Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
KENMOOR 59672253200 my kenmoor fridge dont work frezer very cold
  • punn2832 Aug 26, 2008
    re: kenmore model # 59672213200
    I too have the situation that the refrigerator is not cool while the freezer on the bottom  is working fine.  I have tried to check the vents in both the freezer and refrigerator to be sure they are not blocked but i am 85 and having difficulty locating all of them.  Do you know why this would be happening other than vent blockage?  Do you have any recommendation?  Thank you for your time.
  • francis rivero May 11, 2010
    we can not help unless you specify what is the particular problem. what happened? what is happening now? what is wrong with the fridge?
    thank you,
I was out of town and the top part, the refrigerator part lost the coldness. The freezer which is on the bottom is working ;just fine.
Posted on Jun 26, 2008
The fridge is not working.the freezer is the freezer the cold air is not coming in the fridge.
fridge basics
the fridge and freezer are seperate compartments they dont share air there is a chemical filled filiment on your fridge u can see it at the back looks like a big grill that chemical is pumped around both fridge and frezer that chemical carrys heat energy it removes the heat from the fridge and frezer to the radiator at the back this radiator gets verry hot whyle your fridge / frezer becomes cold it shuld be 1 compleate system with better fluid flow in the frezer to make it cool faster
ok so the frezer is working but fridge is not it could be a few things 1 fluid not geting round the fridge lack of fluid or 2 a blockage
im no expert but knowing the basic science of fridges is a help i hope this has helped but like i say im not farmiliar with any fridge and models deviate but the science stays the same hopefully this steers u in the right direction
Oct 30, 2012 | Refrigerators
There is frost buildup on back wall of frezer fridge or frezer dont get cold enough
my fan blade had slipped down and was rubbing makeing a noise and fine particles of white dust was at the rub point. Pushed the fan back up drop of super glue and lubricated the motor. works great!
Jul 27, 2010 | Hotpoint (HSM25IFTSA) Side by Side...
Fridge not cold frezer working ok
check the temperature settings in the fridge.
Feb 19, 2010 | Freezers
Our frezzer is working fine but the fridge isnt
the return air ducts are frozen, not allowing cool air up to the fridge
unplug unit overnight and let defrost,you can speed up the defrost time by using a blowdryer in the freezer compartment
Jan 16, 2010 | Samsung Refrigerators
The fridge is not working and the frezer has a low temperature
be carefull when you remove the panel inside the frezer it may be you have a build up of ice and the panel could get frozen to the ice, best idea is to turn off the fridge/frezer for 24hrs to let it thaw
Oct 15, 2009 | Hotpoint FFA60 Bottom Freezer Refrigerator
Fridge does not get very cold,compressor comes on, frezer is cold
check to fan inside unit air not transferring from freezer to fridge fan uses cold air from freezer to cool fridge check that fan is working usually can feel but may have to push button on door and hold if no fan remove cover and check for ice on blockage if none have fan serviced or replaced -if fan is working properly, same area is a damper that my be blocked or frozen good luck and thank u for using fixya
Oct 14, 2009 | GE Refrigerators
My Kenmore modle 59672253200 vegetable crisper is freezing up. Thermostats and fan have been replace but problem still exist.
What is your fridge thermostat set at?
Check the freezer thermostat setting.
Too cold of freezer will do this.
Sep 28, 2009 | Refrigerators
Frezer cold and working but the refrigerator
It sounds like your fridge has leaked refrigerant gas. The leak needs to be repaired and then the fridge should be recharged.
Mar 02, 2009 | Refrigerators
The fridge on my fridge freezer has stopped
just about all friges work off the frezer .the evap fan moves the air fromthe frezer to the you would here fan noise.i dont know your brand but on most frezers if you turn the frezer temp to the highest setting thats acomplished by keeping the air from going to the frige.hence warmer frig temps .also make sure fan on out side back is working and condenser is clean.again turn air damper control from frezer to frige to lowest setting .somthimes this could be in frig section.God bless ,tom
Jan 01, 2009 | Freezers
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
148 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
