My panasonic dvd player and recorder is frozen will not function will not release disc or accept any commands DISPLAY SHOWS ??ERROR CODE U 99 RETAILER STATES I HAVE TO RETURN T O PANASONIC MOEL NUMBER DMR-EZ25EB
  • lipworth Jun 23, 2008
    YOU ARE NO HELP I HAVE ALREADY BEEN ADVISED BY MY RETAILER TO LET THEM SEND THE MACHINE BACK TO PANASONIC UNDER WARRANTY
    Problem Solver:
  • 13 Answers
Yes, U99 is a software issue most of the times, you can check this website for the newests software version for your player:
http://www2.panasonic.com/consumer-electronics/support/Drivers-and-Downloads/list-DVD+Recorders
Try updating the firmware (software) on your player, if not you might need to send it for service to a Panasonic authorized service center.
Posted on Jun 23, 2008
  • El Loco 1 Jun 23, 2008
    Did you check for the software upgrade?
My Philips DVD Recorder does not accept a DVD disc shows no disk. The DVD disc does not revolve. A CD disc revolves but shows junknown
Could be that you are using the wrong type of DVD ? There are two formats DVD+R, DVD+RW etc and DVD-R, DVD-RW etc. Some machines are capable of using either, others can use one of the two formats.
My other suggestion is that some machines are picky about which manufacturer's DVDs they will use.
6.November.2015
https://en.wikipedia.org/wiki/DVD_formats
if you have an error code this might be useful
Dvd recorder won record on DVD RW disc
Some possibly relevant answers here which suggest my answers above
http://www.digitaltvbanter.co.uk/uk-tech-digital-tv-digital/25025-brand-new-panasonic-dvd-recorder.html
Nov 06, 2015 | Philips Televison & Video
My sony dvd oplayer/recorder only sometimes accepts the dvd-rw discs without displaying disc error
That is odd, the only other option is buy a DVD cleaning kit and follow the instructions it might solve your problem.
Mar 07, 2012 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Dmr-ex85 shows u81 code and is not functioning at all, says please wait but eventually just goes onto error code. no buttons will function?
Physically unplug power from the unit for a minute or two.
Connect power cord to unit and Simultaneously Press & Hold
both the [STOP] and Channel UP [^] for 5 seconds. This will
force Eject the DVD tray. Remove any disc if present.
Cycle the power again if necessary and wait for the unit to
go through its self check cycle. If after several attempts, and
you continue to get this error, then your Ram drive may need
to be replaced.
Jul 12, 2011 | Panasonic DMR-EX85EB-S DVD Recorder/HDD...
During my recent transfer to a new flat i lost my remote control for my panasonic dvd recorder type DMR EH67. I bought a universal remote control but i did not have the full functions of my lost one. In my...
You can try changing the command mode of the (genuine Panasonic) remote itself, press and hold [ ENTER/OK ] and the number [ 3 ] button together for 5 - 10 seconds, then release. Then try the remote with the unit. If it still shows DVD 3 on its display, no matter which button is pressed, reset the main unit to factory default as outlined in the user manual (assuming this model recorder has a tuner, there would be channel buttons on the front - try pressing and holding [ CH/UP ] and [ CH/DOWN ] together - for 5 - 10 seconds, until 'SETUP' appears, then release). This may or may not restore your DVD unit to the default (DVD 1) command mode. (Don't forget to reset the remote back to DVD 1 if you do reset the main unit - press and hold [ ENTER/OK ] + the number [ 1 ] button together as above).
Your new remote may be set to DVD 1 by default while your unit is DVD 3 = different remote command modes.
May 02, 2011 | Panasonic DMR-EH67EG DVD Recorder/HDD...
My panasonic dvd/vcr combo displays the message DV D 2 in the display. Cnnot play DVD
Sounds like your remote code is different to what's in the unit's display (DVD 2). You can try to 'reset' the remote, by pressing (and holding) 2 and ENTER/OK buttons together for 5 - 10 seconds, then release. This should restore your remote function back to your unit. If it does not, replace the batteries with new ones, and try again.
The remote may require a 'reset' of its command mode (to match the unit) whenever the batteries are replaced.
I assume you can play DVD by pressing the PLAY button on the main unit.
Apr 28, 2011 | Panasonic DMR-EH55 DVD Recorder/HDD...
I entered,in error, Command mode 3 on the set up and now the remote control won't operate the machine.The display keeps showing DVD 1,how do I restore things?
Try this (works for Panasonic) - remove the batteries from the remote (as if to replace them with new ones), press any button on it to clear its buffer, then re-insert them (if they are reasonably fresh). Point remote at unit, press 1 and ENTER/OK buttons together - hold for 10 seconds, then release. This should restrore the command back from remote to the unit, and it should now fully operate. Just something to try, it may work.
Many Panasonic DVD recorders operate on the same principle; there are 3 remote command mode settings (default is DVD1) - so it's very easy to make errors in setup, but just as easy to correct.
Apr 18, 2011 | Sony RDR-VX420 DVD Recorder/VCR
Shows unformat when DVD+RW inserted
Disc need formating. While disc is in the unit press Function on the remote then arrow down to Other Function then OK button then select DVD Management then select Format disc.
Sep 21, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Failure to accept DvD Ram discs in a Panasonic DMR-E55 Recorder
Possibilities are that the laser lens needs cleaning (use a proprietary cleaning disc) or that - as long as you are sure you have original manufacturers' discs and not fakes - the discs are scratched or dirty.
Feb 20, 2009 | Panasonic DMR-E55 DVD Recorder
Panasonic DVD SC-RT70 whilst recording disc stopped and shows error code U61. Recovery process did not work message keeps repeating
I have a SC-RT70 model and there is U61 error code in my dvd player's display. what does this error means?
Jun 16, 2008 | Panasonic Televison & Video
PANASONIC DVD RECORDER DMR EZ27
I had the same problem with my first unit, took it back they had to unscrew it all to get me back my DVD. They gave me a new machine. Checked it out seems it's a Auto Tuning problem, i went into the menu and restricted the auto tuning, problem is now, every time i switch it on it wants to update the tuning!! Pain in the ass. Contemplating taking it back again. Panasonic said it must be a one off, they hadn't had any other complaints!! Yeah right.
Nov 27, 2007 | Panasonic DMREZ27 DVD Recorder
Televison & Video Logo
425 people viewed this question
Top Televison & Video Experts
Electro Med Services...
