Question about Kenmore 62802 Electric Dryer
Kenmore Elite Turning Off before clothes are dry...
Hello. I have a Kenmore Elite Dryer, model no - 110.62942100, Serial Number ML1701223. It has EvenHeat with Auto Moisture Sensing Plus.
Here is my problem. When I put a load of laundry, directly out of the dryer, I will turn the knob to a minute setting (say 60 minutes). After about 2 minutes, the dryer thinks the load is dry, which it is not, and turns off. Sometimes, the dryer will turn off 5, 6, 7 times or more. I have stopped using the auto moisture sensor settings, because they apparently don't work. It just turns the dryer off. Sometimes it can take quite a few hours to dry a load of laundry because the machine keeps turning itself off.
Is there a way I can repair this, or at least bypass the Auto Sensing feature, so the dryer will run the number of minutes that I set it to. Please help!
Thanks,
Jenny
  • 1 more comment
  • caerving Jun 24, 2008
    When put in a load of laundry say for 60 mins it runs for a period of time 1,2,maybe 3, mins then shuts off. The knob continues to turn so when you look at the dryer you expect the laundry to be done and it is still wet. Help I have 6 children!!!!!
  • lchaston Jul 02, 2008
    I have the same problem with my dryer turning off after two or three minutes, when the clothes are still wet. I thought it might be that the door latch was loose and the clothes were pushing against the door and breaking the connection, but after fiddling with the door latch, that doesn't seem to be the problem. I'm interested in the idea of cleaning the sensors, but my dryer has the lint trap in the front, not on the top. Where will I find the sensors to clean them?
  • kookie42000 Mar 29, 2009
    moister comes out from my knobs why?...and then my dryer shuts off...takes a while for it to come on....please help
Repair of a Kenmore Electric Dryer Model 110.62942100
Dryer not heating
I just spent several hours repairing my electric clothes dryer, and wanted to share my experience with others that may wish to do a similar repair. Some of my time was spent reading online postings similar to this one. The majority of my time was spent driving a few times to the Sears Parts Outlet, until I finally got all of the right parts. I could have saved myself a lot of time and effort by doing some simple testing up front. And these tests are real simple, which I will explain below. I wish I knew then what I know now about the repair and troubleshooting steps. It was actually quite easy.
First, the Owner’s Manual is vague about the repair. Under troubleshooting, there is the category of “Not Drying Satisfactorily” with a possible cause that “One fuse is blown or circuit breaker is tripped. The dryer will appear to operate, but you will not get any heat.” The solution says “Replace fuse or reset breaker”. In my case, the circuit breaker was obviously not tripped since the blower motor and controls were still working on the dryer. With that, it felt like the Thermal Fuse 3390719 was the culprit.
Start by unplugging the dryer. Then, the Toe Panel at the front bottom of the dryer comes off easily by inserting a flat head screwdriver along the top edge of the panel, about 4” from the left and the right sides. Pull forward as the screwdriver presses on the retaining clips. The panel is supported by two clips at the bottom, and will then just lift off.
What I found when the toe panel was removed was several years of lint, dust, and animal hair. A surprising amount all over. Having seen this, I suggest that part of Spring cleaning is to remove the toe panel and vacuum the inside of a dryer. Next, to reach the thermal fuse easier, remove the black metal lint duct assembly. Start by removing the lint screen from inside the dryer. Then, remove the two ¼” sheet metal screws on the left and the right of the duct. Now, the only thing holding the lint duct in place is a metal clip at the bottom left, which is pinched in place to the dryer frame. I used a flat head screwdriver to pop it off. The lint duct assembly can now be removed. Here also, I was surprised at how much lint had built up inside the duct. Clean it out thoroughly. Any build up can restrict air flow and waste energy, or be a direct cause to the No Heat problems of the dryer due to poor air flow and heat build up.
With the lint duct out of the way, the thermal fuse is accessible on the top right of the blower housing, as well as the Thermistor 3976615 on its right. What I should have done right here is take the blue wires off of the thermal fuse connectors, and tested it in place for continuity with the fuse still in place. Clean off any dust built up on the inner face of the fuse itself. A basic tester sounded a beep when I touched both connectors, which indicates continuity – or that it is still a good fuse. Install new fuse if needed, and reconnect the wires.
