Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi TV issue
Hi, Did you resolve your blue screen issue. I'm having the same issue and called a repair person today. It seems that many folks had the same issue. Did Mitsubishi fix it for free??
  • jefff1960 Jul 22, 2008
    my 52" dlp screen just went to all blue with only a circle of blue/white static in the center of the screen. I get no picture from cable or dvd inputs. The on screen displays for sound etc show up at the bottom of the screen.
No, they did not fix the problem. I spoke with a non-english speaking customer service representative who kept saying the same thing, you must take the television to a repair depot before we can help you. The nearest Mitsubishi shop wanted $150 to diagnosis the problem. Based on reading the online material it is pretty clear what the problem is related to heat causing capacitors to prematurely fail. My big problem is "do you invest $150 in television that could be replaced for less $1000 with similar technology without any assurance that the company is going to help". From the other post, it appear that the repair is going to be between $600 and $1000. By the time I had finished speaking with the customer service representative, I had concluded that Mitsubshi will not be enjoying anymore of my money. I tried my best to get past the first level customer service person but with no luck. I believe that a conversation with higher level management person would yeild more acceptable results. I would be willing to $200 to 300 to have the repair made.
Posted on Jun 25, 2008
I am having a few probems with my 2005 buck rendezvous. the front driver heated seat does not work anymore, and i have checked under the seat for broken or unplugged wires, i need to check the fuse bu
Heated seat issues are almost Dealer Only repairs
The dealers,some anyway, bring in outside seat folks,
after 5:30 when the service bays closes, to do seats
I am well versed in the heated seat issues
They not only require the dealer techs,the outside seat
folks, they need hours of wire checking & as with my
car, many go on for years & never be resolved
Keep in mind, I'am a 50 year experienced vehicle person,
all be it, retired, I do today's diagnostics on vehicles
The seat & all the other issues can & many to some extend
be on a Network called a CAN as was mentioned on another
question today
Controlled Area Network where modules talk to each other
So your off to a dealer,my suggestion for ALL your issues
Never say a dealer very often,never what I suggest, but
we are going that way with current technology
Nov 26, 2014 | 2005 Buick Rendezvous
Mitsubishi WS-5541 light blue glow
I know these sets pretty well--worked on a lot of them when new and later--one of two possible ideas=
1. Either a odd convergence problem==confirmed or denied by going into the convergence menu (in customer menu) and selecting advanced which will bring up a grid of lines--if see the same issue (I will attach a photo of a Mitsubishi with this problem) it can be fixed.
2. Some sort of issue with the circuit board on the end of the Blue tube(you are missing blue=black) but usually in this set if that happens it is uniform and on both sides of the screen, not the top.
Let me know what you find.
I doubt it is convergence, but does not hurt to look--if the missing area was perfectly rectangular I would suspect up/down centering adjustment.
There is one other possible thing to try--we will leave it for last--set has 3 hidden menus and one is OPTION menu which allows a hard reset of entire set--sets everything back to factory except convergence adjustments which are stored in another area.
Apr 06, 2012 | Mitsubishi WS-55411 55" Rear Projection...
Red and blue streaks across the screen top and bottom
The Convergence Amp IC's are bad. You should call a good TV Tech for this repair.
Jul 11, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Blue screen on WD-52525
Hi, Standby i'll sent you how.for a while
Apr 10, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Distorted picture on a mitsubishi ws-55613 tv
Their is no more you can do.
Seen this before.
You need a professional.
Stop using the TV until it is repaired.
Continue to use the TV and your problems WILL multiply.
Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc
Milwaukee, Wisconsin 53405
(414) 762-8600
Established 1974
Mar 24, 2009 | Mitsubishi WS-55613 55" Rear Projection...
Blue screen with a floating white orb
if you have the blue screen of death your harddrive is going out. The only way to fix this is have the hard drive replaced. If you have a warranty call the warranty company as they will fix this issue. if not try a local computer repair shop to fix it.
Jan 15, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Double vision on my Mitsubishi 46 inch width screen--TV is 5 years old
any repair shop can re converge the tv for you.id do some calling arond and get a few quotes to see what it would cost to have them come to you
Oct 09, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Blue Screen & inputs dont work.....capacitors?
I had the same problem, I called Mitsubishi and they with trouble shooting help, they told me to get a new lamp. Well I got a new lamp and but nothing happens, the tv screen is black no sound, no picture. I went to this site http://servicemanuals.vstore.ca/product_info.php/pName/v26-dlp-fmt-pwb-repair-kit/cName/repair-kits/osCsid/5ac56adb48ff3afdd7ff25c1f1f5cbf2 and with their help, and troubleshooting help, said this kit would work, I just got it today,and I am going to install it now, I will be back to let you know. But I do suggest you go on that site, and try to get some assistance, they sell the service manuals for 16.99$, but if you buy a kit, it includes the manual. Well let us know what happens, and I will be back.
Aug 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Blue Dots
Sony has an extended warranty on this issue right now. You can contact Sony and they will take care of it.
Jan 13, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
