Question about Logitech diNovo Cordless Desktop DH967428 Keypad/Mouse/Keyboard
Numeric pad How could I connect numeric pad and use in excel worksheet?
  • wjchin1120 Jun 24, 2008
    I have the Logitech V250 cordless
  • 91 Answers
You can connect it using the USB cable that looks like this: http://blogs.s60.com/s60multimedia/usb%20002.jpg
Thank You!!!!
Posted on Jun 23, 2008
My excel is starting right to left in window 7
The default worksheet direction in Excel 2007 or 2010 is Left-to-Right. To change a worksheet direction to Right-to-Left, follow these steps:
  1. In Excel Ribbon click on the Page Layout tab.
  2. In the Sheet Options group click Sheet Right-to-Left. The sheet direction will be changed. Column A will now be to the far right. Columns B, C, D.. etc. will follow to the left.
- See more at: http://www.exceldigest.com/myblog/2012/04/29/how-to-change-worksheet-direction-in-excel-2010-to-right-to-left/#sthash.lSG25YXq.dpuf
May 27, 2014 | Microsoft Excel 2010
Tip
How to find no. of rows and columns in Worksheet.
Hello everybody, this would be my first tip on FixYa.com. Number of people might not be aware how many rows and columns are there in Microsoft Worksheet.
This is how you can find out.
1. Select A1 cell in the worksheet
2. Now press Ctrl + down arrow from your keyboard, that will take you to the bottom of the row. You can find the number on the left side.
3. Again select A1 cell in the worksheet and press Ctrl + left arrow from your keyboard, that will take you to the last column of the worksheet. Now to number, just type "=column() " , without quotations, that will give you the number of the column.
Microsoft Worksheet columns is number from A to Z, again from AA to AZ, again from BA to BZ and so on till it reached IV in Excell 2003 and earlier version.
Microsoft Excel 2003 and old version has 16,777,216 cells per worksheet (65,536 rows * 256 columns).
Excel 2007 has 17,179,869,184 cells per worksheet (1,048,576 rows * 16,384 columns).
on Jul 27, 2010 | Microsoft Excel for PC
Hi. we have copy pasted something to an excel worksheet but the auto sum doesn't work. can you help please?
Its hard to know the issue, but I suspect its due to the cell formatting not being something that can be "summed". Make sure the column(s) you are having autosum are all of the same format (numerical?)
Dec 13, 2013 | Microsoft Excel for PC
What is a workbook?
A workbook is a spreadsheet file. By default, each workbook in Excel contains three pages or worksheet
The term spreadsheet is often used to refer to a workbook, when in actual fact, spreadsheet refers to the computer program, such as Excel.
So, strictly speaking, when you open the Excel spreadsheet program it loads an empty workbook file consisting of three blank worksheets for you to use.
Jun 25, 2011 | Microsoft Office Excel 2007 Full Version...
What is default name in ms excel? how is possible excel worksheet in excel?
Book1.xls Do you mean that you can't find the worksheet you have establish and you haven't rename the file? The worksheet will be OK if it had been saved.
Feb 15, 2011 | Microsoft Office 2010
Ms excel
In Excel Worksheet 2007 the maximum number of rows per worksheet is 1,048,576 and the no. of cols. is 16,384 which is col. XFD, which makes it 17,179,869,184 cells.
Jul 26, 2010 | Microsoft Windows Vista Ultimate Edition
How can enable mail recipient as attachment excel
MAIL RECPEINT AS ATTECHMENT OPTION NOT VISIBLE IN MY OFFICE 2003 PROFESSIONAL
Apr 11, 2009 | Microsoft Office Excel 2003 for PC
Cordless Numeric Pad
If you are using a cordless numeric pad, it likely came with a USB connector. Plug the USB connector in. This should automatically install with Windows plug and play.
You should then be able to punch the numbers in just like you would on a keyboard when you have excel open.
Oct 14, 2008 | Logitech Alto Cordless Laptop...
Import data from access into excel where one column go into one worksheet and other into next
Can't be done.
Access will only put the data into one worksheet. It is very picky when it comes to exporting data into an Excel spreadsheet.
There are two ways to get around it:
1) You can export the data from Access into two files. One for the the first worksheet and another file for the second workshet.
2) You can import everything into one spreadsheet and build a macro into Excel to cut the information one spreadsheet and paste it into the other if this is a redundant task to do all the time.
Hope that helps you out.
Jun 10, 2008 | Microsoft Office Access 2003 (077-02871)...
Export data in excel shld yoeet through VB
When i first figured out how to pull data from SQL and put the results in an excel file i referenced these two articles....
Reading and writing excel file using VB.NET (http://www.codeproject.com/KB/vb/Work_with_Excel__VBNET_.aspx)
Get the Values From DataBase and Stored into excell Sheet (http://www.codeproject.com/KB/vb/Getvaluesfromdatabase.aspx)
This is the code i ended up using.... (check out those links to see how you need to import the ms office excel reference file with visual basic)
Const stcon As String = "Provider=SQLNCLI;server=xxxxx;database=xxxxx;uid=xxxxx;pwd=xxxxx;DataTypeCompatibility=80"
Dim stSQL As String = "select * from scs_rate_class_money where irate_book = 124 and snew_used = 'U' and sclass = '2' and splan = 'T4' and sopt_code = 'F1'"
Dim cnt As New ADODB.Connection
Dim rst As New ADODB.Recordset
Dim fld As ADODB.Field
'Open the connection.
cnt.Open(stcon)
'Open the recordset.
With rst
.CursorLocation = ADODB.CursorLocationEnum.adUseClient
.Open(stSQL, cnt, ADODB.CursorTypeEnum.adOpenForwardOnly, _
ADODB.LockTypeEnum.adLockReadOnly , _
ADODB.CommandTypeEnum.adCmdText)
.ActiveConnection = Nothing 'Disconnect the Recordset.
End With
'Close the connection
cnt.Close ()
Dim exp As Export = New Export()
Dim xlApp As New Microsoft.Office.Interop.Excel.Application
Dim xlWBook As Microsoft.Office.Interop.Excel.Workbook = xlApp.Workbooks.Add(Microsoft.Office.Interop.Excel.XlWBATemplate.xlWBATWorksheet )
Dim xlWSheet As Microsoft.Office.Interop.Excel.Worksheet = CType(xlWBook.Worksheets(1), Microsoft.Office.Interop.Excel.Worksheet)
Dim xlRange As Microsoft.Office.Interop.Excel.Range = CType(xlWSheet, Microsoft.Office.Interop.Excel.Worksheet).Range("A2")
Dim xlCalc As Microsoft.Office.Interop.Excel.XlCalculation
Dim i As Short
'Turn off Excel's calculation.
With xlApp
xlCalc = .Calculation
.Calculation = Microsoft.Office.Interop.Excel.XlCalculation.xlCalculationManual
End With
'Write the fieldnames.
For Each fld In rst.Fields
xlRange.Offset(0, i).Value = fld.Name
i = i + 1
Next
'Populate the range.
xlRange.Offset(1, 0).CopyFromRecordset(rst)
'Close the recordset.
rst.Close()
'Make Excel available to the user.
With xlApp
.Visible = True
.UserControl = True
'Restore the calculation mode.
.Calculation = xlCalc
End With
'Release variables from memory.
fld = Nothing
rst = Nothing
cnt = Nothing
xlRange = Nothing
xlWSheet = Nothing
xlWBook = Nothing
xlApp = Nothing
Jan 03, 2008 | Computers & Internet
Logitech diNovo Cordless Desktop DH967428 Keypad/Mouse/Keyboard Logo
106 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
