Reports you can print
You can print these reports whenever you need to. Some of these reports can be set to print automatically also.
1. Press Report/Help.
2. Choose the report you want by using left or right arrow.
3. Press Start/Enter when the desired report is displayed.
4. The selected report will be printed.
Sending Confirm
A confirmation report shows whether the transmission was successful or not,
how many pages were sent, etc.
ON: prints a confirmation report automatically each time you send a fax.
OFF: never prints a confirmation report (You can print one manually using the
Report/Help button (see Print reports on page 51).
ERROR: prints only when an error occurs.
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 3.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
Fax
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and
receive.
