Question about Cameras
Automatic lens cover only shuts
I have a Pentax ESPIO 140 zoom camera. The Automatic lens cover only shuts part of the way when the camera is turned off
  • Fellsider Jun 23, 2008
    The only power source is the Lithium battery which is in good shape. All the other features of the camera work OK. (Just to clarify, this is not a digital camera - it's an old model 135mm zoom dating from around 1990)
    Thanks
    This doesn't really answer the problem as I have already done these things - the problem seems to be more mechanical rather than dirt or the result of sticky fingers.
  • Cameras Master
  • 6,487 Answers
This can only mean your lens is damage and needs replacement I suggest you better take it to a repair center have the lens replace because your camera is old and still working fine so I assume you still want to use it for more long years.......
Goodl luck....
Posted on Jun 23, 2008
    Master:
  • 638 Answers
Its some obstructing thing that stopping the lens cover .clean it properly to clear any blockage.i have come through a same problem few months ago at my workshop.cleaning really helped n its working fine now.wish u success too.
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
  • 91 Answers
What probably happened was that you dropped the camera some where or that you accidentally touched the lens.
Thank You!!!!!
    Master:
  • 788 Answers
My Kodak does the same way the kids got there sticky fingers on it.
I would suggest trying to clean it with some 98-99% Isopropyl Alcohol since the alcohol evaporates completely. Make sure to remove the batteries before doing it. Also use some compressed air to try to dislodge any dirt, dust, or debris that may be stopping the movement.
If it still doesn't close once you've cleaned it then there may be something physicaly wrong or broken inside the camera. You can attempt dissasembly but it could be quite fragile and tricky to take apart and even more so to put back together.
Otherwise, always keep a good clean micro-fiber cleaning cloth with you and clean the lens frequently.
  • Cameras Master
  • 1,879 Answers
Greetings,
Use the power adapter that came with the unit.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
    Guru:
  • 1,894 Answers
Did u drop the camera?
the lens section is jammed i think
  • dewan nafees ahmed Jun 23, 2008
    The problem isn't in the sliding door. All it does is allow power to
    switch on. If you're getting some functions the obviously the door's
    switch is operating correctly.
    Your problem is in the lens area.
    If you're lucky a ribbon cable has become loose or dislodged. If luck
    isn't with you the lens assembly is kaput.
    Very minor knocks in
    the right place can dislodge guide pins or knock those guide pins out
    of the grooves they run in to extend the lens or operate the focus. The
    camera will check the operation of the lens prior to allowing pictures
    to be taken so if any part of the lens is out of whack then the camera
    gets a bad routine message and switches off. If you are in the review
    mode sometimes certain cameras will allow you to see what you've
    already taken but switching to any shoot mode will disable the camera.
    The
    only advice I can give is either get the camera repaired or trust your
    luck and wait for the same model camera to come up on Ebay with a
    different problem e.g. broken LCD and do a transplant. Or sell the
    broken camera on Ebay and buy yourself a new one.
    credits:bmwrider of fixya
    since topic was Generic problem for all Digital Cameras we thought it to be a digital camera. sorry.
I need a user Manual for ESPIO 160 Pentax camera
The ESPIO 160 is called the IQZoom 160 in some parts of the world. You may download a copy of the IQZoom 160 manual here.
May 31, 2012 | Pentax ESPIO 160 QD 35mm Film Camera
Need to find manual for Pentax Espio 120 Mi
The Espio 120mi was called the IQ-Zoom 120mi in some parts of the world. You may download a copy of the IQ-Zoom 120mi manual here.
Apr 04, 2012 | Pentax Photography
I was given a 35mm pentax espio 70 zoom camera recently but I have no instruction leaflet with it. Is it possible still to get one.
Most documentation is available online. Use the search engine of your choosing to look for:
Camera manufacturer + model + manual
I believe you can find it here:
http://www.pentaximaging.com/support/manuals-and-literature/
Feb 28, 2011 | Pentax Espio 738S 35mm Point and Shoot...
How much is a Pentax esp10-140 worth?
I found the ESPIO-140M selling for as little as $30, and I found an ESPIO-140V in excellent used condition selling for $150. I also noted a 140V that failed to sell for $55 on eBay. I hope this information helps.
Here's a link to the high priced V model:
http://www.porterelectronics.com/servlet/the-342/Pentax-Espio-140V-35mm/Detail
Jan 26, 2011 | Pentax Cameras
U7 error code when Pentax Espio 200 camera switched on. What does it mean? Can I rewind and remove film to develop?
Its actually a technician code which means that your Zoom system has malfunctioned. If you want to remove the film then you can simply click the reset button and then remove the film. If you want to get it repaired then it would be better if you throw it and look for a new SLR Camera
Oct 22, 2010 | Pentax Espio 200 35mm Film Camera
What does smcp -fa mean
SMCP- means: Super MultiCoated Pentax (a term that refers to the anti-relctive coatings that Pentax has been using on its lenses for years F-means it is a lens designed to cover the larger area required of a lens for Film camera use versus the smaller sensor of the Digital SLRs Pentax also makes. Pentax also makes DA lenses , which will only work with their digital SLRs. A- means it will work in fully automatic mode on cameras that have the ability to set shutter speed and F-stop automatically (most modern Pentaxes) It should also be noted that all DA and FA pentax lenses have a modified version of the original Pentax K lens mount, which replaced their first lens mount, the universal M42 used by so many early film SLR manufacurers- this concluded todays pentax lens history
Jun 02, 2010 | Pentax Zoom Wide Angle SMCP-FA 28-105mm...
Camera suddenly stopped responding, maked grating noise and shows HI in window. wil not turn off.
If the 'H' disappears when the zoom lever is moved the camera is ready for use. If the 'H' appears often, it should be taken to the service.
Nov 20, 2009 | Pentax ESPIO 160 QD 35mm Film Camera
Pentax espio 140
subaru662,
can you see the lens in the finder move when you zoom out? if not ,the finder lens is stuck.
if it does move when zooming, see if you have a diopter adjustment wheel or sliding knob near the front lens of the finder. if so adjust the lens to your eye.
Jun 28, 2008 | Pentax Espio 140V 35mm Point and Shoot...
A Pentax Espio 135M Multi AF Auto Focus 35mm Compact Camera with a SMC Pentax 38mm to 135mm Zoom Len
I sounds like your shutter is stinking dont remove or losen the screws there are manuals on the web. find out what type a camera it is then go to the retail on the web they should have support or manuals for you
Apr 06, 2008 | Cameras
Zoom lens not retracting
May be a bit of grit gas got in. Do not try to manually manipulate it- this will wreck the motor drive. A Vacuum clean suck way have some affect. Certainly contact Pentax Tech Support Team .
Jul 02, 2007 | Pentax IQZoom 140M 35mm Point and Shoot...
Cameras Logo
57 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
