Memory card reader
My laptop has a built in memory card reader. My camera uses a sony memory stick and to transfer pics to my laptop I have to use an memory stick adaptor. I have done this many times before with no problems but now when I put the card into the computer the computer sees the card but says it is not formatted. If I put the card back into the camera it works fine. I have also tried putting a SD card from another camera into the reader and it works normally, no problems. I have tried restarting with no luck. any help would be appreciated.
  • malo_four Jun 23, 2008
    I was excited when I read your post thinking that it would fix the problem but it didn't. I did what you said and when I put the card in the computer said it needed to be formatted so I hit ok but then it said that the card could not be formatted. I don't know what the problem is. I ended up connencting my camera to my computer via usb and it saw the pictures on the card no problem and let me transfer them. For some reason the reader is not working with this card even though it has in the past. Could the adaptor be messed up?
  • miketahan Dec 05, 2008
    I have a Dell Inspiron 6000, the SD card reader was working fine until recently. It no longer could start (code 10) the SD Memory Card.
    I worked with Microsoft Support with no result. I have installed a Ricoh driver and I can now read MMC cards but not SDs.
    Problem Solver:
  • 8 Answers
This happens due to some restirction on the memory card i faced the same problem all you have to do is just copy the pic on to the laptop or on any other laptop and then you can format this card however before u format copy the pic as it will delete the data from the card .
i did the same as did not work on my hp laptop and worked on lenovo laptop for my phone memory it is also called as registry problem of the memory card .
thanks try it out and please let me know
thanks alson
Posted on Jun 23, 2008
  • alson_1925 Jun 24, 2008
    yes the reader might have however i still suggest to check another card if possible to see if the reader is a problem or not
    thanks for the reply
    thanks alson
My dsc-w310 wont connect on my computer, it says switch on usb mass storage which is on? what to do?
Sometimes it is easier to remove the memory card from your camera and connect directly using a card reader. Modern computers often have a card reader built in for the popular cards like and SD card. Sony often have 'Sony Memory Stick' cards. This would usually mean you have to purchase a card reader separately unless it is a Sony laptop. Card readers are less than 10 GBP each often only 5 GBP. Connect card reader cable to a USB port open windows explorer or my computer, create a new folder on your computer and then click and drag the photos from the card reader to the folder on your computer.
Dec 21, 2013 | Sony Cybershot DSCW310 Digital Camera
Can I import camera pics to a Dobly Home Theater laptop, by Acer?
First a nitpick: your memory card is Memory Stick Pro Duo, it's not an SD card. Secure Digital is one specific type of memory card, distinct from xD, CF, Memory Sticks, and other memory card types.
Okay, not that I've got that off my chest, yes you can import pics to your laptop. Just connect a card reader to the USB port and then put your Memory Stick into the reader. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files.
Card readers should be available at just about any department, electronics, or office-supply store. One important point to remember is to make sure you get a card reader that can read Memory Stick Pro Duos. If you get, for example, an SD card reader, it won't do you any good.
Jun 11, 2012 | Sony Cybershot DSC-T200 Digital Camera
I have a dsc-w150 digital camera, no usb cord. how can i transfer my pictures to laptop?
You'll need a card reader to transfer the data to your PC.
These days most laptops and printer has built in card reader. But since Sony camera's use memory stick, some of them don't support memory stick. So,
  • First check whether or not your printer or laptop has memory stick support, if has then use it to transfer you images. Otherwise you've to purchase a memory card reader with memory stick read support[should be available on any nearby electronic shop].
  • Then remove your memory stick from your camera and connect it with your laptop.
  • Open the memory card and copy your images.
Mar 15, 2011 | Sony Cyber-shot DSC-W100 Digital Camera
Sony cyber shot 7.2 Carl Zeiss transfer pics on memory card
No.
Take the memory stick out of the camera then connect to the computer. You can then transfer the pictures from the camera to the computer.
Alternatively, use the camera's copy command to copy the pictures from the internal memory to the memory stick.
Jul 12, 2009 | Cameras
Our computer cant access our psp memory card
fe4875a.jpg Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} PSP uses Sony Memory Stick Pro Duo and you need an adaptor (see picture) to use it on your external card reader or your laptop’s built-in card reader. Also, please check your card reader if it supports Memory Stick Pro Duo.
If you already have an adaptor but still doesn’t work, you can buy a PSP USB data cable to transfer files between your computer and PSP.
Apr 09, 2009 | Sony PlayStation Portable (PSP) Slim...
Memory stick photos to laptop
Connect a card reader and insert the memory card to this card reader and you can transfer the pictures to your computer. Now most of the card readers have slots to insert all types of memory cards, you can have any card reader from a local electronic shop.
Mar 25, 2009 | HP Pavilion Laptop RM-70 Notebook
Memory stick error
Hi There, In the menu there should be a setting to set the camera back to factory. Try re-formatting the card. Try using a different card. The camera has some built in memory, take card out and shoot 2 pics on built in memory, is playback ok?
If not, card reader may be defective. Only service shop could tell you that for sure.
Let me know, mr cicmo.
Dec 28, 2008 | Sony Cyber-Shot DSC-F717 Digital Camera
My memory card says that it needs to be formatted
If you have a memory card reader built into the computer, printer or by itself insert the memory card and see if the pics come up to transfer over. Lots of stores like Walgreens/Rite Aid/Savon have print machines you can stick the mem card in to print pics and backup to CD/DVD for a few dollars.
Nov 17, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Sony DSC-P71 Can't Transfer Pics from memory stick to computer
I have the same problem .Ican see pictures on LCD but thet stick is not recognized by computers. we tried at wal-mart and other shops too. please help me. these picturs are very precious to me. Thank you.
Apr 07, 2008 | Sony Cyber-Shot DSC-P71 Digital Camera
Transfering pictures using the memory stick.
Where would you put the memory stick?
two mthods if you have a card reader- built in or external use thiat.
Otherwise leave stick in  camera and connect using the USB cables supplied.
Oct 12, 2007 | Sony Cyber-Shot DSC-P92 Digital Camera
Computers & Internet Logo
265 people viewed this question
David Payne
David Payne
