Question about ASUS P5ND2-SLI (890552603831) Motherboard
Cleaned, now it dont work!
I cleaned out my new computor and took outall the psu wires from there sockets, i left it over nigth and re-pluged the wires. now when i switch on my computor it goes to the MOBO screen and then shutts off, however the LEDS on the MOBO stay on. any ideas?
    President:
  • ASUS Master
  • 1,314 Answers
Reseat all the cable, double check to make sure every place that a cable goes, there is a cable there, especially the four pronged one near the CPU.
Posted on Jun 23, 2008
2007 ml320 cdi left brake light will not come on
It is apparent that the wire between the current sensor that the computer monitors and the left brake light socket is open. Thus the computer knows the brake light is not working because it is not drawing current. If you have a wiring diagram, you can probably find the broken wire or bad connection. This may take some time. To get the left brake light working, you can jumper the left brake light socket to the right brake light socket. Warning, this may cause the computer to register the extra current on the right side as a short circuit and shut both off. If that happens you will have to forgo the left brake light until you get the open circuit corrected.
Apr 22, 2014 | 2007 Mercedes-Benz ML320 CDI
Asus P5GC-MX/1333 system wont boot up, motherboard light on (blinking), fans on PSU not working, fan on motherboard not working, is that a sign PSU went bad? (it was OK a few days ago)
yes
it can be problem wth psu hence insert a wire in green socket and another in black socket of psu and this will short and psu fan will rotate. if psu fan rotates then you need to check the voltage supplies of the psu.
Apr 01, 2014 | ASUS Computers & Internet
Ethernet dont come on,and keyboard,and monitor dont work
HAVE YOU CHECKED SO PSU ARE ON.WHITOUT PSU NOTHING.
Apr 04, 2013 | Computers & Internet
Left read stop/blinker light bulb does not work. Left front blinks fast. I insatlled a new bulb and the problem persists
Almost all problems like yours are caused by a faulty ground at the socket. Check the left rear socket for corrosion, clean it with a wire brush, steel wool, or sandpaper if necessary, and make sure that the ground wire running from the socket to the chassis is clean and intact. The fast flash at the front is just to let you know that the rear is not working.
Bill B
Apr 10, 2010 | 1994 Chevrolet Suburban
Front right blinker does not work back does,i took the working blinker from the left, and that doesnt work either
Sounds like the socket is bad or you have a short in the wiring. You can test it with a multi meter to see if you are getting power to the socket. Also look for any corrosion and clean it out if necessary. Look over the wiring for any signs of broken insulation or heat damage (blackened or melted insulation). Good luck and hope this helps.
Jul 15, 2009 | 1996 Suzuki X-90
Immediate RROD and fans only run for a second
Hey i had the same prob after x-clamping took it all bk out of the caseing same, then i unpluged the dvd player it worked fine pluged it bk in and havent hade a problem yet defantly worth u trying
Feb 12, 2009 | Microsoft Xbox 360 Console
1990 acclaim signal and brake lights
You need to check for power & ground at left rear socket, and clean it & contacts in it well, and may have to squeeze socket a bit to supply better ground to outside of bulb base. If that doesn't work, poke wires going into back of socket with test light, with signal on, and if power present, replace the socket assy. About $5.00
Feb 12, 2009 | 1990 Plymouth Acclaim
The system fails to boot up after a new power supply was added
There should also be a brand - the nVidia just relates to the chipset that the board uses, but its OK, lets check the wiring first.  If we still have trouble I'll get you to double check for the brand name.
Lets just check that you have the following plugs in place:
  1. The 24 pin plug from the PSU (blue) to your motherboard - this powers the board itself.
  2. A 4 pin 12v P4 connector plugs into the motherboard (near the CPU).  This is the CPU power.  It runs from the 8pin blue socket on the PSU.  Make sure that the end plugging into the motherboard is only 4 pin.
  3. No power cables required to run the 8600GT so the red sockets on the PSU are empty.
  4. Power cables going to all your peripherals (hard drives and CDroms).  These run from the black sockets on the PSU.
Does your current setup match that?
Nov 12, 2008 | EliteGroup NFORCE 570 SLIT-A Motherboard
My hard drive is not working!!!!
You can access your HDD from the old computer but cannot boot your HDD from that old computer. I think you down load a file with virus, maybe your computer was infected with virus coming from that crack. Means you have to re-install your computer.
Oct 20, 2008 | ASUS P5QC Motherboard - Intel P45, Socket...
ASUS P5ND2-SLI (890552603831) Motherboard Logo
57 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
