Question about Microsoft Windows XP Professional for PC
Win 32 virus
Can u plz tell me how to remove win 32 virus
it has affected my all HDD DRIVERS
new folder is develop in each drive with name 1.0.0.0
my TASK MANEGER IS DISABLE
plz tell me de solution to remove it
how much pain it will give to my pc
my email id is booshan@gmail.com
  • 282 Answers
Try to scan using malwarebytes found at malwarebytes.org
Posted on Jun 25, 2008
AutorunRemover Autorun Virus Remover license code
Your note book is virus affected.
Try to system restore in earlier date. Follow the step
How will you confirm?
Follow the steep. Press win key +R >type gpedit .msc and soon an windows will open.
Press win key +R>ms config and soon an windows will open.
Press win key + R REGEDIT an windows will open soon.
Go to tools option >folder option >view>check on show hidden file
Check off hide protected operating system file
Check off hide extension known type file.
BUT still there are no hidden file in drive C:
Think your computer has affected by serious virus.
>start>program>accessories>system tools >system restore >set earlier date. If you have the strong virus you can not do that, then you should better to copy your data if necessary
follow step>set your hard disk in another computer .before install be ensure that .another pc is well condition.
>show hidden folder can see all system file >can open task manager>run type ms config >enter, it will be open windows>run type gpedit.msc> enter, it will be show.>run type regedit enter ,it will be open .think your another pc run in ok condition. Then type gpedit.msc and hit >administrative templates>system>turn off auto play>select enable>click down arrow >select all drives.
SET IT FROM BOOTH SIDE BECAUSE THERE ARE TWO SIDES >Go tools> 1 folder options>views>check on show hidden files and folders>2 check off hide extension >3 check off hide protected.
Now auto run program off. you can see and delete easily all the hidden unnecessary file .auto run file. Placed virus affected hard disk in this pc.explore drive select autorun/recycler/system volume information by dragging and delete it. Don't do the system drive for ensure r click on my computer >manage>disk management>identify system drive >and system drive letter>
Now You can copy your file and store in another drive which formatted emediate.And you can format drive one after one and transfer all the file to the formatted drive .Switch off the pc and put your pc again and install your os and set the pc same way Then type gpedit.msc and hit >administrative templates>system>turn off auto play>select enable>click down arrow >select all drives.
If you did not have the cd rom , you should create a bootable flash. follow the link.
http://articles.techrepublic.com.com/5100-22_11-5928902.html
If you want remove manually 1st click here or http://amiworks.co.in/talk/how-to-remove-new-folderexe-or-regsvrexr-or-autoruninf-virus/
If you want remove manually Autorun virus 2nd click hereOr http://www.wikihow.com/Remove-Autorun-Virus-from-Hard-Disk-Drives
You want to save your data download
http://www.hiren.info/bootcd-on-usb-disk
Write cd with the ISO and restart pc cd will start soon, click here or http://www.windowsreinstall.com/articles/bios/ for BIOS SETUP and go mini windows and deletesystem volume information and RECYCLERfrom all drive except "C"
drive. Because Heart Of Castle.If can not remove download bootable f cecure,click here or http://www.techmixer.com/free-f-secure-rescue-bootable-cd-to-clean-virus-and-malware/b>And write the ISO and boot from CD at the start time.SET THE BIOS SETUP for BOOT FROM CD
http://www.windowsreinstall.com/articles/bios/DONT USE KAV because it will delete your windows file
Now you will install and just delete C drive and create C drive same andinstall.
Installation guide click here.http://www.microsoft.com/windowsxp/using/setup/winxp/default.mspx
Hope this helps. Let me know if you need more informationThanks
shibuda
May 11, 2011 | Computers & Internet
My dell inspiron 1501's card reader will not work. Even when I insert a memory card, it will not work. I have downloaded and installed the card reader drivers under chipset on Dell's website.
If you want remove manually Autorun virus 2nd click here Or http://www.wikihow.com/Remove-Autorun-Virus-from-Hard-Disk-Drives
drive. Because Heart Of Castle.If can not remove download bootable f cecure,click here or http://www.techmixer.com/free-f-secure-rescue-bootable-cd-to-clean-virus-and-malware/ b> And write the ISO and boot from CD at the start time. SET THE BIOS SETUP for BOOT FROM CD
http://www.windowsreinstall.com/articles/bios/ DONT USE KAV because it will delete your windows file
Regards
shibuda
Jan 06, 2011 | Dell Inspiron 1501 Notebook
I can not save any data nor can i create a folder on my 2GB sandisk. Originally it was ok, i have even formated but i cant save anything on it. it says access dened, maybe right protected ,i dont know...
check your pc is not affected by virus
....................follow the steep for check your pc isnot affeted
go run write gpedit.msc and enter if it open or not if it open may be ok your pc
regedit ,,
ms config ,,
go tools> folder potion> veiw>check of show all hidden folder file look C drive if you can see there are some hiden file it is ok
or prees allt+ctrl+del or r click on task bar try to open task maneger if it is not open think your pc affected
if all these progame can not open your flash drive can not work proper .you should better format your pc stop autorun.exe then you format your flash drive.after these your pen drive can run proper
Nov 11, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How do I delete or repair the threat to my Laptop system that has
HOW TO REMOVE RAILA ODINGA VIRUS IN 2 MINUTES
How to remove raila odinga virus is a very easy process. Firstly, Raila odinga is a worm that attacks Microsoft word files, but it looks like a JPG file and mostly found on the desktop.
