cannot be recovered.
Sep 14, 2005 | Polaroid PhotoMax Fun Flash 640 Digital...
Sep 14, 2005 | Polaroid PhotoMax Fun 320 Digital Camera
What else can I do with CompactFlash
You can copy images to a CompactFlash card from the camera's internal memory or copy images from the CompactFlash card to the camera's memory. Also, if you have a PCMCIA adapter and a computer with a Type II PCMCIA slot, you can access images stored on a CompactFlash card directly from your computer.
Sep 13, 2005 | Epson PhotoPC 600 Digital Camera
Canon PowerShot A70 Digital Camera Logo
23 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
