Problem when start
When i tray to start pc i hear tree sounds at every two secondes
  • Anand Salunke
    Anand Salunke May 11, 2010
    Can you please tell me your motherboard Model, I can definitely help out. You can also find the reason by checking in Troubleshooting section of your Motherboard Manual / documentation.
    Does the PC boot?? If not, this may be because of failed RAM. try changing the RAM.
  • 68 Answers
What The -Only-Sol said ram is getting cheap if you should open up your PC and check if the ram is loose cant check it then bring your computer to a place that repairs computer but another reason could be that the manufactures did not install the ram (random acess memory) properly also befor bring in your computer in to a shop be sure to call tech support
Posted on Jun 23, 2008
No sound on computer
Exit all programs and then re-boot the computer first to see if the sound returns. If you hear the start up sound, things are probably working.
Here is a link to the Dell support page to investigate further:
http://www.dell.com/support/home/us/en/19/product-support/product/dimension-3000/manuals
Aug 12, 2015 | Dell Dimension 3000 PC Desktop
Why is my pine tree turning brown?
Pines loose up to 20% of their needles naturally every year so you can expect some browning and needle drop. Tip moths and various beetles will gird twigs killing them as well.
Aug 27, 2014 | Garden
I cant hear any sound from the built in speakers
Ensure that the system volume is turned up and not muted. There should be an icon for the volume controls in your system tray at the bottom right of the screen. Or you can click on Start > Control Panel > Sound.
Mar 18, 2011 | IBM ThinkCenter A50 (841937U) PC Desktop
I have family tree maker version 6, i recently bought a macpro and wanted to transfer my files which are extensive. i had to wait for family tree maker mac version which i now have but the files wont...
Try saving a copy of your family tree as a .GED file. for example "familytree.ged" onto a USB drive or disk, then put said disk in your MAC, open family tree maker and try and import your tree.
Files using the .ged extension seem to be the most portable.
Feb 26, 2011 | Broderbund Family Tree Maker Version 6 -...
WF20D4 model of Symphonic TV DVD combo - Dvd tray will not open. When the open buttonis pushed, you can hear a sounds as if there is a gear out of place and it is trying to opwn, but it just will not. Do...
If your DVD tray has a little hole near the bottom like the CD/DVD tray of a typical PC, then
carefully and gingerly insert the end of a paper clip or toothpick into the hole to release the tray.
I think you've correctly diagnosed the sound you're hearing - the transport mechanism has slipped a moving part but the little motor is still alive.
Dec 11, 2010 | Televison & Video
Error c-0910
C-0910
The Lift-up Sensor is not blocked even after the lapse
of a given period of time after the lifting motion has
been started.
Basically your paper tray 2 did not lift right. Open the tray and make sure the paper is loaded correctly. The paper should be touched on all four sides by the tray or by adjustable guides. Open and close the front door with the tray out. Once the machine is ready to copy close the drawer you should hear a slight buzzing sound as the tray rises. If you don't or you hear a banging or grinding sound the tray lift motor may be damaged and you will need to call a service technician.
If the code keeps coming back pull out tray 2, open and close the front door to reset and leave the tray 2 partially pulled out until a technician can repair.
May 03, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
How to clear Malfunction code C-0204
C-0204 The Lift-up Sensor is not blocked even after the
lapse of a given period of time after the lifting
motion has been started.
Apr 08, 2010 | Konica Minolta bizhub C351 All-In-One...
I own a Whirlpool model WBM35LW refigerator, a buzzing noise lasts for about 10 seconds followed by a click. I replaced the start relay and overload but the buzzing continues, all seems normal including...
This is usually a sound coming from the ice maker solenoid. It will buzz while it is energized and letting water fill the tray up and then you will usually hear a clicking sound when it is cutoff and the water is stopped. Sometimes if the water line on the back of the unit is not secured properly you will hear various sounds as the water is suddenly stopped and the line moves around, like a garden hose does.
Sep 29, 2009 | Refrigerators
Sound plays on my system but i dont hear it at all.my windows
Let's start by checking
  1. Your speakers are plugged into the green connector on the computer
  2. Speakers have power, are turned on, and volume is up
  3. Check your "speaker" icon on your tray (lower right hand corner of desktop) - to make sure volume is up and not muted.
Sep 15, 2009 | Dell OptiPlex GX240 PC Desktop
Ice Dispenser on GE Profile PSS23MSTC does not work.
sounds like the ice is stuck together and the auger can't turn. remove ice tray and dump old ice new cubes should begin falling into tray after 30 minutes or so.
Jan 24, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Computers & Internet Logo
329 people viewed this question
David Payne
David Payne