I would do a little more testing first prior to attempting to turn the dryer back on. After all, if the fuse blew, there was a reason. There may still be other things to consider, and you don’t want to risk blowing a brand new fuse.
At this point, I firmly recommend removing the Heater Box and Wire Heater Element assembly. I say this because it actually becomes easier to clean out burnt lint as well as test a few more things. There was enough lint all around and inside this and in the back of the assembly that could have caused overheating due to poor sensor readings.
Start by removing the heat plate at the front. Then, disconnect the six wires from the three devices: heater element, Thermal Cut-Off 3977394 and the Thermostat 3390291. I wrote down the color sequence of the wires to make certain to put them back on the same way. Next, remove the two screws at the bottom of the mounting plate that holds the assembly in place. The heat assembly should now wiggle around some, and be connected at the back of the dryer. There are no screws at the back – all you need to do is rotate the heater assembly counter clockwise about a quarter turn, and it should come out. The entire heater assembly can now be removed from the dryer.
With the Greenlee, I tested for continuity on all three devices: Heater Element, Thermal Cut-Off, and the Thermostat. All three should return an audible beep from the tester, indicating continuity exists. In my case, only the Heater Element was bad and actually had a break in it from overheating. One screw holds the heater element in the housing, so it is easily removed. I had to press on the housing a little to unbind the sides of the heater element, and then it slid right out. The housing can now be cleaned out. Assuming the thermal cut-off and the thermostat tested fine for continuity, all I would do is reach inside the heater housing and clean off the lint and dust build up on these devices, since they appear to be working. Install the new heater element.
While I had everything apart, I cleaned out the flexible duct in the back, vacuumed everywhere inside and out, and even used compressed air to clean out any remaining lint and dust that I could. Reassemble the heater box into the dryer in reverse order. Make sure all of the wires are properly reconnected to all of the devices. Make sure everything is screwed back together properly. Now, reassemble the lint duct by attaching the clip to the dryer and setting the duct in place, and then screwing the two screws back in place. Plug the dryer in and turn it on. If all went well, the heater element should glow orange and there should be heat
Posted on Jul 23, 2010
  • sandjcornwel May 13, 2013
    Outstanding suggestions and clearly written, many thanks. Duh, I went to check our exterior drier vent screen on the side of our house and it was PACKED with lint. But I still took all apart as you suggested and got good readings on three sets of plugs. However, there were two other plugs on the exhaust side of the drum, under the screen, and the smaller one did not have any resistance reading - it was a 1 - no circuit. I've got to find out what that does.
  • 246 Answers
Two different issues to address. First let's take care of your moisture sensors. If your lint screen is on the top of the washer, look at the back panel on the inside of the drum. If your lint screen is under the door, put you head in the drum and look straight back towards where the lint filter sits. Which ever style you have, you should see 2 silver bars inside. These are you moisture sensors. They work on the principle that when something wet brushes across them, it completes a circuit and tells the unit to keep running. Overtime, they can develop a build up on them and moisture cannot get to the sensors. Therefore the dryer "thinks" the clothes are dry and turns itself off. The easiest way to clean them is either using the "rough" side of a double sided sponge or for slightly worse/ stubborn build up you can use a fine grit sand paper. Rub either of these back and forth across your sensors to clean them up.
Now the second thing I wanted to check on was you said that you stopped using the auto sensing feature and then later you said sometimes it can take quite a few hours to dry a load. Now if you have stopped using the auto sensing AND it is still taking quite a few hours, then read on, otherwise you should be all set. However if you are still having hours of drying time on your timed dry cyles as well, then read on. From the dryer side, using a vaccume cleaner attachment (availible at most appliance parts stores) to clean out under your lint screen can help. Also check the vent between the wall and rear of the dryer. Is it bent or kinked? Remove it and clean it out as well once it is straightened. Lastly, you could have a restriction in the house portion of your vent. Again appliance parts stores generally sell a cleaning kit for the house portion or there are companies that specialize in dryer vent cleaning as well.
Sorry if you didn't need the last portion, but I just wanted to make sure we covered all of the problems you were having. Drop me a note back if you need anything else.
Posted on Jun 25, 2008
Why won't it start?
