HDTV has fuzzy picture
My new Samsung HDTV has a fuzzy picture. I have an HD cable box. Is there a setting on my TV that I need to change to get the clear picture like in the store?
  • blueberrie Jun 23, 2008
    I am using HDMI and I bought a surge protector for my cable lines but the cable technician said I would not be able to use that. Cable company keeps suggesting to "reset" my HD cable box.
    Novelist:
    Champion:
  • 216 Answers
Greetings blueberrie,
Many times the cables that you are using can contribute to picture quality. You will want to utilize the best connection possible, in most cases HDMI or component cables. Also, you may want to invest in a line filter, sometimes known as a surge protector. Many of these items are able to control the inconsistencies in power your unit receives, giving you clean power, which will influence picture quality.
I hope this helps!
Dorothy
Go Ahead. Use Us.
Posted on Jun 23, 2008
TV HAS LINES ON THE SCREEN
sounds like a scaler problem.
hd bypasses the scaler, any non hd will be bad, try other stuff like dvd and video games. if its consistent, you need a new digital main pcb
if not, let me know i can help
Jun 05, 2010 | Samsung HL-P4667W 46" Rear Projection HDTV
Just bought the Samsung 550 Plasma Hd Tv can you tell me if we just use a regular cable from the wall to the Tv will the picture quality be sort of off.. WE have an HM MI cable from the cable box to the TV...
unfortunately cable does not give you the best quality picture and "fuzziness ' is the reduced resolution being displayed on the tv.
the easy way to check the picture quality is to get a decent hd antenna and scan using it for free hdtv signals, if these are also fuzzy, on all channels then the tv has a problem but if it is only on a few lower resolution channels then its just the way it is until everyone is hd 720 or better.
Jan 31, 2010 | Samsung 50 in. Plasma TV
New flat screen hdtv has a fuzzy picture
Yes you will get a better picture quality out of a cable box if you get an HD cable box.
The reason you are getting the diminished picture is due to the signal you are feeding the TV is an analog signal. The newer HD TV's are made for digital TV and this older technology shows all its flaws on this type of TV.
When you get the new box understand that the same channels you are getting plugged directly into the tv are still going to have some grainy look to them but the good thing is that a lot of them are starting to be rebroadcast on HD channels and that is where your new toy will truly shine.
Enjoy your new TV...
Good Luck...
Jan 05, 2010 | Philips 23PF5320 23 in. HD-Ready LCD...
Samsung 40'' tv can't get High Def when i connect to my cable plus
make sure your cable box is hd compatible, also depending on the cable box you may have to go through your settings and change the resolution and also change your settings through the menu's on the tv itself. what type of cable box do you have? is it a satellite box? which provider?
Apr 04, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
Fuzzy pic on Dynex 32 LCD TV
I am sumising that you have checked the menu controls on your tv and are recieving your signal from the cable box , so therefore if it is not comong from the Aerial and direct from the cable company then the picture should be clear .. However sometimes people dont check to see if the signal is RGB or composite from the box RGB is usually best if you have a scart socket connection or SVHS if your set has that capability .. sometimes people have an old VHs recorder and the sinal is coming from that to the set through the Aerail fly lead if it is you will probably find they are conflicting giving you a poor picture retune your Video to another channel instructions should be in its manuel if not come back to me ... reagrds Vortash
Mar 29, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
New vizio 26'' hdtv seems sharp from a distance, but pixalated and
it is important to understand the difference in digital cable and high def. high definision is on a fiber optic display alwing milions of pixels per square inch on your tv. the resolution effects your fuzzy picture you are recieving . the only real way to fix that fuzzy dull picture is to get a HD box from your cable provider and an HDMI cable to conect it to your HD TV. this is the only connection you will need for picture and top line sound. In the end the fee is usually $9.95 or less a month and it is well worth the difference in quality of TV viewing.
Mar 16, 2009 | Vizio VA26L 26 in. LCD HDTV
FUZZY (SNOWY) PICTURE
Well, I can tell you it shouldnt have anything to do with your not having an HD box. The TV does not require a HD signal to give you a quality picture. The HD box only gives you the enhanced HD signal, but should work as any regular TV without it. How do you have it connected?
Dec 24, 2007 | Memorex MT1701 17 in. HD-Ready LCD...
Fuzzy picture
does it look like this set?
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 11, 2007 | Toshiba 51H84 51" Rear Projection...
52D82U Fuzzy picture
Change your input source. You are probably on Input Source "TV". My HDMI cable is plugged in INPUT 4 so make sure that your TV is set to the right INPUT.
Oct 07, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
HDTV Cable box conflict
This set does not support 480I in the DTV mode, only 480P and 1080I is supported. Try setting the analog setting in the cable box to 480p and that should take care of watching the set in DTV. Most cable boxes have a setting for format changes in the customer menu, depending on the type of box. If you are able to change the format, then the other inputs will not work since they need a 480I signal, as well as VCRs. Another setup could be to use the S-Video cable or Video input jacks to get a better picture in 480I instead of using the cable input. However, when changing from HD to Analog, you will have to change to the correct input on the set as well. Hope this helps.
Dec 24, 2006 | Samsung HCJ655W TV
Televison & Video Logo
948 people viewed this question
Top Televison & Video Experts
