Rca scenium hd50lpw164 hdmi port issue
PS3 was connected via hdmi to tv. Worked fine, until one day I had black screen, no sound. TV screen looks like no signal is coming in. Tried all troubleshooting to rule out PS3 issue, reset all settings to component cables. PS3 recognizes it is connected via hdmi, but when selecting it as a video/audio output it does not work. That indicates to me the hdmi port on the PS3 is still good.
  • Anonymous Jul 11, 2008
    I had the same problem, only HDMI worked for a short time with PS3. It seemed to have stopped after I did the system update (I believe the ill fated 2.40 version).
  • pjmop Jul 23, 2008
    I have the same problem. I think the hdmi port is bad. Any quick fix? Email to pjmop@yahoo.com. Thanks,
    Paul
5 Suggested Answers
  • 4 Answers
SOURCE: PS3 not recognized by Mitsubishi WD=52525 tv through HDMI
FYI,
PS3 has output settings and would need to be adjusted if you are coming from the RCA input. Check out www.sony.com/ps3 trouble shooting under display problems. I believe the solution is to turn on the PS3 unit and keep holding the I/O button for more than 5 seconds. I had the same issue going the other way.
Good Luck.
Posted on Jan 10, 2009
  • 1164 Answers
SOURCE: My Toshiba 62HM95 DLP TV does not work with my PS3
hello, unplug all the cables from you ps3, turn the power off on the ps3 then turn it on press and hold the standby button on the front of the ps3 you will hear 1 bleep then 2 short bleeps after the short bleep relase the button, also turn your tv off then on again, when your ps3 comes back on plug the hdmi cable into your ps3 and then into your tv hdmi 1 on the tv go into the menu find hdmi click on this you should get a picture and sound hope it works
regards
shaun
Posted on Nov 22, 2010
gregs_rockin
  • 274 Answers
SOURCE: Hi. We have an old analog TV (Sony) which has a new digibox running through it (since the switch over). Was fine, but over the last few weeks, intermittently, the screen goes black with EXT 1 in the t
Your picture tube is on the (Verge) Of going.
Posted on Oct 09, 2012
8880u81
  • 3103 Answers
SOURCE: Toshiba Dvd won't work properly with my new TV
if your old tv was an analog one you need a digital converter box to change to the new signal.. new tvs wont recognize the analog signal..temporarily you may be able to use your laptops' dics player as a player for your discs..
Posted on Jan 11, 2014
gopakumarg43
  • 69845 Answers
SOURCE: When CRT JVC TV is first turned on, the image looks shrunken and warped, eventually, the image looks fine. What to fix?
SMPS fault. Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do a search by type in the brand name of your device at its search box.
Check all the electrolytic capacitors.
Posted on May 26, 2014
Mitsubishi rear projection tv, model WS-48311 - Lost audio after moving tv and re-hooking up cables. How do I get it back?
It sounds like this TV is being used only for the PS3. We'll need to troubleshoot this through a process of elimination.
If you're using Component Input 1 and audio, try using Component Input 2 and audio instead. If this set of inputs provides working audio and video - you can stop. Or, try going back to Input 1 once more. If Input 1 now works - you may have simply made a better connection. If it doesn't - then there's probably an issue with input 1 on the TV.
If moving to Input 2 above still didn't solve the problem, you should try using a different set of audio cables between the HDFury and the TV. If it now works, the original audio cables are faulty.
You can check the HDfury setup on another HDTV with component inputs with it connected to an HDMI cable. if the HDFury wors, you know the device and all the cables work. If you do this test and it works with your PS3, then you know that the PS3 is providing good video and audio signals via HDMI. If the problem follows the PS3 - then it's the PS3 at fault. If everything works perfectly on the second TV, then there is some issue with the audio amplifier / inputs / speakers of the Mitsu TV. You could get a cheapo stereo amp and speakers - or a set of computer speakers for audio - it all depends on how much you want to spend for sound.
Good lcuk!
May 07, 2015 | Mitsubishi Televison & Video
Suddenly lost Laptop to Mitsubishi 60c9 connection using HDMI
never plug in hdmi when comp.is on you may burn your hdmi port
Aug 03, 2012 | Mitsubishi WD-60C9 60" DLP HDTV
I am having connection issues with an LG 55lh40 television, a HD DVR from Directv, a PS3 and a DVD/VCR combo. The TV seems to be working good, but does not seem to be picking up an HDMI cable of any kind....
No picture
when connecting HDMI:
Check HDMI cable over version 1.3.
The HDMI cables don’t support HDMI version 1.3, it cause flickers or no screen
display. In this case use the latest cables that support HDMI version 1.3.
Feb 14, 2010 | Televison & Video
57 hitachi ultravsion rear proj hdtv :ps3 hdmi issues
TRY ON THE DISPLAY PS3 SETINGS TO NOT LET THE HDMI DO AUTOMATIC,,CHECK OFF A FEW ,,LIKE TRY JUST DION IT CUSTOM,,CHECK 480P,,AND 1080I,,,NOT 720P OR 1080P,,TRY THAT AND IF YOUR TV IS A 1080P,,JUST CHECK THAT,,OR IF ITS A 1080I,,JUST THAT
May 15, 2009 | Hitachi 53FDX01B 53" Rear Projection...
HDMI PORT STOPPED WORKING!!
the best option here is connect via a standard PS2 avi cable or componet cable until your tech guy comes out!
Apr 30, 2009 | Televison & Video
RCA HD50LPW164
It is very well possible for new lamp to be bad ?
Dec 09, 2008 | RCA HD50LPW164 50" Rear Projection HDTV
FYI,
Good Luck.
Sep 24, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
528 people viewed this question
Top Televison & Video Experts
Electro Med Services...
