Back to:
Tags:
Technics SL-1200MK2 Turntable
Technic 12000 (by 2 users)
posted by grahamcon on Jun 23, 2008
I am getting no sound out of the left hand side of my technic1200 mk 11 deck. I have changed the leads and this made no difference.Any suggestions to the fault?
Comment by grahamcon, posted on Jun 24, 2008
Tim ,
Tks for your imput I have tried all the usual including reversing the leads and every possible solution. I have had 1200 for the past 20 years and come across all these problems before.There is something in the deck that is blown. If i can find out what it possible is I can change the part. Any suggestions Tks
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by cutty941, posted on Jul 27, 2008
no sound... everything else works fine...
Best Solution
posted on Jun 23, 2008
Inappropriate (40)
SIPRESS2
Rank:Apprentice Apprentice
Rating: 40%, 1 votes
DO THE SIMPLE THINGS FOR STARTERS. DID YOU TRY REVERSING THE CHANNELS? CONNECT THE LEFT TO THE RIGHT AND THE RIGHT TO THE LEFT. THAT WILL TELL YOU IF IT'S THE TURNTABLE OR THE AMP. DO YOU PERHAPS HAVE ANOTHER STYLUS YOU CAN TRY, TO SEE IF THE NEEDLE IS DAMAGED?
TIM
Rating Locked! (?) grahamcon has rated this solution as Inappropriate
Thank You!
Was the solution helpful?
Show your appreciation by commenting on technic 12000:
I don't want to Accept this solution
Solution #2
posted on Sep 08, 2008
Not Rated (0)
djproaudio
Rank:Guru Guru
Rating: 88%, 147 votes
The issue is more than likely with your tonearm. How did you replace the leads? Did you unsolder the old ones from the main PC board? Or did you just splice? If you just spliced new ones, this also might be the root of your issue. If you went straight from the board, then the only other culprit is your tonearm.
Well, actually, the issue could also be your stylus or cartridge. Have you determined whether this was ok? If so, then it's your tonearm.
Look inside the area where the cartridge mounts. You'll see 4 gold prongs. All 4 prongs must be protruding, and must all be equally protruding from the base. If one is shorter than the others, that is an issue. You can attempt to get the shorter one to bounce back (there are springs behind each prong), by getting a paper clip or similar and pushing the prong in, hopefully it will bounce back - if not, you'll have to have your tonearm replaced.
If your prongs all look good, make sure there is no build up of any type on the prongs. They should be a nice shiny gold. However, because your unit is 20 years old, I can only imagine it hasn't been cleaned there in that amount of time - most people don't know they should clean that area.
To Clean - get yourself some Isopropyl Alcohol (99% pure ONLY), and get a cotton swab, and just clean it out. If it doesn't work, then it might be damaged, and will need to be replaced.
Besides... After 20 years, it's a good idea to change your tonearm at this time. For the cost, this unit will perform another 20 years without any issues.
- OPTiC
The 1200s Expert
www.1200s.com
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Can you Help with these Turntables problems?
Turntables
Wanted to play some Buddy Rich for my daughter who is...
Turntables
the drive belt has come off. how can i put it back on to...
Turntables
Dear davejuke01, Thank you for telling me about the brush...
Turntables
need a motor for my turntable..it is an old system but in...
Turntables
When I push the power button it doesn't come on.
Loading problems.
Repair Service
Find Turntable Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
