Question about HP Pavilion dv6000z Notebook
Http/1.1 Internal Server Error - HP Pavilion dv6000z Notebook
  • se73n Jun 23, 2008
I spent ages on this problem and so very glad i came onto this sight i have easily managed to log onto ebay - many thanks, excellant
Posted on Aug 12, 2008
    Scholar:
  • 174 Answers
The windows od with latest update does not allow two versions of ASP.NET to run in the same application pool.
do onething go to run and type cmd enter then type iisreset enter
I hope your problem is solved
Thanks
Hothawk
Posted on Jul 02, 2008
Microsoft Exchange Server. HTTP 500 Internal Server Error.Any recommendations?
To resolve this problem, follow these steps on your Exchange 2000 or Exchange 2003 back-end server. Alternatively, follow these steps on another computer that has access to the same domain controller and the same global catalog server.
NoteThis procedure requires the Exchange Server Fix Toolbox
1.Start the the Exchange Server Fix Toolbox
  1. Right-clickYour_back-end_Exchange_server, and then clickProperties.
  2. Clicknetworkaddressin theAttributeslist, and then clickEdit.
  3. Add a new value forncacn_ip_tcp. Use the FQDN of the server instead of the NetBIOS name or the host name of the server.
    The syntax for this value isncacn_ip_tcp:FQDN. For example, if your Exchange back-end server has a host name of EXCHANGE1 and the FQDN is EXCHANGE1.domain.com, use the following value forncacn_ip_tcp:ncacn_ip_tcp:EXCHANGE1.domain.com
  4. Remove the oldncacn_ip_tcpvalue that contains the NetBIOS name or the host name of the back-end server.
  5. Apply this change.
  6. Because your Exchange computer may change this value back during a failover or a system attendant restart, configure the following registry value on both nodes of the cluster:
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\MSExchangeSA\Parameters\UpdateProtocols
  1. Right-clickUpdateProtocols, clickModify, type0in theValue databox, and then clickOK.
  2. If your network uses a Hosts file on the back-end cluster node, modify it by using the following order of entry:
  3. Restart the Exchange services on the back-end cluster node.
  4. If there are multiple domain controllers, wait for replication to occur before you try to log on from the front-end server. If the problem is not resolved after replication is complete, restart the IIS Admin Service on the front-end server.
You can obtain the Exchange Server Fix Toolbox by visiting the following site: https://www.fixtoolbox.com/exchangeserverfix.html
Jul 27, 2015 | Microsoft Exchange Server for PC
Internet explorer http internal server error 500 help gave it a day still cant get online!!!
Error 500 to 504 are usually nothing to do with your system, they are errors created by the server you are trying to connect to.
Introduction
A server (not necessarily a Web server) is acting as a gateway or proxy to fulfil the request by the client (e.g. your Web browser or our CheckUpDown robot) to access the requested URL. This server did not receive a timely response from an upstream server it accessed to deal with your HTTP request.
Mar 21, 2011 | Computers & Internet
HTTP 500 internal server error while accessing yahoo account
Check your computer for malware, because you should be logging on with https, and not an unsecure connection. Free options i suggest are avast antivirus, www.avast.com, and ad-aware, www.lavasoft.com.
Additionally, you may want to see if you have the same error with a different browser, such as mozilla's firefox, www.firefox.com
Jul 15, 2009 | Yahoo Mail
Keep getting an 500 internal error error need help how to download opera browser for i9 motorola problem:
Hi, a 500 error has to do with your webhosts server.
#1. The server was down for a long time.
#2. Your host doesn't support PHP files.
Jun 29, 2009 | Computers & Internet
The server encountered an internal error
just refresh...if that doesnt work Re-type the youtube address if that doesnt work try a different brower...if u dont have another browser download some
konquerer, opera, firefox, flock, chrome
May 16, 2009 | YouTube Videos
Http/1.1 internal server error
If you are running two versions of ASP.NET, you may get HTTP:/1.1 500 Internal Server Error when creating a new Web project or opening an existing Web project in Visual Studio.
This problem may occur when IIS is not sure what version of ASP.NET to use or where to locate ASP.NET files. One of the following solutions should fix the problem.
Solution 1.
  1. Remove web.config file from inetpub/wwwroot directory
  2. Go to IIS, Right click on Default web site / All tasks / Check server extensions and let it run
  3. Reset IIS by right click on IIS or call iisreset from Run command
Solution 2.
