Question about Car Audio & Video
2004 Buick Rendezvous No sound coming out stereo
All the functions seem to be working well on the radio , but all sound has quit coming out of the speakers. I checked the owners manual assuming that it was a blown fuse, but there is only one fuse for the radio and it is good. There is also a fuse in the amplifier slot and it is good, but where is the factory amp located on a Buick rendezvous , or am I overlooking some other possible problem?
  • Justin9212 Nov 05, 2008
    I have the same exact problem. I tried to replace the Head Unit thinking it was the problem, I replaced it with an aftermarket unit and the same thing happened a few days later. I put the factory one back in and it started working again, then quit just like before. Lights on but nobody's home. I am beginning to think the BCM might have something to do with it. The speakers must be run through it for the door chime or something. I am about to just run my own speaker wires to the speakers to avoid the BCM all together.
Call the dealer
Posted on Aug 21, 2008
Having problems with 2003 buick rendezvous radio. When i turn on radio the gages stop working for some reason and my headlights stop working too. It's weird!! What seems to be the problem!?
Have you modified the radio in any way? Added an external amp? Sounds as if your radio is drawing too much current or is wired into the lighting circuit. Does radio work normally while the lights go out?
Jun 29, 2015 | Buick Cars & Trucks
My air conditioner compressor in my 2002 buick rendezvous stopped working.
Take to a shop that has the proper gauges and ability to vacuum the system properly. Do not simply try and add Freon as it only causes an air gap and false readings. In addition, some cars require a resetting of values on the cars computer brain in order to function properly.
Apr 15, 2014 | 2002 Buick Rendezvous
2006 Buick Rendezvous cd and xm not working but radio works fine
depends on what fuse. the fuse on the back of the stereo or the fuse in the fuse box? if the one in the fuse box it should show you on the cover that you opened to get into the box. it should say stereo. now if your looking for the one on the back of the stereo you will have to take the stereo out and on the backside you will find a fuse or two. good luck
Dec 07, 2013 | 2006 Buick Rendezvous
Does anyone have the factory radio wiring diagram for the 04 Buick Rendezvous? I am wanting to remove the factory radio and install my Sony stereo. I have found 1 wiring diagram, But it seems to be off. On...
it should be written cast on radio for wire purpose
orange wire is there for ignition current turn on and off radio current
red for battery current (keep radio setting,clock)
Oct 14, 2013 | 2004 Buick Rendezvous
2004 rendezvous parking lights wont turn off
replace the switch or the relay for the lights normaly one or the other hope this helps ivan
Oct 23, 2012 | 2004 Buick Rendezvous
I have 2004 buick rendezvous and the blower motor fan does not work but the fuse is ok
{: ) If all other HVAC functions seem to be working normally except for the blower air, the most likely cause is a faulty blower resistor assembly ( for manual a/c) or a faulty blower motor control processor( for automatic control a/c). The blower motor can be easily checked if stucked-up or open-circuited. Inspect and repair (or replace) connectors and terminals for these components if you found them heated up or burned.
Aug 06, 2011 | 2004 Buick Rendezvous
My buick Rendezvous 2002 had transmission change n thewindows dont work n the stereo
its got to do with the security system on car it disables your radio and windows ask dealer they can tell you more about it i believe they had a recall on it
Dec 01, 2010 | 2002 Buick Rendezvous
Radio works but no sound. 02 Buick Rendezvous.
you have to find the amp turn on(it might be solid white) wire for the amp from the wire harness and hook it up to amp turn on on the radio
Jul 13, 2009 | Car Audio & Video
Car Audio & Video Logo
479 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
