Question about Refrigerators
Amana Side by side
Hot panel between freezer section and refrigerator.
  • Capt Crunch Feb 10, 2009
    I have the same problem with the center strip between the 2 doors becoming almost too hot to touch on my GE Monogram side-by-side fridge.....does it need repair???
    President:
  • 1,462 Answers
This is normal and is to stop condensation on the transom between fridge and freezer
Posted on Jun 23, 2008
I recently purchased a used Amana Side By Side refrigerator that's a few years old. I've recently noticed water on the floor around the bottom of the refrigerator on the freezer side. I don't have the...
you need to remove the rear panel inside the freezer section,inside there will be the evaporator coil/core,below this is a drip pan/drain and they get frozen over,shut off the unit and put a bunch of towels there to catch water as it thaws,then use hot water to hasten thaw,then run a piece of wire down the drain hole,you will need to remove rear lower cover to see when wire comes out there,then after you get it starting to drain,clean out drain tube with hot water and vinegar
Mar 22, 2011 | Amana Refrigerators
My amana side by side refrigerator is leaking on the freezer side ..puddle on floor or starts melting on its own
Defrost drain is clogged with ice and overflows from defrost. Lower section of freezer at the bottom area of the freezer back wall.
Jan 31, 2010 | Amana ARSE66MB Side by Side Refrigerator
I have an Amana Side by Side. The freezer section
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air
check defrost heater, defrost thermostat. If the heater and thermostat are ok it’ll be the adaptive defrost control.Part 13 on this diagram of your fridge controls. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=ASD2625KES&productCategoryId=0165000&brandId=1268&modelName=AMANA-REFRIGERATOR&diagramPageId=00005&componentDescription=CONTROLS&documentId=M0612301&backToLink=Return%20to%20Sub%20Components%20list
Is the evaporator fan in the freezer running.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jul 13, 2009 | Amana ASD2625KE Side by Side Refrigerator
Buzzing noise from back of freezer
need to remove rear panel inside of freezer section. check for normal operation of evap fan motor. check for ice build up on evap.
Apr 21, 2009 | Amana ARS2464B Side by Side Refrigerator
We have an Amana side by side that is only cold on the bottom in both the freezer and fridge. Also the top shelf of the fridge is hot from the light, which does not seem to go off when the door is shut....
amana runs power to the fan thru the defrost sensor that is mounted on the evaporator coil. these sensors will get moisture inside of them and short out causing intermittent fan operation. replace then sensor and your frig will return to normal. thanks for using FixYa peyton
Feb 17, 2009 | Amana ASD 2624 Side by Side Refrigerator
I have a ARS2464B SIDE BY SIDE AND THE REFERATOR SIDE IS NOT COOLING.
unit not going through defrost cycle. build up of frost on rear panel and evaporator in freezer section. check defrost timer, defrost thermostat and defrost heater
Jan 06, 2009 | Amana ARS2464B Side by Side Refrigerator
Extremely hot panel between freezer and refrig sections
Usually is not a fire danger however there is a problem that needs attention. I would recommend that you call a qualified service man for this one as soon as possible.
Nov 29, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerator failed keeping food cold, ice maker stopped working
i would look on the back panel of freezer section, is it iced over???? either its iced over and you have a defrost issue, or if there is no frost at all behind the rear panel yo uhave a sealed system/compressor issue
Nov 15, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Amana Side-by-Side refrigerator hot spot
hi tanks for the question there are heaters at the spots you said were hot and those heaters are there to prevent moist air from hitting cold surface and create warer droplets from forming on those surfaces i would remove the back of the fridge and vacuum it out that should solve your problem thanks the appliance doc
Sep 18, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Amana refrigerator only not working
Few questions first. 1.  What is the entire model # on the sticker inside the fridge section?  2.  Is the fan in the freezer running?  3.  Is there a thick frost build up on the back panel in the freezer (look at the bottom half for a side by side)?
Oct 20, 2007 | Refrigerators
Refrigerators Logo
76 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
