Question about HP DesignJet 1050c InkJet Printer
ERROR CODE 04C400 - WHAT TO DO, WHAT IS IT
PLOTTER STARTS TO INITIALIZE, MOVING TO LEFT ABOUT 1/2 TO 3/4 WAY IT GIVES ERROR 04C400, PRESS NETER TO CONTINUE. iT THEN SAYS INITIALIZING BUT NEVER CHANGES. wHAT TO DO?
  • JWITZEL Jun 24, 2008
    The machine is actually a 1055cm plus. I f this matters
Pulled Harddrive and ethernet card, no error. Installed hard drive started machine, no error. Installed ethernet card, restarted machine got error. I am now replacing the ethernet card to resolve issue.
Posted on Jun 24, 2008
How to enter service mode in canon ipf605
Ansewer
Enter the Service mode following the procedure below.
1) Turn off the printer.
2) Turn on the printer while holding down the [Paper Source] button and [Information] button.
* Keep pressing the above buttons until "Initializing" appears on the display.
3) "S" is displayed in the upper right corner of the display showing the version.
4) After display of "Online", pressing the [Menu] button displays the SERVICE MODE top menu and the MESSAGE LED flashes.
Aug 05, 2014 | Canon imagePROGRAF IPF605 InkJet Plotter...
During initialisation it shows dat there is jam
during the warm up cycle the carriage has to reach both ends of the scan platten if for any reason it is not able to achive this it throws the error Paper jam or 86:01 ( both mean the same thhing)
what you need to do:-
1) disconnect the plotter from the mains
2) open the central lid and using a torch look carefully along the carriage path for any obstacles or debris that may interfere with the carriage motion.
3) assuming there is no obvious blockages look carefully at the carriage drive belt to see if the imprinted teeth have worn off you may also see what looks like mouse droppings on the print platen
4) remove the right end cap - move the sercvice staion out of the way of the carriage and then gently ease the carriage to both left and right extents checking all the while for debris, leave the carriage on the left and leave the service station out of home position, return the mains lead and allow th plotter to initialize checking to see if the plotter is able to move both assemblies as required.if not then call out a qualifed enginner to replace defective drive belt or carriage assembly or indeed the service station
Jul 05, 2013 | HP DesignJet Z2100 InkJet Photo Printer
I have a problem Taskalfa 250ci eror code c0640 I think at Hdd problem. But I don't know how to hdd format
Maintenance
item No.
U021
Memory initializing
Description
Initializes all settings, except those pertinent to the type of machine, namely each counter, service call history
and mode setting. Also initializes backup RAM according to region specification selected in maintenance item
U252 Setting the destination.
Refer to *1 of the maintenance mode item list about the item initialized.
Purpose
To return the machine settings to their factory default.
Method
1. Press the start key.
2. Press [EXECUTE] on the touch panel.
3. Press the start key. All data other than that for adjustments due to variations between machines is initial-
ized based on the destination setting.
4. Turn the main power switch off and on.
For errors occurred, turn main power switch off then on, and execute initialization.
Error codes
U024
HDD formatting
Description
Initializes the hard disk.
In addition, the following settings are also initialized by initializing the hard disk.
System menu (user login administration, job accounting, address book, one-touch keys and document box
etc.), shortcuts and panel programs
Purpose
To initialize the hard disk when replacing the hard disk after shipping.
Method
3. Press the start key to initialize the hard disk.
Description
Codes Description
01 Configuration initialization error
02 Counter initialization error
20 Engine initialization error
40 Scanner initialization error
2JZ/2JX/2JV/2H7-5
1-3-23
Apr 15, 2013 | Kyocera Taskalfa 250ci Color Copier...
Error code E161-403F
I have had two of my Canon plotters give this error.message, I had to manually move the carriage unit and replace the printhead. On one of the plotters the error message returned, on the second plotter I was able to go into service mode where it asked me to replace the printhead. I just went though the motions since the printhead was brand new and I was able to get the plotter to function correctly.
