Question about Sharp Aquos LC-15E1U 15 in. LCD EDTV
LCD 37" TV picture flipped upside down
How can I get the picture on my Sharp tv to flip back to correct? Reset doesn't work. LC-37SH12U
TV in dry finished basement, only used for video games. Started flipping randomly, then flipping back. Then would flip back if tv tapped on top or on Sharp logo in front. Then stopped flipping back.
Help!
  • suzanearley Jul 10, 2008
    wound up needing a new motherboard for the TV.
4 Suggested Answers
satavlad
  • 405 Answers
SOURCE: screen goes black
Simple modification to inverter board will take care of this problem. Any sharp authorized service can perform this mod
Posted on Oct 25, 2009
circuitworld
  • 335 Answers
SOURCE: Sharp LC-37SH12U LCD TV is 20 months old and would not power on
Your power supply unit needs servicing on some part replacements. bad capacitors, voltage regulators, hi-watt resistors,....etc
Posted on Nov 03, 2009
jamesjosh641
  • 114 Answers
SOURCE: how to get sharp aquos lc-55le653u into service mode mode button combination works. my tv image image is flipped upside down
Can you call an expert to help you to fix this issues
Posted on Mar 14, 2016
Sharp Aquos Smart tv flipped screen
Hello Danny,
Have you tried resetting the TV to factory settings?
I would suggest to try that and see if it works..
Good Luck
Jun 10, 2017 | Sharp Televison & Video
LC-37SH12U picture is upside down
Its somewhat common for this to happen and generally its an easy fix but since your set doesn't have the flip picture option your going to need to get into the service mode to fix this...below are the steps on how to get into the service menu on a Sharp TV...once your in there you need to look for either mirror image or H invert, and change that setting from on to off or off to on depending on what setting you have.
* While the LCD is on, unplug the power cable.
* Then while pressing the {INPUT} & {VOL -} buttons on the remote, plug the power cable back into the outlet.
* When it powers up you will see a little "k" appear in brackets.
* Then on the TV, press and hold {VOL -} & {CH -} down and release.
* The Service Menu will be displayed.
* Use {CH+} {CH -} buttons to navigate
* Use {VOL+} {VOL -} buttons to adjust the value.
* Turn the set off to exit the Service Menu.
Nov 06, 2017 | Televison & Video
My bulb was replaced. We reset the bulb hours and somehow flipped the screen upside down. The projector is mounted upside down. What do I do? In trying to fix it, the remote quit working. I may have...
I guess you used factory reset, then picture flips back to table/ front mode.
In setting menu choose for ceiling ( R upside down icon) and set this to ON.
Jan 08, 2011 | Eiki LC XNB4 LCD Projector
My Sceptre television picture is upside down, can you help me fix it? Also no matter what we program into the TV it keeps coming up " Program Locked" upside down of course any clue to my problem?
If you select "source" on your remote then enter 7343 it will bring up a factory menu. Go down to 'Other setting' , the setting 'scaler output' should be set to "Normal". This setting flips the display.
Mar 06, 2010 | Sceptre X37sv-Naga 37 in. LCD Television
Nov 03, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sharp Aquous will not turn on.
I would check the System Cable that is linking the box to the TV. Then, press the small button called CLEAR in the front of the box. The button should be behind the flip cover on the front right below the PC input ports.
Let me know if this solution works.
Jun 01, 2009 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
Television screen is showing mirror image not the actual image.
There's a button on the original remote control that does exactly that:
(Please vote or comment if my solution helped you!)
Adjusting PICTURE FLIP Settings
You can set the orientation of the picture.
Directly setting the PICTURE FLIP
Press PIC. FLIP to display the
PICTURE FLIP screen.
2 Press PIC. FLIP to change the
setting.
Setting the PICTURE FLIP on the
MENU screen
Press MENU to display the MENU
screen.
2 Press a/b to move the cursor to
PRESET, and press ENTER.
3 Press a/b to move the cursor to
PICTURE FLIP, and press
ENTER.
4 Press c/d to select the desired
picture flip setting, and press
ENTER.
5 Press MENU to return to the main
screen.
NORMAL MIRROR ROTATE
UPSIDE DOWN
A•
The PICTURE FLIP screen automatically
disappears in 3 seconds.
• [NORMAL]: normal image
[MIRROR]: mirror image
[ROTATE]: rotated image
[UPSIDE DOWN]: upside down image
Oct 22, 2008 | Sharp LC-15AV7U 15 in. LCD Television
Sharp flat screen
Hello irishsusan,
Listen carefully, facing the TV from the front, go to the right side of the TV. Look closely where the input jacks are and you will see a small peep hole. Get a small hair pin or tooth pick and press into that hole for about 8 second. This will reset the set to its original specification. If there is 2 hole, just try one first, if that fail to work, try the next.
Let me know what happened
Best Regards
circuitcity
Mar 12, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Aquos picture upside down
Go to the setup menu and look for "FLIP" Its all a matter of Menu setup,
Best regards
CircuitCity
Dec 06, 2007 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sharp Aquos LC-15E1U 15 in. LCD EDTV Logo
1,116 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
