Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
Distorded image on left side of scren
Cloor bloom on left side of screen, right side appears near normal.
    Novelist:
    Champion:
  • 203 Answers
Probably has a convergence problem that may be able to be solved if caught early enough by soldering the pins of the convergence amps which are mounted on large heatsinks. If soldering them doesn't do it then replace them and you should be good. You will need a soldering iron, solder and solder wick(to remove old solder). Hope this helps you, Russmann.
Posted on Jun 24, 2008
Youtube on my vizio 470i tv is off centered
CHANGING THE SCREEN ASPECT RATIO: ( From Manual )
The TV can display images in four different modes: Wide, Zoom, Panoramic, and Normal. Each mode displays the picture differently. To change the screen aspect ratio:
1. Press the MENU button on the remote.
2. Use the Arrow buttons to highlight the Wide icon. Press OK.
3. Use the Arrow buttons to highlight your desired screen mode and press OK:
• Normal preserves the content's original aspect ratio. Since the 4:3 aspect ratio is not large enough to fill the TV's screen, black bars are added to the left and right of the display image.
• Wide stretches a 4:3 aspect ratio picture to the edges of the screen. Since the picture is being stretched, the display image may appear distorted. If the program is already formatted for widescreen viewing (1.85:1 or 2.35:1), then black bars will appear on the top and bottom of the display image.
• Zoom expands images with black bars to fit the screen.
• Panoramic expands the display image to fill the screen.
images may appear wider than intended.
If you are watching widescreen (1.85:1 or 2.35:1) content, black bars will still appear on the top and bottom of the display image. This option is only available when the TV is displaying a 480i/480p source.
Apr 25, 2014 | Vizio Televison & Video
The words "Digital Noise Filter
The words "Digital Noise Filter Off" and "digital Noise Filter On" appear on the top left and right and side of the screen and the words " Auto Visulisation" appear on the bottom of the screen all the time when watching normal T.V.(series 5 lcd) and if we make changes regarding in setting in picture option in mode.then after 20-30 min againg it displays same message
Feb 01, 2011 | Samsung LE40R74BDX 40 in. LCD Television
I'm having trouble deleting pictures any advice would be helpfull.
normal procedure for deleting images using a dscs700 cam.
1. press playback button (button you use for viewing images, located just above the lcd screen,left side w/arrow icon pointing to the left)
2.salect the image by pressing the left or right control button
3.once image to be deleted is selected, press the delete button (2 black squares w/a slash and garbage can icon,below the control buttons on the left side).
4.select delete option by pressing the up control button.
5.press middle of the control button to confirm.
...or if you would like to just remove everything on the memory stick including protected images you can just format the ms by:
1.press menu to diplay menu settings.
2.press right control button to go to setup (looks like a toolbox or suitcase icon) and press the right control button again.
3.press the down control button to go to Memory Stick Tool and press right again to confirm selection.
4.press right control button to select format.
5.press up control to select ok and press middle control button. message will appear telling you that "all data in ms will be erased.ready?"
6'press up control to select ok and confirm by pressing middle control button.format completed.
hope this info helps. thanks:)
Apr 13, 2010 | Sony Cyber-shot DSC-S700 Digital Camera
How do I make the blooming flash work?
on the left side of the camera there should be the usb port and theres a little switch right above it,, if u push it down it will put the camera in "normal" mode and the flash will come on automatically.. if not u might have to do it manually by pressing the lightning bolt button
Oct 17, 2009 | Vivitar ViviCam 5024 Digital Camera
Image split with black bar in middle
check leads if they are connect in the normal video slot on dvd player and chek the player settings what out pot it is on
Aug 21, 2009 | JVC HR-XVC18B DVD Player/VCR
Tv has a distorded image on right side
You have a speaker too close to tv,or some other stong magnet move the tv our magnetic source.
Mar 12, 2009 | Vizio L32 32 in. LCD HDTV
Image has bend at top of screen
first reset the setting to factory default. if it persists on a regular image too, either the lens, the tunnel or something else in the optical engine is damaged (from a fall?).
Jul 29, 2008 | InFocus ScreenPlay 4805 Multimedia...
Dlp tv hl-r5688w samsung
i believe the buld is bad replace it its cost from 200 to 500 dollars depending on the year and model
Jun 20, 2008 | Samsung Televison & Video
WS-55807: Images are dark on right side of display, but will go away after 3-4 hours.
you could be on the right track get some freeze spray and go around all the parts to see if you can make it act up, same with heatgun or hair dryer when first turned on heat one area at a time to narrow your problem down
Oct 21, 2007 | Mitsubishi WS-55807 TV
Sony FD Trinitron WEGA kv32fs120 32" picture too big/vertical arch...
Sounds like you have a problem with the high voltage regulation or the power supply. This condition is called "blooming" Stargazer
Aug 18, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
27 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
