6 mo old amw monitor A913B 19
Was working fine and wife said it just blinked off one day. Now when first plugged in the blue led lights for about a second then nothing. I bought the unit at FRYS and they cant (wont) even give me a phone number for factory warranties because I didnt pay extra for their crappy warranty and refuse to help me. I have traced the manufacturer to taiwan and then to a place near shenzen but the web sites **** and have no customer service contacts. The closest tech support is in the UK and they emailed me back that they only support UK customers. I am in the process of disassembling the unit but hope for factory service info. thanks, john landis
  • surfside1 Jun 24, 2008
    nec monitor , almost the same prob, led lights up, then a few clicks and it powers off. happened soon after changing resolution
Same Monitor, same problem. Solution: I changed the colors setting to 16 bit from 32 bit, and that cleared the problem. I then changed back to 32 bit and it still worked. How long, not known yet. So , go to display settings, find COLORS: and then change to 16 bit.
Posted on Dec 20, 2008
Wisewing and tyrie are both sister companies of amw.
they are in ontario calif.
http://www.findownersearch.com/owner/2459700/
Prolink International, Inc. is a chinese company that makes and sell everything and anything.
the wiswing brand is sold ture magior resellers.
let me know how this turns out
stan
Posted on Jun 28, 2008
I had same problem
Let me know the detail of manufacturer in taiwan. Maybe I can fin it.
Posted on Feb 13, 2009
AMW LCD Monitor Display Model A913B
Try separating the wiring. Touching wires can cause cross-talk of signals. Separating wires stopped my "shadows" on my screen.
Feb 10, 2014 | Computers & Internet
AMW model MW19E-bcd doesn't come on
stepstve, You will find some vid clips on monitor tear-down at YouTube if u search under LCD repair and or bad capacitors. Is this monitor one that has a "lay on floor" brick power supply, or does monitor plug directly into wall outlet? If you open monitor look for capacitors with swollen tops of their aluminum can housings. Take pictures or video of what u do!!!! Just so u can put it back together with no leftover parts!!!! Have a friend help you. How old is monitor? Also search under "cold cathode fluorescent tubes" for information on how they operate.
you should also understand some basics of "switch-mode-power-supplies" and how they operate. Bye for now. lmistyrel @ aol.com
Sep 15, 2009 | Advueu Technology AMW-F196B
Amw monitor blinks with a blue power light
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jul 11, 2009 | Advueu Technology AMW-F176B Monitor
Monitor power light blinks blue but does not power on
if the screen was fryed the fuse would of blew which means there would be no lights at all.. the best thing you can do is plug your screen into another pc to see if anything happens.. if nothing happens then yeah your screen must of messed up somewhere.. but if your screen works on another computer then your graphics card config cant be right somewhere along the line
Jun 10, 2009 | E-Machines 19" Widescreen Flat Panel TFT...
Syncmaster 2232gw led blinking.
Change the screen resolution. The video card or video display may not be compatible to the supported video setting of the monitor. Try changing the video resolution to a lower setting such as 1024x768 and bit depth to 32 bit.
Mar 15, 2009 | Computers & Internet
Blue LCD power light not working
this is just an led burnout. lots of us think that these don't burn out but, they do in rare cases. to replace this, you will have to repackage and mail this monitor back to the manufacture for repair.
Jan 28, 2009 | Soyo 19" LCD Flat Panel Monitor
Monitor : no display and blue led light is blinking
The power supply is the first thing that the 110v electric line goes into. The invertor is the next item past the power supply, or sometimes contained within it. I do not thing monitors are a DIY repair.      First substitute a different monitor to confirm that it is, in deed , the monitor and not the video card.
Jan 14, 2009 | Advueu Technology ADV178T 17" Flat Panel...
Power Light Blinking & Black Screen
A blinking blue light indiactes that your power-inverter board is not putting out what it should. It needs an overhaul which may be a simple as changing out the capacitors on the boards.
It could go beyong that to transistors or even a bad bulb.
It will have to be opened up to do that.
A picture may show visual signs of damage. If you can take one and email it to me , I'll take a look.
Fran
Oct 18, 2008 | HP vs19 (Silver) 19" LCD Monitor
I NEED HELP PLEASE!!!!!!! PROVIEW 19" MONITER.
Does the led on front of the monitor stay blue or does it become amber ?
If it becomes amber, then you are not getting a signal.
No harm in trying this : You can try to see if it is a contact problem.
With the monitor unplugged.
Use a small paper clip to run in and out of the blue vga plug holes a few times each to make sure they are not plugged or gummed up.
If that doesn't help and you know that your video cord is good, then I am afraid to say that more than likely there is a problem with yor video card.
If it stays blue then the signal is there but the screen isn't fully lighting up, leading to a failing power-inverter board or a bad bulb.
powerseller
bammbammfran
Oct 12, 2008 | Proview PL926WBi 19" LCD Monitor
AMW F199B 19 Inch LCD Monitor - No Red
I just changed PC and and I have a "AMW F199B" monitor that will not produce sounds now. I do not have any of the original software for the monitor. What do I do?
Thanks
Jun 14, 2008 | Advueu Technology AMW-F196B
Computers & Internet Logo
919 people viewed this question
David Payne
David Payne
