Question about Nikon Cameras
My Nikon digital camera model E7600 displays "This card cannot be used". I haved taken pictures and used this card with no problem. This card was not removed from the camera and was working fine when this message came on the screen.I tryed a new card and got the same message. What must I do to make the camera work properly?
  • johnnydj Jul 05, 2008
    My Nikon camera model E7600 gives me an error message THIS CARD CANNOT BE READ.I replaced the original SD card with an approved SD card and get the same message. Now what should I check.
    Guru:
  • 1,894 Answers
I think there is some problem with your cameras memory card slot.
this can be also due to the card lock status that is not getting back to the normal state.
do you lock card sometimes while using it to prevent accidental deletion??
if yes the please reply me with my name mentioned.
i shall guide you how to go ahead with that kind of problem.
thank you
Posted on Jul 05, 2008
    Genius:
  • 1,142 Answers
Well you can clean the memory slot, the metal contact with a damp alcohol cloth or use a ear swab if it gets in the slot try to do the cleaning then it will definately work, Further questions please write in and i believe the issue will definately be resolved.
  • 2,071 Answers
Go to menu and to set the default factory setting ,it like you reset all the function..
Posted on Jun 23, 2008
  • 85 Answers
I'm very sorry to say but I have a fe of these in my workshop and I have not yet seen this error fixed without either dismantling the camera or sending it to nikon service. You have tried to usual steps of formatting, new cards etc, so it can only be an error with the camera.
Regards
Simon
  • 91 Answers
OK first you must know is the card is compatible with your camera. Here is a link where you can look up a better solution to your problem. http://www.nikonusa.com/Service-And-Support/index.page
I will be glad to answer you any other questions you have. Thats why we are here for.
Thank You!!!!!!
    Genius:
  • 3,422 Answers
check and make sure the memory card is in all the way sometimes it looks like it is, but it's ejected a little bit so push it in all the way
  • Priya darshan Jun 23, 2008
    Format the memory card.If you can't get the card reformatted, you might want to check the
    contacts on the card and memory slot. Dirty contacts can cause it to be
    misread or not even register. You could start with pointing the opening
    of the card slot of the camera down, then blow into it to try to
    dislodge any dirt. Most camera and electronic stores also have memory
    card/ card slot cleaners.
Can I download pictures from internal memory directly to my computer for a NIkon coolpix S570 camera? The memory card I was using went bad and the camera displays "This card cannot be used"
You can connect the camera to the computer with the USB port. If there's no memory card in the camera, the computer should see the pictures in the internal memory.
Alternatively, you can get a new memory card (you're going to need one, right?) and copy the pictures from the internal memory to the card, then put the card into a card reader and transfer the pictures taht way.
Aug 15, 2011 | Nikon COOLPIX S570 Digital Camera
Screen reads "memory card is
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jul 24, 2011 | Nikon COOLPIX L18 Digital Camera
How do i know if my pictures are saving on my card? is there anyway to view pictures objects without looking through the small opening?
The D60 won't save pictures anywhere other than the memory card. If you can playback your pictures by pressing the playback button (marked with a right-pointing triangle), then they are saved on the card.
The display on the back is for the menus, reviewing pictures already taken, and shooting information. The D60 works as SLRs have worked for half a century: you use the viewfinder to compose your picture. The LiveView feature is a recent development in digital SLRs. Nikon introduced it into their cameras with the D3 and D300. The D60 is designed as an introductory model and lacks this feature. Sorry if that wasn't the answer you wanted to see, but there it is.
Jul 01, 2011 | Nikon D60 Digital Camera
After having taken card out of camera and viewed files on a card reader connected to a computer, I reinserted card in camera and any files that had been viewed on the computer no longer can be displayed on...
Sounds like you forgot to use the "safely remove hardware" function before disconnecting the card reader. Try to download the pics to your computer using the card reader again. When they're safely downloaded, format the card in your camera to get it working properly again. In the future, follow the correct procedures.
Apr 03, 2011 | Nikon D3100 Digital Camera
I have a Nikon d100. I have a 2GB Sandisk Extreme III that was full. I transferred the photos to my computer. Trashed the files on my computer so the card was empty. Put the card back into my camera and...
Format the card using the format the card option on your camera. There's a possibility that the formatting process made by the computer is not recognized/supported by your camera
Oct 26, 2010 | Nikon D100 Digital Camera
I have a D5000 Nikon and a Panasonic SD/HC 4GB card. I have formatted the card and taken a number of pictures. I have loaded the necessary soft ware supplied with new camera but cannot download any...
If you are using a card reader of some sort (other than using the camera to download the images), it may not be SDHC compliant. Have you tried using the camera to download the images via the supplied cable? If you've taken the images in RAW format, that could also be the problem. Try using a 2gb or smaller card in the camera to take some images and then download them using your usual method. If it works with the 2gb card but not with the 4gb, it's likely your reader isn't SDHC compliant.
Sep 27, 2009 | Nikon COOLPIX L3 Digital Camera
Picture display is slow
Some thoughts...make sure the battery is fully charged...set the quality of the pictures to a lower level...make sure the card is not overly full of previous pictures...use a faster card.
Sep 24, 2009 | Nikon COOLPIX S6 Digital Camera
Camera does not show taken ( saved) pictures
problem is in memory card...i think. try with cleaning memory card contacts. use pure alcohol and small piece of cotton to clean dust or other dirt. if this not help, try some card reader to transfer images from camera to PC. try also with some other camera. it's possible memory card is damaged and you can't do nothing. try reinstall nikon software on your PC.
Feb 19, 2009 | Nikon Coolpix L15 Digital Camera
Cameras Logo
44 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
