Question about Philips Magnavox 51MP392H Rear Projection Television
NO PICTURE HAS SOUND
My Philips Magnavox, model 9P6034C103, chassis PTV835 is about 7 yrs old, past month acting up. When turn tv on picture would fluctuate from big to small and stay small for several minutes then will go back to normal NOW there's no picture, but has sound. Could someone give me more info as to what parts might need to replace? Thanks in advance has no picture has sound.
  • Philips Master
  • 3,459 Answers
I had the same problem. Check www.magnavoxhelp.com for instructions on how to fix it.
Posted on Jun 24, 2008
Phillips magnavox 9P6034C103 turns on but no picture or sound
Its a older set: most common issue which can cause your problem is convergence short.
The only way to know is gain access to the two (should be stk-392-120 or -110) convergence chips have to be unsoldered (all 18 pins on both) and then the set turned on to see if it will power up---picture will look very bad but if set comes on the chips are bad.
If you do not have the skill or desire to try that it may be time to consider replacing the set.
May 16, 2012 | Philips Magnavox 51MP392H Rear Projection...
I lost my picture I still have sound but no picture.
I have a Philips Magnavox Projection TV.
I had dish satelight install on my TV. It worked well for two days, then the picture started showing in a square box. I ffixed the convergence and it seemed okay. The next day I turned on the tv and it had sound, but no picture. When I press the status button, the picture would come on then go right back out. Now I don't have any sound or picture. Here is the model information:
Brand: Philips Magnavox
Model #: 9P6040 C104
Serial #: 51190366
Chassis # PTV843
Manufactured: Nov. 7, 2000 (3910K071H)
TV Receiver Listed: 347K E10839
Amps: 3.7
HZ: 60
V: 120
Can someone please, please help me!
Nov 15, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Picture from 60" to 19" then gone.
The fluid is a fairly easy replacement. They just need to remove the CRT with the bad fluid and drain the old fluid and clean the CRT and then replace the fluid. The Shrinking is just a Vertical Deflection problem which is also an easy repair. A new Vertical IC and a couple Capacitors. In my shop it would run @ $200.00 to fix both.
Dec 19, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox Video Shrinks over and over
If you have the following symptoms check the site www.TvRepairKits.com . They have a repair kit for this problem.
Screen shrinks and expands - may or may not correct itself after the TV warms up. After a few days, weeks, or months of having the shrinking/expanding problem you may loose all audio/video but the power light will remain lit!
Works on the following Philips Magnavox sets with chassis number
PTV835, PTV836, PTV840, PTV841, PTV842, PTV843, PTV844, PTV847, PTV853
Or if your Model number is...
50YP43C101,50YP43C102,50YP44C101,50YP44C102,50YP44C103,50YP44C104,55P9161001,55P9161002,55P9161003,55P9161004,55P9271001,55P9271002,55P9271003, 55P9271004, 55P9271005, 55YP43C101, 55YP43C102, 55YP43C103, 55YP43C104, 55YP44C101, 55YP44C102, 55YP44C103, 55YP44C104, 55YP45C, 60P9161001, 60P9161002, 60P9161003, 60P9161004, 60P9271001, 60P9271002, 60P9271003, 60P9271004, 60P9271005, 60YP43C101, 60YP43C102, 60YP43C103, 60YP43C104, 64P9161001, 64P9161002, 64P9161003, 64P9161004, 64P9161005, 64P9161006, 64P9271001, 64P9271002, 64P9271003, 64P9271004, 64P9271005, 64P9271006, 64P9271007, 9P5031C101, 9P5031C102, 9P5031C103, 9P5034C101, 9P5034C102, 9P5034C103, 9P5040C101, 9P5040C102, 9P5040C103, 9P5040C104, 9P5044C101, 9P5044C102, 9P5044C103, 9P5044C104, 9P5511C101, 9P5511C102, 9P5514C101, 9P5514C102, 9P5531C101, 9P5531C102, 9P5531C103, 9P5534C101, 9P5534C102, 9P5534C103, 9P5540C101, 9P5540C102, 9P5540C103, 9P5540C104, 9P5544C101, 9P5544C102, 9P5544C103, 9P5544C104, 9P6031C101, 9P6031C102, 9P6031C103, 9P60349101, 9P60349102, 9P60349103, 9P6034C101, 9P6034C102, 9P6034C103, 9P6040C101, 9P6040C102, 9P6040C103, 9P6040C104, 9P6044C101, 9P6044C102, 9P6044C103, 9P6044C104, 9P6440C101, 9P6440C102, 9P6440C103, 9P6440C104, 9P6440C105, 9P6444C101, 9P6444C102, 9P6444C103, 9P6444C104, 9P6444C105, PV5571C101, PV5571C102, PV5571C103, PV5571C104, PV6071C101, PV6071C102, PV6071C103, PV6071C103, PV6071C104
Dec 12, 2008 | Philips Magnavox 9P6034C 60" Rear...
Audio only, no picture
Audio without video is usally a vertical or horizontal deflection problem with the DPTV chassis and Mag 1 chassis which is what you have. You may need a new deflection Large signal board. If you would like a link to one of those boards let me know.
Jul 21, 2008 | Philips Magnavox 51MP392H Rear Projection...
Regarding service manual for philips magnavox
You can also get a Factory Service manuals from www.magnavoxhelp.com. The manuals can be downloaded instantly. They are complete with over 2000 pages in all.
Their manuals cover all projection TV models with Chasis # PTV835, PTV836, PTV840, PTV841, PTV842,PTV843, PTV844, PTV847,PTV853
Feb 12, 2008 | Philips Magnavox 9P6034C 60" Rear...
My 60" Philips Magnavox, model 9P6034C103, chassis PTV835
It could be the flyback losing resistace in its windings. What is the chassis number I should have the service manual for it. Phillips/magnavox is hard to cross reference without the actual chassis number.
Feb 11, 2008 | Philips Magnavox 9P6034C 60" Rear...
When you say small do you mean shrunk up top and bottom as well as from side to side. You definitely have a deflection problem either horizontal or vertical.If the picture just shrunk top and bottom you have a vertical deflection problem. Do you have the service manual for your model? If not let me know and I will email you one. Describe the shrinking issue a little more and I should be able to give you some guidance.
Feb 06, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips 9P6034C103 - Urgent Response Appreciated
Was the hour glass upright or sideways? From what you described I would say you have a pin-cushion problem. Let me know if you need any additional info.
Feb 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 51MP392H Rear Projection Television Logo
162 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
