Noise when the typewriter is conected
I have an electric typewriter Sears 1000 I hear a noise when I try to conect to the power surce.
  • scomanoz Jun 24, 2008
    I have an Olivetti ET Personal 50, it will power up but as soon as I push any letter key it makes an error sound that will not stop till i turn it off and on again
  • Jim Keysor May 11, 2010
    What kind a noise? electrical, motor, etc
    Scholar:
  • 183 Answers
Two different machines and problems.
on the sears mach. need more info. make sure mach. is turned off when you plug it in. does it still make a noise? does it make the noise when you turn the mach. on? what kind of noise. does it still work?
on the olivetti, check the ribbon. if it is at the end, the mach. may not work. replace ribbon. check to make sure printwheel is latched into place and the cover is down. if it still doesn't work it may need a new main board.
Posted on Oct 30, 2008
Www magicjack comfaq
Try moving your Magicjack to a separate outlet away from any
other electrical lines.
Jul 25, 2014 | magicJack Plus Pc To Phone Adapter
What color wires go to power switch and circuit breaker
If you use the code of NEC(National Electric Code) will be Red and Black and white.
However will be differences with this. In short black to any point and red to any pointsince you are trying Alternating Current VAC , There are No polarities need it,such inContinue Current. VDC, you must be carefully to conect the white wire to ground, will VERY CRITICAL.You can conect whatever will be the color in any point except the white color.sincerely.Will be a good idea for you to open the Male receptacle from power cord, and follow the wires codes. Except the white for the reason explain. If the wires changes for examples to yellow-green this will be the ground instead of the white.
sincerely.
Nov 21, 2011 | Nordic Track Nordictrack Exp 1000...
ERROR SC 547
Zero cross signals are not detected within a certain period within 500 ms after the main power switch has been turned on.
Possible Causes
• Power supply board defective
• Noise on the ac power line
Try conect the copier in other side.
Disconnect all the household-electric of the place.
Feb 20, 2010 | Ricoh Aficio 450 Copier
Car shut off while i was driving i tried to start it again but it would not start now the car had develop this knocking noise when ever i start in the morning and wen ever it sat for long.Now when the car...
sounds like the electrical system is being grounded out track all recently added accessories, amps radios etc. dosent really bsound good about the noise in the morning, but still sounds like electric short.
Sep 22, 2009 | 1994 Honda Accord
Your HDTV does not support HDCP
This is normal in HD 4250.Problem is ( box software).You need to disconnect HDMI cable from the box,or leave TV "ON" during recording.
Apr 04, 2009 | Sony Playstation 3 (PS3) Console
My passenger side window will not move up or down at all.
1: an electical problem (blown switch, blown motor, loose conection...)
2: a broken regulator (pressing the window switch, listen for the motor in side the door too make noise. if you can hear the motor but the glass doesn't move it's your regulator, if you can't hear the motor it's electrical).
Jan 25, 2009 | 1994 Nissan Quest
97 ford escort will not start
check all your conections clean with a wire brush sounds like a bad conection. let me know. Phil
Jan 12, 2009 | 1997 Ford Escort
1998 dodge ram 1500 starting problem
check the charge on the battery. then maybe your starter is out.
Jul 19, 2008 | 1998 Dodge Ram 1500 4WD
If you are using the internet and someone uses the house phone we lose internet conection
Do you hear any static noise when using the phone? if there is noise there is a problem in your telephone line, try contacting your internet/telephone provider.
Jun 18, 2008 | Belkin Computers & Internet
112 people viewed this question
jasbo
jasbo
