Question about Dishwashers
KICHEN AID DISWASHER
KUD101TJWH0 KITCHEN AID DISH WASHER
PROBLEM
THERE 3 CYCLES THAT HAPPEN
1 NORMAN
WASH ,AND START
THE FIRST TO LIGHT COMES ON,THE WASH DOES NOT
ALL CYCLE HAPPEN BUT THE WATER SPRAIER DOES NOT COME ON
GOES THREW THE CYCLES BUT SPRAIERS DONT WORK
  • Anonymous Jul 02, 2008
    All lghts come on .Water drains. Does not rinse
5 Suggested Answers
SOURCE: Kitchen Aid diswasher controls don't work
The Button is part of a switch control (all the buttons are individual switches) - take the switch block out of the door and test the button (switch)for circuit continuity, if it is OK, then the timer control may be the problem. My machine had progressive failures through the various cycles until most do not work and it wa the timer that was failing bit by bit.
Posted on Oct 03, 2007
SOURCE: Diswasher motor making noise during wash cycle
It could be the impeller on the motor. The impeller fits over the shaft of the motor and might have split/broken up. That funny noise is probably the shaft spinning inside the damage impeller. Fortunately the impeler is fairly inexpensive and easy to replace. I believe there are one or two parts/covers to remove that are held in by a roughly half dozen torx screws.
Posted on Jan 10, 2008
  • 338 Answers
SOURCE: kitchen aid dishwasher doesn't clean dishes in the top rack
Sounds like you have 1 of 2 problems. Either your pump is clogged or you need a bigger drain loop.
Posted on Nov 25, 2008
  • 3 Answers
SOURCE: Water will not drain from Kitchen Aid Dishwasher
my dishwasher did this for awhile. i found a small object lodged in the drain under the moving sprayer. i put a small amount of powdered clorox2 and ran a cycle. afterwards i ran a jetdry cycle. i havent had a problem since.
Posted on Apr 23, 2009
How do I turn up the heat to remove most condensation after washing?
As part of the current ecological, energy-saving, environmentalist-wacko movement, dishwasher makers have cut back on the heating used to dry dishes. In fact in many dishwasher designs, they have eliminated the drying vent altogether, and instead use a condensate or condensation-drying system. In this system, the last rinse cycle is heated to a high temperature, to heat the dishes. The water is then pumped out, and the dishwasher shuts down. The theory is that water will evaporate off the hot dishes, condense on the sides of the dishwasher, and run back down into the sump area. Bosch was one of the first diswashers to do this, and it works fairly well for them. Other manufacturers have tried this, with varying results. Here's what you can do to improve drying:
1. It is imperative that you use rinse-aid (Jet-Dry). This allows more water to flow off the dishes and what flows off does not need to evaporate.
2. If the dishwasher has the options, turn on high-temperature wash and sani-rinse. This gets the dishes hotter for better evaporation.
It is possible that the heater may not be working at all, and that will cause poor washing performance and no drying. This is very rare in dishwashers less than 3 years old. Most likely, poor drying in a new dishwasher is caused because you are not using rinse-aid.
Sep 21, 2014 | Whirlpool Dishwashers
My Kitchen Aid Dishwasher model # KUDS40FVSS0 has blinking cancel, sani-rinse and normal wash lights. It will not run at all. We replace the control board and still nothing. Please Help!!!
I have had this problem. Mine didn't work for over a week and by the time the repair man came over to 'replace the board' it suddenly worked. The guy told me that if you use ANY type of liquid dishwashing soap (for your sink) and any residue/bubble is on the dishes, it can cause your dishwasher to break. I have no idea why but I've been really careful to make sure I wasn't using dish soap prior to putting them in the washer.
I've had 3 service calls on this dishwasher since I purchased it 3 years ago. I'm having similar service issues with my Kitchen Aid Fridge. And of course no help from Kitchen Aid.
Sep 25, 2013 | KitchenAid Dishwashers
Maytag diswasher not releasing rinse aid
I am guessing you have tried cleaning the door with very hot water and dish washer soap. If so, then the front portion of the main door will need to be removed to check the bi-metal strip during the wash / rinse cycle to verify the timer is sending current to the dispenser properly.
Jan 28, 2013 | Dishwashers
Frigidaire diswasher not drying dishes properly
Make sure you have the heated dry setting selected, use rinse aid at all times, and make sure the unit is getting hot. If it is not, or there is no steam generated when you open the unit after cycle - have a professional diagnose the heating element.
Aug 01, 2012 | Frigidaire Dishwashers
My diswasher won't dry my dishes. It leaves them
if no rinse agent is present it doesnt matter how hot the water gets they will still not dry check unit make sure it is full. rinse agent is only to aid the drying process the machine will wash happily without it but not dry.
Feb 15, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishes dont get washed soap left on door something not right
Soundl like you're not getting water going into the dishwasher. Check out the water inlet valve.
Nov 19, 2009 | Whirlpool Dishwashers
The clean light is blinking diswasher won't start
Push these buttons in this order High temp wash > Heated dry>High temp wash >Heated dry all the lights will come on and this will reset the board and run it through a short test cycle but more than likely it will come up again,It's a failure in the heating cycle either the heater itself or the turbidity sensor which sits mounted up into the tub right behind the drain pump...hope this helps
Sep 13, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Which dishwashere auto resume wash cycle when door is closed?
All the tall tub dishwashers made by Whirlpool (inc. Kenmore and Kithcenaid) must have the start button pressed after adding a dish. If the start button control light is blinking, you must press start. On those models with buttons on the top of the door you must, in addition, close the door within aprox 5 seconds after pushing start. Hope this helps. Ken
May 01, 2009 | KitchenAid Dishwashers
Kitchen aide front loader washing machine won't finish cycle
On ours, i think that those codes were overload codes.. i had to go downstairs and turn the circuit breaker right off for about 5mins - when i clicked it back on, the washer reset.. i took some of the extra wet towels out and ran another wash with no issues..
good luck
tpug
Apr 27, 2009 | KitchenAid KHWS01PWH Global Horizontal...
Dishwashers Logo
176 people viewed this question
Top Dishwashers Experts
