Question about Frigidaire FEQ1442ES Electric Dryer
Dryer turns off after 30 seconds and beeps six times (over and over.....)
A couple of weeks ago, I found that the dryer would stop after one load had dried (around 45 min) and wouldn't restart until it had been left alone for an hour or so (cooling down I guess). Then, this weekend, the time dropped to about 30 seconds, and the dreadful six beeps code thing happened. Even after cancelling the beep continues along with the lights flashing. I tried unplugging and trying again but had the same result. The unit is only three years old and looks like new. Is this normal? Is there anything other than a dying motor that could cause this?  Hopefully yours, Steve R.
  • 2 more comments
  • haller1 Sep 04, 2008
    My dryer is brand new and has been installed. It runs for about 10 seconds and then shuts down. Any suggestions?
  • habbibte Dec 27, 2008
    This has happened to me twice now. I take everything apart and clean it really well, including vacuuming excess lint out of every crevice and crack I can find. It seems to do the trick, but now my dryer will not function on the 'normal' setting at all. It just reads 'damp' and beeps away, I am forced to use towels or perm press settings.
  • mayumir Mar 17, 2009
    I have the exact same problem.  In my case, I am forced to use 45mim. setting.  Nothing else works.  The dryer runs about 10-15 sec. and stops.  It beeps 6 times continuously.  Please someone help me.  By the way, it is only 2 1/2 old.
  • zhuntsman Apr 29, 2009
    I have the same problem. Just started yesterday ( 29 of April) The machine is only about 1 1/2 years old. Sounds like a thourough clen is needed. Could this be a stuck button problem in the control panel??? Has anybody above solved the problem yet?
    Please help...much appreciated.
    Zack
  • 4 Answers
There is a moisture sensor by the lint screen, that could be defective.
Posted on Dec 23, 2008
    Genius:
  • 1,073 Answers
Other than a good lint cleaning by dissasemble and if not then replace the motor
Posted on Jun 24, 2008
Bosch dryer beeps
Two Beeps on my Bosch WTE84100au Condensing Dryer means a thermal overload but also means one of the thermal sensors is faulty .... as if it is always on.
Open the door, pull out the lint catcher and clean around the silver probe (it's like a shiny 1/8" nail sticking into the cavity below the lint catcher). If it still doesn't work (and still 2 beeps), just flick it lightly a couple of times. If it still doesn't work, flick again from the other direction.
Mar 24, 2014 | Dryers
Dryer is a week old. ran a cycle and dryer turned off. didn't trip breaker. wouldnt turn back on. so turned breaker off for a while then turned it back on. now dryer powers on but for only like 10 seconds...
A week old dryer should have, in its warranty, a condition that you can get them to exchange this for an identical (hopefully working) model free. Do it now, that is a short time window. It's usually one month.
Nov 16, 2013 | Samsung DV50F9A8EVP 27" Electric Dryer...
We have a electric, front load electric Duet dryer that was working fine this morning and when my wife went to put a second load in.... it only beeps...nothing else looks wrong on the control...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 08, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer - GE model DRSR483 ED2WW Worked fine a few days ago with a light load. Now, just a loud beep when I try to start it. It doesn't come on. I can turn the drum manually (slowly) - almost sounds like...
heatman101
Sep 01, 2010 | GE DBSR453EBWW Electric Dryer
I have a FEQB4000FSO dryer that continually beeps, running or finished. The lights flash and I can't reset it...HELP! it makes me crazy!
first see where the beeping is coming from you might have a load finish alert setting on your dryer as in when it finishes the cycle it beeps but the contacts might have gotten stuck together so they are making the noise always try first unplugging the dryer for couple seconds than if that doesnt help  get the wiring schametics its usually on the inside bottom pannel your panel should have two or three screws on bottom of the bottom panel and check on the wiring schametics if you have the buzzer (probably name used in the schametics) if yes than try to see where it is so you can just disconnect it
but easiest thing to do is just unplugg it and plug it back in after 30 seconds
Jun 07, 2009 | Frigidaire FEQ1442ES Electric Dryer
Dryer won't turn on for 2nd load
A couple of things is to make sure you have 110v at the recepticle, if you do then it's with in the dryer. It could be the door switch wont close, thermal over load won't reset in your motor(if it got hot enough to open, you said it had been in use) , broken belt switch if your dryer has one, or even the thermal fuse (in series with L-1) opened up. Ohm out the door switch in the closed position, it should read 0 ohms, Same with the thermal fuse, should read 0 ohms, not an open read.Good Luck..MJE
Mar 25, 2009 | Dryers
Maytag Neptune gas dryer beeps.
NO RESETS OTHER THAN TO UNPLUG THE DRYER FOR 5 MINUTES, THEN RECONNECT POWER. ON ANY ELECTRONIC CONTROL, THIS WILL RESET THE CONTROL'S MICROCOMPUTER. IF THAT DOESN'T SOLVE THE PROBLEM, THE TOUCH SWITCH MAY BE FAULTY.
Apr 14, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Kenmore he4t front loading dryer stopped working
did you clean the lint?
is the way the airflow goes not blocked with residue??
Mar 19, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Frigidaire LEQ2152ES Electric dryer
Just to verify does it also beep six times? This model has the actual pushbuttons. Press all buttons lightly and see if any release. Disengage button.
Nov 25, 2007 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire FEQ1442ES Electric Dryer Logo
549 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