  1. Install ASP.NET again using the following command from your Run command: C:WINNTMicrosoft.NETFrameworkv1.1.4322aspnet_regiis.exe
    Make sure to change the windows folder and ASP.NET version folder with the version what you want to install
  2. Reset IIS
Solution 3. Applies to Windows Server 2003
Note: This is a Microsoft KB article:
When you try to create a new Microsoft ASP.NET 1.1 application after you change the script mapping of the existing ASP.NET 1.1 Web application to ASP.NET 1.0 on a Microsoft Windows Server 2003-based computer, you may receive the following error message:
The Web server reported the following error when attempting to create or open the Web project located at the following URL: 'http://localhost/822319ev1'. 'HTTP/1.1 500 Internal Server Error'.
CAUSE
This issue occurs because Windows Server 2003 does not allow two versions of ASP.NET to run in the same application pool.
WORKAROUND
To work around the problem, do one of the following:
Restart the IIS before you create a new ASP.NET 1.1 application. At the command prompt type the following command: iisreset
OR -
Create an ASP.NET application in a separate application pool. Create the script-mapped application (ASP.NET 1.0) in a separate application pool -- for example, in the ScriptMapappPool application pool. Then, create a new ASP.NET 1.1 application in an application pool other than ScriptMapappPool. For more information about how to create an application pool, visit the following Microsoft Web site: Configuring Application Pools http://msdn.microsoft.com/en-us/library/1kdfe21k(VS.80).aspx
Dec 10, 2008 | Acer Aspire 5610 Notebook
Fan flow error 1611 I/O
The ProLiant DL380 G3 server requires that both primary and redundant fans exist in a specific configuration in order to perform optimally. Any deviation from the specified configuration will cause one of the above error messages to occur and the internal Health LED to illuminate. In a ProLiant DL380 G3 server without the redundant fan option, the server will shut down after the error message is displayed. In a server with the redundant fan option, the internal Health LED will illuminate and the appropriate error message regarding fan redundancy will be displayed. The purpose of this document is to detail the required configuration for both primary and redundant fans.
DETAILS Both primary and redundant fans in the ProLiant DL380 G3 server must be configured to meet specific requirements in order to avoid the error messages above and in some instances, subsequent shutdown of the server.
All primary fan locations (2, 4, 5, 6 and 7) must be populated with a fan before the redundant fan locations (1, 3, or 8) are populated. If a primary fan location is left unpopulated, the server will display one or more of the error messages shown above. In addition, the internal Health LED (the top LED on the front panel of the server) will display the status of the fans.
When the redundant fan option is used, all redundant fan locations must be populated. ProLiant servers do not support partial population of redundant fans. If any redundant fan location is populated without also populating all other redundant fan locations in the server, the fan system will not be fully redundant and one or more of the error messages above will be displayed.
Figure 1 below illustrates a ProLiant DL380 G3 server configured with all eight fans installed for fan redundancy. The server airflow is divided into three zones: processor, I/O and power supply. Shared fans 4 and 7 each provide airflow for two zones. If a shared fan fails, the failure is experienced in both zones.
Figure 1: ProLiant DL380 G3 server configured with all eight fans installed for fan redundancy
The internal Health LED (the top LED on the front panel of the server) indicates failed or missing components. The internal Health LED should be observed to determine the status of the fans as follows:
RED LED: A red LED indicates that the minimum fan requirements have not been met. Minimum fan requirements indicate that all primary fan slots must be populated with functioning fans.
  • If the 1611 fan "x" is not present (where "x" is the fan location) error message is displayed at POST and the internal Health LED is red , then a primary fan is missing.
  • If the 1611 fan "x" failure (where "x" is the fan location) error message is displayed at POST and the internal Health LED is red , then a primary fan has failed.
AMBER LED: An amber LED indicates that the minimum fan requirements have been met; however, requirements for redundant fan configuration have not been met. This means that all primary fan slots are populated with functioning fans, but at least one redundant fan has either failed or is missing.
  • If the 1611 fan "x" is not present (where "x" is the fan location) error message is displayed at POST and the internal Health LED is amber , then a redundant fan is missing.
  • If the 1611 fan "x" failure (where "x" is the fan location) error message is displayed at POST and the internal Health LED is amber , then a redundant fan has failed.
Note: In a redundant fan configuration, the error message fan system not fully redundant will also be displayed at POST if any redundant fan slot is left unpopulated or if a redundant fan has failed.
Nov 21, 2008 | HP Compaq ProLiant DL580 G4 (430811001)...
Internal Server Error 500
Start Internet Explorer. 2. On the Tools menu, point to Pop-up Blocker, and then click Pop-up Blocker Settings. 3. In the Address of Web site to allow box, type http://v5.windowsupdate.microsoft.com, and then click Add. 4. Click Close to close the Pop-up Blocker Settings dialog box.
Feb 13, 2008 | Office Equipment & Supplies
HP Pavilion dv6000z Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
