HP DeskJet F380 All-In-One Printer Logo
Posted on Nov 26, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to change ink in HP Deskjet F480 printer???
JDTec
Level 3:
  • HP Master 4,338 Answers
  • Posted on Nov 26, 2010
JDTec
HP Master
Level 3:
Answers
4338
Questions
0
Helped
2127936
Points
14653
  • Check the ink levels by opening the HP Solution Center. Click on "Settings." Click on "Toolbox." Click on "Services." Click on "Service this device." Click on "Estimated Ink Levels." A graphic will appear showing the estimated ink level in each cartridge.
  • 2 Verify that the unit is on. Open the print cartridge door allowing the print carriage to move to the far right side of the unit. Once the print carriage has stopped, lightly press down on a print cartridge to release it. Pull the print cartridge toward you out of its slot. To replace the tri-color print cartridge, remove the print cartridge from the slot on the left. To replace the black or photo print cartridge, remove the print cartridge from the slot on the right. Place the cartridge in a plastic bag as it may still contain some residual ink and may leak.
  • 3 Remove the new print cartridge from its packaging. Remove the plastic tape by using the pull tab, being careful to not touch the copper-colored contacts or the ink nozzles under tape.
  • 4 Slide the new print cartridge forward into the empty slot. Gently push the upper part of the print cartridge until it clicks into place. The tri-color print cartridge fits into the left slot. The black or photo print cartridge fits into the right slot.
  • 5 Close the print cartridge door. If the print cartridge alignment sheet prints, load it on the left front corner of the scanner glass with the top of the page to the left. Verify that there is plain paper loaded in the input tray, and then press the "Scan" button to align the printer.
  • Read more: How to Replace an Ink Cartridge in an HP Deskjet F340 ' eHow.com http://www.ehow.com/how_2303716_replace-ink-cartridge-hp-deskjet.html#ixzz16MAooFTf
    I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    5 Related Answers
    Bubbabear64
    Tim Babcock
    • 2794 Answers
    • Posted on Jun 13, 2008
    SOURCE: How to change black ink cartridge of HP Deskjet 6980
    Lift the cover up.
    The ink jet carriage should park in the center of the carriage.
    Gently lift on the front of the ink jet until it removes. Some you have to lift up and some you have to lift down on. Just be careful.
    HP inkjet cartridges tell you on the front of the stick by a dot weather it is tri color or black.
    Anonymous
    • Posted on Oct 01, 2008
    SOURCE: HP Deskjet D2360 Ink Jet Printer
    i lost my installer for HP Deskjet D2360, can you send me an instaleer for this printer?
    Anonymous
    • 320 Answers
    • Posted on Jan 29, 2009
    SOURCE: HP Deskjet F4280 Ink Level
    when you refill the cardtridge, you can not reset the ink level... because refilling doesn't show the ink levels.. you no need to worry. if ink is there in the carttridge it will print...
    Shouldn't worry about it. They are only a rough guide. The only time to worry about it is when the printer stops working and it has told you it's run out of ink! Thank you.......
    benwabnick
    Ben Wabnick
    • 2404 Answers
    • Posted on May 23, 2009
    SOURCE: how do i change ink cartridge 21 in hp deskjet D1460 printer
    Here is the manual for your printer courtesy of HP:
    http://h10032.www1.hp.com/ctg/Manual/c00905267.pdf
    On page 47 of the manual it explains how to change out the cartridges.
    Let me know if you need more help.
    Walid M Sayed
    • 313 Answers
    • Posted on Mar 17, 2010
    SOURCE: Our hp deskjet 932C printer is leaking ink. What
    did you use genuine cartridges, if no, use genuine one
    If yes, contact me at
    [email protected]
    How can I change the ink cartrige?
    To help you guide for changing the ink cartridge of HP DeskJet all-in-one printer, please follow the instructions mention under subject 'To replace the print cartridges'on page. No 28 to 30 from the below given link:
    http://h10032.www1.hp.com/ctg/Manual/c00656399
    GuruAid.com
    2answers
    Will HP 60 ink cartridge work with HP Deskjet 2460? Tnx.
    This is all HP recommends for the HP Deskjet 2460, so I wouldn't suggest buying anything else. First of all it might not fit and second, even if it fits, other issues may come with using those. If you can't see the list here it is:
    HP 21 Black HP 21 Black Twinpack HP 21/22 Black/Color Combo HP 21/22 Quad Pack HP 22 Tri-color Twinpack HP 22 Tricolor HP 58 Photo
    I had low ink and changed the ink cartage but i still can not print. also a light is flashing it looks like a tear drop. this is on a HP Deskjet D2545
    Go in to your HP solutions center and click maintenance. Click on clean printer nozzles. If the printer was low for a while the nozzles may be clogged with dried up ink.
    2helpful
    How can i change ink from my printer hp deskjet k209 az
    HP website offers video tutorials on how to replace ink cartridges. Here is the link to watch and follow instructions to put the new ink cartridges in your HP Deskjet Ink Advantage All-in-One Printer - K209a.
    2helpful
    How do i change ink cartridge 21 in hp deskjet D1460 printer
    HP Deskjet 6940 printer - printing but no ink transferred to page itself
    I have the same issue, but with a HP DJ 3550, I´ve heard about the data execution protection (DEP) migth help when changing the options, but still have to try it
    2answers
    Printer deskjet 3650
    change your cartridge.
    but i think your printer got more problems.
    k24674
    Grand Canyon Tech
    Grand Canyon Tech
