You need to wire up the pink color wire (handbrake), connect to the handbrake and when you apply it you'll be watching video.
There is two wires at the handbrake, one of them will show you ground when the handbrake is applied, you'll need a voltmeter to check continuity between ground and the wire you trying to connect.
Put the handbrake up, then touch the black lead side of the voltmeter (set at continuity) to ground and the other (read) to one of the handbrake wire, if you hear a beep is because this the the ground wires if not touch the other wire until you hear the beep and connect it to the handbrake DVD wire.
