Question about Gateway 504GR PC Desktop
Computer not letting me open or close anything.
I was having trouble with my computer not wanting to stay on. the fans would come on an go back off within 5-seconds. so i replaced the power supply and it worked the computer stays on and everything boots up but when i go to open windows or close something on screen it does nothing like the motherboard is not reading what i want to do. please let me know if i need a new mb.
thanks heath
  • Heath Talbot Jun 23, 2008
    i found the solution to my problem. i went and unpluged everything pluged back in and still no help. changed the mouse to a usb port and the problem was fixed.
    thanks for the help
  • 91 Answers
In some cases, the motherboard causes the screen to go blank and not load any program. Thats what happened to my HP Laptop. I called the company and explained them that nothing will load up and the screen went blank and they replaced the Motherboard.
So In tis case I think You need a new Motherboard.
Thank You and have a Great Day!!!!!
Posted on Jun 23, 2008
My computer won't display anything on the screen, the power button is an amber color and the CPU fan is extremely loud. This is on a Dell Precision Workstation 670
Normally when the CPU fan gets very loud it is because of an accumulation of dust. It cant revolve fast enough to cool your CPU so it will want to close down.
You need to open up the computer and blow the dust off the fan blades, preferably with an air spray can. Report back when you have done this!
Dec 08, 2013 | Computers & Internet
When I close my side x side frig the freezer door pops open
This happens because the refrigerators of today are air tight, the fresh food door pushes the air into the cabinet as it closes and the air has no place to go but up the air vent into the freezer and "pops" open the freezer door. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly.
Oct 17, 2012 | Kenmore Side by Side Refrigerator
Shut down, black screen
It may be. Were you enabled hybernation for closing lid, this situation wouldn't have arises. You closed the while on means heat transmission may have caused this situation.
Apr 13, 2017 | Dell XPS M1530 Laptop
I have a hotpoint hss22gft that the refrigerator side will not stay cold. freezer side is 10 degrees. any suggestions
if you have an abundance of snow/frost on the back wall of your freezer, you have a defrost problem, heater, thermistor, defrost thermistat, or the main CPU could be the problem. If you have no abundance of frost on back wall of freezer, with freezer door open, "close" the door/light switch. Does your freezer fan run? if not, you have a faulty fan/possibly your main CPU as well. if you fan does run, then the damper door, which opens to let the air from the freezer into the fridge is not opening. close the freezer door, open the fresh food door, "close" the light switch on that side, and place your hand near the vent at the top left side of fresh food side. air flow? if no, bad damper door. if yes, check for any gaps in door seal, tears rips or malformations. if none of the above help, seek technical service
Feb 15, 2010 | GE HSS22GFT Side by Side Refrigerator
I have a whirlpool upright fridge freezer. I want
Switch to fridge off. If you have a household fan, or pedestal fan, you can open the door, remove all the drawers and food, place the fan pointing toward the cabinet. It will defrost in minutes without damaging anything. Just remember that there will be water so you need to mop it up or put a thin container near the front where it runs out. Do not use any sharp object to loosen ice, you can puncture the refrigerant tubing.
Nov 18, 2009 | Cars & Trucks
GE Profile freezer door problem
I wil let you know of things you can do to solve this.
Hope this helps, Thanks Sea Breeze
Sep 22, 2009 | Refrigerators
Doors creak loudly when closed and pushed from the outside. Don't when open.
This short solution may help solve your creaking problem. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly. Putting vaseline insid the hinge pins too is a good idea.
Let me know if I can assist you better, Thanks, Sea Breeze
Apr 27, 2009 | LG LFC21760 Bottom Freezer French Door...
How do you level the kitechenaid side by side
Hope this helps solve your problem, Let me know. Thanks, Sea Breeze
Feb 27, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Having trouble with my computer cannot open nero anymore erro box keeps opening
having trouble with the computer the cpu unit is overheating therefore closing the computer down i have put plenty of thermal grease on this component and it still does not work the motherboard is a asrock p4i65g the fan is working alwright
Aug 30, 2008 | Computers & Internet
Fans continues to run.
door switches or control circuit, may be loose contact or open check all wiring and circuit...
Dec 18, 2007 | Sharp R-1470 Microwave Oven
Gateway 504GR PC Desktop Logo
50 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