Raila odinga has some common characteristics
1. If you delete the picture file it will delete and return to where it was.
2. It runs from the driver folder in system 32 folder
3. it auto runs at system startup
4. It makes the computer boot slowly
5. It makes your computer to hang.
6. It creates new folder.exe folders in your computer
How to remove raila odinga virus, open my computer, double click drive C: open WINDOWS folder, double click on system 32 folder, open driver folder,
locate the word file in the folder, note the name. Right click on the task bar, open task manager, click on the process tab locate the name of the word file you saw in the drive folder, right click on the name of the file, click end process, to terminate the running process
Open the driver folder of system 32 where the file is, delete all the ms word files on that folder, then close the folder locate the raila odinga picture file usually on the desktop or somewhere in your computer, delete the picture file. Please do not double click on the picture file only delete it, finally empty your recycle bin and restart your computer. That way odinga is off your machine.
Mar 25, 2010 | Computers & Internet
Window can not find gphone.exe
gphone.exe is nowadays one of the most dangerous virus spreading very fastly.Its a trojan and changes your IE homepage and sends tries to open gtalk and yahoo messenger.It even sends messages to gtalk contacts.Its icon is just like that of folder icon and people thinking of folder click on it get infected by the virus.
Gphone virus basically is a 260 kb .exe file which looks like a folder and it can take any name of any other folder if you have clicked on the virus folder which looks like a folder but it isnt.If you have a folder name “comptalks” in your D drive it will make a exe file in the folder named comptalks.exe and if you click on that exe file it too work as a virus.It makes .exe files in all the folders you have with the name of the folder.
To remove the gphone.exe virus you just need to follow simple steps:
Go to Task Manager ->Processes and then click on gphone.exe and click on end process.
After that manually go to folder where gphone.exe is present and simply delete it.
Or simply search for the exe file clicking which started sending messages through gtalk. If you clicked on 1.exe search for that file on task manager and then delete it.
Good luck.
Sep 02, 2009 | Microsoft Windows XP Professional With...
Doesn't show any files and folders when drive opened
Congrats, You got a nice virus. Its better you backup your drivers and data from ur root partition format it. reinstall your operating system and install avg 8.5 before browsing any of the other partition. I can surely tell u your task manager, registry editor or show hide folder won't be working. There is no permanent solution to this other than format. But beware don't browse other partition before installing avg 8.5. Your earlier installed antivir has given its way to virus its of no use. You won't be able to install antivirus or visit any malware removal virus site. welcome back.
Jun 14, 2009 | Western Digital Passport WDXML800UE...
Remove W32.Sality.AE Virus from my win2k server
hi..
w sality 32.ae is a virus, it infects the memory of the computers(RAM).you can remove this virus by downloading and installing a FREE anti virus..
download it from here..
http://www.free-av.com/en/trialpay_download/1/avira_antivir_personal__free_antivirus.html
please click above and download the free of cost anti virus..this anti virus is free for whole life and it is not a trail version.
WAS I HELPFULL, PLEASE RATE ME
GOOD LUCK :-)
Mar 21, 2009 | Xplore Technologies iX104C3DV
Drive not opening
To solve this error, follow this steps:
1>> Run Task Manager (Ctrl-Alt-Del or right click on Taskbar)
2.>> Stop wscript.exe process if available by highlighting the process name and clicking End Process.
3.>> Then terminate explorer.exe process.
4. >>In Task Manager, click on File -> New Task (Run…).
5.>> Type “cmd” (without quotes) into the Open text box and click OK.
6>>. Type the following command one by one followed by hitting Enter key:
del c:\autorun.* /f /s /q /a
del d:\autorun.* /f /s /q /a
del e:\autorun.* /f /s /q /a
c, d, e each represents drive letters on Windows system. If there are more drives or partitions available, continue to command by altering to other drive letter. Note that you must also clean the autorun files from USB flash drive or portable hard disk as the external drive may also be infected.
7. In Task Manager, click on File -> New Task (Run…).
8. Type “regedit” (without quotes) into the Open text box and click OK.
9. Navigate to the following registry key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
10. Check if the value name and value data for the key is correct (the value data of userint.exe include the path which may be different than C drive, which is also valid, note also the comma which is also needed):
“Userinit”=”C:\WINDOWS\system32\userinit.exe,”(correct this)
If the value is incorrent, modify it to the valid value data.
Aug 13, 2008 | Microsoft Windows XP Professional for PC
Hello, I am experienceing difficulties with my PC. I can't access to any folders and cant open the start menu.
You might have a Virus. In the case of a Virus infection I would most likely disconnect the Hard drive from the machine, scan it on another machine ( using AVG7 + AVGAS = AVG Antivirus and AVG Anti Spyware Scan) remembering to turn off system restore while scanning on the drive.
If you have successfully found and removed the virus infection, remember to delete your system volume information and recycler folder on the drive. virus files tend to infect these folders.
When you plug in your HDD into your machine again, you might want to do a Windows repair; to fix the issues that the virus has caused OR use a registry repair tool to repair registry items. Another option would be to create a new user name. The settings in that new accound should be working fine and you should be able to access the start menu and your folders again.
Apr 17, 2008 | Computers & Internet
How can i remove virus worm/autoit permanently
its simple guys..!!!
if it asks for permission to access outlook..don't permit it because it is a smart virus and is going to spread it to all the people on your contact list...!!!
simply open task manager and end process tree of KHATRA.exe , gHost.exe , xplorer.exe and OUTLOOK.exe seperately...!!
then run your anti virus or download one if you don't have one..!!!
run a complete computer scan in detail..!!
then delete all files which are infected by the virus because the results contain only duplicate files which are created by the virus
Feb 04, 2008 | Acer TravelMate 2300 Notebook
Microsoft Windows XP Professional for PC Logo
70 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