Free Kenmore Clothes Dryer User Manuals ' ManualsOnline ...
laundry.manualsonline.com > ... > Laundry Appliance Kenmore
Products 1 - 50 of 65 - Kenmore ELITE HE3 Gas Dryer User's Guide 110.9787 9789. Pages: 0 ... Kenmore 27-Inch Wide Electric Dryer Owners Manual. Pages: 0 ...
Whirlpool & Kenmore Dryer Repair #02 - Won't Start or Run ...? 7:29https://www.youtube.com/watch?v=SPRqKVE8JfYOct 21, 2011 - Uploaded by canyonman1963... and repair a Whirlpool or Kenmore electric dryer that will not start or run. ..... I have a Kenmore Elite Oasis ST Dryer, model number 110.78082701. During ... Dryer Troubleshooting - NotDrying or Taking a Long Time to Dry ...How to take apart Kenmore Elite Dryer - YouTube? 6:28https://www.youtube.com/watch?v=QNa6zfzrm5kOct 16, 2012 - Uploaded by RenewApplianceI have a kenmore elite 79661423410 electric dryer stoppedworking manual says has no thermal fuse and I can't take it apart help thank you.
Dec 12, 2015 | Kenmore HE5 Electric Dryer
Dryer putting out hot air but clothes not drying
You have some blockage between lint trap and where the unit vents outside.
Dec 16, 2012 | Kenmore Dryer Sears Elite
It takes two hours or more to dry clothes
Hello tront... begin by clearing the lint from the vent pipe and the outdoor end of the vent pipe. This alone will cause the dryer to take hours to dry the clothes. Joe
Jul 02, 2011 | Kenmore Elite Oasis 7808 Gas Dryer
Hello; I have a sears kenmors electric dryer that does not dry my cloth the first cycle . I checked the vent and cleaned out the complete dryer from the air inlet through the exhaust and the fan inside...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 25, 2010 | Kenmore Dryers
Have an HE3 Kenmore elite gas dryer. It is taking longer to dry the clothes than it did when it was new. Is there any maintenance I can do to improve the time?
If your dryer is STILL heating, but your clothes still won't dry, you may want to check the dryer interior cabinet and/or the entire run of the exhaust ducting from where it exits your dryer to the point where it leaves your home to ensure you have no kinks or clogs. The following link explains many of the common problems that can cause poor drying efficiency and longer dry times:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
Before assuming you have a problem with the appliance, check your installation to ensure you are providing the dryer with proper exhaust and air flow. This is the NUMBER ONE cause of poor drying efficiency. A dryer in a clogged state or having improper air flow will not dry efficiently and will cause the heating circuits to overheat. Eventually, this can lead to component failures and is the source of many fire hazards. If you have any questions, please post back with a complete MODEL NUMBER and let me know. I hope you find this information helpful.
Aug 03, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
2 problems with my Kenmore Elite dryer
Hello, I would be curious to know if the dryer performs the same way on "timed" dry and "auto-dry", have you tried ? Here's a tip on how you can absolutely know if you have venting issues ( and I don't necessarily mean a "clogged" vent, there are other factors too ) Disconnect the vent at the rear of the dryer and run a cycle as you normally would and observe what happens. Also if it has the flex venting on it ( whether plastic or foil type ) get rid of it, personally I will not even service a customers dryer until they agree to change it when present. I'll watch for you reply in this post if I can assist you further. Good luck. macmarkus :)
Apr 10, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite He3 dryer..fine on timed but leaves cloths wet auto
find the metal sensors in the drum
scratchem up with sand paper
especially if you wash rugs, sneakers , or anything with acyrlic
Oct 05, 2009 | Kenmore Elite HE4 Electric Dryer
DRYER DOOR WILL NOT STAY CLOSED WHEN IN USE
Most likely the receptacle that the door latch goes into is broken. Go to local appliance parts dealer with model number and buy the $5 part, or order through Sears Parts Direct online.
Jun 13, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE3 Dryer clothes not dry after cycle
it sounds like a clog in vent.if yours vents up thru roof you may need to have a chimney sweep come out and sweep vent.check and make sure the vent hose is net kinked or full of lint.
Mar 06, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Clothes Dryer not drying
Hello, check to make sure that the dryer is venting properly, is the hot air getting out of the vent ?. If not clear the restriction or unkink the vent then try again. good luck
Dec 16, 2008 | Hotpoint NVL333EY Electric Dryer
Kenmore 62802 Electric Dryer Logo
3,095 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
