Question about Goodman CLJ30AR32 Air Conditioner
Freon leaking my unit is only 4 yrs old. in the winter it was not working, he put 2# of freon, said that the sequensers needed replaced. Then they came back when summer hit and put in 7# of freon, did not check for leak, and now are saying that they have to come back and empty freon to find the leak, they should have done that when it was almost empty, not just add freon. which was 140.00
  • Goodman Master
  • 1,230 Answers
First, you need to complain to the owner about the tech not informing you that the freon would leak out again. It's addtional costs that were not explained to you. If he's a good guy, he may credit you something if you decide to use him to complete the repair. Otherwise, take your money to someone else. And be sure to tell you friends about how you were treated. Vote with your wallet.
Now, He was not totally correct about finding the leak. In 99% of cases, when a leak is in a system, a detector is used to "Smell" the freon and give a signal that there is a leak So, in this case, freon needs to be in the system. Once the leak is found and verified, there can be no freon present in the section of the system that is being repaired. To keep it short, just a big safety no-no. If the leak is in the indoor coil (evap), chances are, they will not repair it. They will try to sell you a new coil. Since yours is only 4 years old, there is the possibility that there may be some sort of pro-rated warranty from the manufacturer. One never knows, ask about it.
Now, repairing an indoor coil is not a good idea. If it leaks once, it's going to leak again.....and again.....and again. Just replace it as they have to do basically everything it takes to remove it to repair it. You should replace it since it is already out. I do not know of any company that will patch leaking evaps. Just bad business. Customers not happy as other leaks soon show up.
Finally, removing all the freon may not be necessary. Ask him about "Pumping down the system into the condensing unit". This can isolate the entire indoor coil and piping so a repair can be done with minimal lose of freon. Remember, it also depends where the leak is at. It may not be possible to do this in every case.
Good luck and hope this clears up some things for you.
Posted on Mar 20, 2009
Hi... my dehumidifier compressor will not turn on, the fan runs fine and the time 2 hr/4hr cycles work, but the compressor wont kick on, the filter is clean and the unit is no more than 2 yrs old. Any...
Sounds like the compressor is inoperative. Most, if not all new units have no means of recharging the freon if it leaks out. If the coils are not cooling, the compressor is not operating and the unit will not dehumidify.
Jun 26, 2011 | LG LD65EL Dehumidifier
Last couple of years if our thermostat is set below 74 the ac will freeze up. The last 2 years we had it checked out and were told that 1)coils might be going out and 2) needs more freon. Once freon was...
If your going to have all the freon taken out,this current tech needs to find the leak.
Clearly from what you have said the unit has a freon leak.Freon is put in by ounces or pounds depending on the size of the unit,then you need to get the correct operating pressures.Coils do not go bad they either get full of dirt or get a hole in them.
An 8 yr old unit is a tough call,surley a new one will probably save some electric and come with a warranty.I would get some quotes on a new one,then see how much i could spend.
May 20, 2010 | Fujitsu Heating & Cooling
Freezer wont work after defrosted
Please keep in mind, I'm attempting to diagnose you appliance without being there and with very little info. Thanks
If the sound is a double click, then after about 2 or 5 Min's another double click. You have a bad capacitor.
If it's a low hum. It sounds to me like you have a low side leak in your freon sealed system. When you unplug the unit, the freon pressures equalize. This put higher pressure on the low side of the system than it has when it's running. If you have a low side leak, it will drain out under the higher pressure.
(Industury standard- 5 year warranty on all sealed systems) This means that if your unit is less than five years old and it is a sealed system problem. (Freon leak, Compressor) The factory will cover parts and labor. You should not need a receipt if it's less than 4 years old.
Sep 22, 2009 | Whirlpool ET4WSKXS Top Freezer...
Freon has to be added for the 3rd year now in unit only 2 yrs 8 mos old. Installer cannot find leak in condenser or inside unit. What could be problem?
installer has no patients. leaks are hard to find if they are small. some times you must use soap and water to find small leaks bubbles will show quicker. or pull charge from unit and charge with nitrogen to a higher pressure and low side of unit may be where leak is coils can be a major problem for so many tubes to trace but time and patients is the answer. leak detectors that are used are great for larger leaks but if the detector isn't kept calibrated this go wrong, thats why i'll go to the old method of soap and bubbles
Aug 23, 2009 | Ruud Heating & Cooling
Compressor freezes up at night and some during day.
You are being ripped off. The ambient (outdoor) temperature at night is low and therefore proper condensing does not take place causing the refrigerant to pool in the condenser and starving the evaporator. This causes a lower temperature in the evaporator resulting in "freeze up" which is often mistaken for a loss of refrigerant.
The proper thing to be done is to block off the condenser air causing the high side pressure to rise until the eqivillant of 110*F condensing temperature.
You can also install a low ambient kit which will cycle the compressor off when the temperatures fall
Jun 07, 2009 | Weather King 12AJA4801AH Air Conditioner
Coil leaking freon on the inside unit. Estimate is $2,100!
If indeed your evaporator (indoor) coil is leaking, the best option IS replace it (it may not even BE repairable). If you live in the USA and your furnace is getting old, a new ultra high efficient SYSTEM that qualifies for the tax credit would probably be a better option (Obama will pay 30%).
May 09, 2009 | Carrier Heating & Cooling
Sounds like you have a freon leak or your compressor has stopped working. You will probably need a service tech. If it is out of freon, don't let them just add more freon, make them find and repair the leak first. Good Luck.
Mar 27, 2008 | Intertherm P3RA-048K Air Conditioner
Goodman CLJ30AR32 Air Conditioner Logo
198 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
