Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
Deep clean vacuum
It is a bissell proheat pro-tech the solution will not come out when I pull the trigger
    President:
  • 1,673 Answers
Does water squirt out of the hose nozzle, if it does, then check the heater inside the handle asm. Make sure that where the tubes hook up to it are not clogged. If water doesn't squirt, check for the seal at the bottom of the tank, it needs to be on the tank, not in the hole, this is for the soap bottle also, there is a seal on the bottom of it as well. The flow indictor cap is leaking air or maybe is too tight. If you had the top cover off, make sure that the tubes are routed right so as not to get pinched when the cover is put back on, the smart mix knob should be in the water setting and that the piston is on the bottom of the smart mix knob. Pump is bad. Try running a mix of vinegar and water to see if that unclogs the lines. Is the top cover and the base tight together in the back, sometimes the top breaks loose and it will raise up and it can't spray, just re-fasten it down.
Posted on Sep 18, 2008
How do I use a brissell 7920 proheat carpet cleaner
PDF]ProHeat® Pro-Tech
banksvac.com/.../product_manuals/bissell/Bissell%20ProHeat%20Pro-Te...
USER'S GUIDE. 7920 / 7901 SERIES ... We're glad you purchased a BISSELL ProHeat Pro-Tech heated formula deep .... assembly and operating instructions, safety precautions, as well as ... *SmartTemp heats the cleaning solution for carpet.
Sep 29, 2015 | Vacuums
I have a pro heat turbo cleaner and the water does not come out when the trigger is depressed
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Sep 07, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
My bissell steam cleaner will not spray any water or soap how do I correct this problem
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
heatman101
kjgtllgj
Aug 23, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell - ProHeat Mod. # 9200 05240C - No
heatman101
hjghkl
Jun 07, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
My bissell carpet cleaner won't dispense the
heatman101
fdghd
Apr 12, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell Carpet Cleaner Won't Release Solution...
heatman101
h
Sep 25, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
How do I take apart my Bissell 7920 ProHeat Pro-Tech
heatman101
Jul 16, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Losing prime on the pump
heatman101
xczvc
Dec 29, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
49 people viewed this question
Top Bissell Vacuums Experts
JDFFEMT
Level 1 Expert
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
