Question about Dometic Rooftop RV Air Conditioner
High cool not working
The low cool and low fan works but high cool and high fan does not work at all. I can here a humm on the roof if I try to turn it on.Whats uo
  • gitzit1 May 11, 2010
    Do you think it could be a fan capasitor? or is it even worth trying it.
  • Anonymous Mar 22, 2014
    modle#MGHOO55B THE FAN BOWS FOR ABOUT 20 MIN. THEN CUTS OFF AND THE UNITE DOSE NOT TRY TO COOL AND THE LINE DOES NOT FREEZE UP LIKE ITS OUT OF FREON
  • 828 Answers
Compressors on these units runs at only one speed. The change to high cool is only a change in blower speed moving air faster over the cooling coil. I would have the running capacitor for the fan motor checked. A bad capacitor can cause your type of problem. The other problem could be that the high speed winding in the fan motor is bad. Try it operation in the fan only position through the two speeds. If it works in the low and high speed for fan only your problem could be in the selector switch.
Posted on Jun 28, 2008
My low cool and low fan does not work. High cool and high fan works good. Is this something I can fix myself and if so, how?
If it is a Ford product the problem is with the ignition switch!!!!!!!!High cool function bypasses switch, Other speeds do not.
Your headlights might not be working either.
Jul 29, 2015 | Cars & Trucks
Front unit high cool and high fan not working
just replace the fan ..... its seems there is some voltage problem
Jun 25, 2008 | Dometic Rooftop RV Air Conditioner
My ac is not working I have a Chevy Tahoe 2005 the fans won't turn on either .
Hi Maria , The A/C system wouldn't keep the fans from running but none working cooling fans will keep the A/C from working ! This is a fairly complex system if your not familiar with this sort of thing ! I will add the description from the factory service manual.
Cooling Fan Control - Two Fan System
The engine cooling fan system consists of 2 electrical cooling fans and 3 fan relays. The relays are arranged in a series/parallel configuration that allows the powertrain control module (PCM) to operate both fans together at low or high speeds. The cooling fans and fan relays receive battery positive voltage from the underhood fuse block.
During low speed operation, the PCM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. This energizes the low speed fan relay coil, closes the relay contacts, and supplies battery positive voltage from the low fan fuse through the cooling fan motor supply voltage circuit to the left cooling fan. The ground path for the left cooling fan is through the cooling fan s/p relay and the right cooling fan. The result is a series circuit with both fans running at low speed.
During high speed operation the PCM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. After a 3 second delay, the PCM supplies a ground path for the high speed fan relay and the cooling fan s/p relay through the high speed cooling fan relay control circuit. This energizes the cooling fan s/p relay coil, closes the relay contacts, and provides a ground path for the left cooling fan. At the same time the high speed fan relay coil is energized closing the relay contacts and provides battery positive voltage from the high fan fuse on the cooling fan motor supply voltage circuit to the right cooling fan. During high speed fan operation, both engine cooling fans have there own ground path. The result is a parallel circuit with both fans running at high speed.
Do you have a check engine light lit ? The thing to do would have it check at the dealer or a ASE certified repair facility ! They could hook up a advanced scan tool an diagnose fairly quick ! Or you could find a wiring diagram an try testing with a volt meter yourself ! But watch yourself so you don't short out the PCM - engine computer !
May 01, 2015 | AC Cars & Trucks
Whirlpool microwave fan not working
I would unplug the oven for 2 minutes to do a hard reset and try it again, just in cause there was a glitch.
Without knowing your full model number from the tag on the oven, I would wonder if it has a separate internal cooling fan from the hood vent exhaust fan. It could be an unrelated issue.
For more free DIY and other help & advice, feel free to contact me with your full model number and FCC ID number from the tag on your oven.
William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 11, 2017 | Microwave Ovens
2007 chrysler pt cruiser cooling fan does not work with ac
If refrigerant is low , high side pressure may not be high enough to engage the pressure switch to kick on the fans. Have the a/c system evac'd and recharged to capacity then recheck fan operation. Also, extreme cold weather can reduce high side pressure on a fully charged system preventing fans from coming on.
Feb 14, 2014 | Cars & Trucks
Almost no air comes from the ac vents but fan is on high. This happens on auto and also on econ.
The 1992 was prior to Buick putting cabin air filters in so there is not a possibility it is clogged. So more than likely your blower motor is going bad or your fan control switch is bad. Does this problem occur with heating as well as AC? Does it change if you switch between blowing on floor, face, window(defrost) If it doesnt change based on location of blow and type of air temp then I would start by turning fan on high and placing head (ear ) against dash in center of console area. Have someone turn fan knob from low to high with engine OFF...After goign from low to high and back a few times you can see if the blower motor is responding to signal from switch. Listen for a whine, squeal, rattle, or humm. A whine or Humm would indicate a bad blower motor... Squeal or rattle a bad squirrel cage/fan blower blades. If you hear no noise and no perceivable change in blower speed/noise then its possible your switch is bad. Unfortunately the only way to definitely diagnose either is to pull the switch from dash and use multimeter to test for voltage change and for blower motor to pull dash. There is a digital control unit for your car as well. Although rare sometimes the wires on this can loosen or it can go bad. But since you didnt state teh fan wasnt working at all and you are getting cool air, that woudl be teh last thing to check
Jun 06, 2010 | 1992 Buick Park Avenue
Cool fan low doesn't work. Doesn't appear to be
It needs to have the blower motor resistor card replaced.
It still works on high speed because on the high setting the voltage does not go through the resistor.
The resistor is mounted beside the blower motor and is easy to replace.
There you are, thank you for using FixYa.
KL
May 01, 2010 | 2003 Saturn VUE
Microwave not heating unless exhaust fan is on high
check the control unit and high voltage circuit, and megnetron, high voltage diodes, wiring and high voltage fuse etc.,
Sep 26, 2007 | Samsung MW1030WA Microwave Oven
Dometic Rooftop RV Air Conditioner Logo
545 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