Mar 05, 2013 | Office Equipment & Supplies
Fuser error 440
turn off copier while turning back on press 0 and 8 simultaneously then press 400.. neter value 0 then press interrupt.
Apr 04, 2012 | Toshiba e-Studio 350 Copier
X axis error comes on the computer screen which is connected to the investronica p2000/1 plotter.
When does it happen?
When you load Plotwin and try to move the head to the physical origin of the plotter or when you launch the job.
These plotters have a lot of problems with carriage and belt so it's hard to give a useful suggestion.
Aug 04, 2010 | Office Equipment & Supplies
1. PEN NOT LIFTING. HOW DO I ADJUST PEN LIFT 2.PAPER SKEWS TO LEFT 3. NEED SERVICE MANUAL ON SUMMAGRAPHICS PLOTTER HI7200
Installing Pens
Most types of disposable pens must be activated before using the for the first time. If you are installing a new disposable pen:
  1. Press down on the pen cap to break the internal link seal.
  2. Holding the pen with its tip pointing down, shake the pen to start the ink flow.
  3. Remove the cap and test the pen for ink flow on a scrap of paper or media before installing it in the plotter.
    Some types of pens require adaptor sleeves to fit the pen holders in the pen changer and pen carriage. Insert each pen into its adaptor sleeve, if required, before installing it.
Using the Pen Changer
You may find it easier to temporarily raise the pen changer arm to install pens. Press the widest part of each pen into the jaws of each stall in the pen changer. After installing all the pens that you plan to use, lower the pen changer arm until it latches into place.
Notice that the pen changer stalls are numbered 1 through 8 from right to left (viewed from the front of the plotter).
Note: Make sure that the pen changer arm is in its lowered position and latched into place each time you power on or reset the plotter so that the plotter will correctly change pens.
Operating Without the Pen Changer
For operation without the pen changer, position the pen changer arm in the raised position and install a pen directly into the pen carriage by pressing the widest part of the pen body into the jaws of the pen holder on the pen carriage. You can still produce multi-pen plots, if desired, by enabling the PEN PAUSE parameter--------------Online KeyThe Online key toggles the plotter between on-line and off-line operation. The mode is displayed with each key press.
The plotter is initally in the on-line mode at power-on. In the on-line mode, plotting operations are enabled. When media is loaded in the plotter and the plotter has been selected (see below), an on-line plotter begins executing plotting commands from the input buffer as soon as they are received from the host computer.
In the off-line mode, the plotter can still receive data into its input buffer if it has been selected, but plotting operations do not begin until the plotter is switched on-line. The plotter can be operated manually in the off-line mode using the following control panel keys:
  • Pressing the left or right arrow key moves the pen left or right.
  • Pressing the up or down arrow key moves the media in or out of the plotter.
  • Pressing the PEN SELECT key accesses a menu to select a given pen from the pen changer.
  • Pressing the PEN UP/DN key raises or lowers the pen.
Pressing the Online key during plotting switches the plotter off-line and suspends plotting.
Pressing the Online key again will cause plotting to resume at the point of suspension. ------------------Pen Up/Dn Key
The Pen Up/Dn key raises and lowers the pen when the plotter is off-line. If there is no pen in the carriage, pressing the Pen Up/Dn key causes the plotter to retreive the currently selected pen from the pen changer (if the pen changer is installed and is in the lowered position).
Note: After approximately two seconds of no pen movement, the plotter will automatically raise a lowered pen to prevent ink from bleeding on the media, until the pen is moved again. If the pen is not moved for the period set for the AUTO-CAPPING parameter , the plotter will return the pen to its pen changer stall. To restore the currently selected pen to its previous position on the media, press the Pen Up/Dn key or an arrow key. Pen Select Key
When the plotter is off-line, pressing the Pen Select key allows you to select a pen from the pen changer. After pressingPen Select, press the <-- --> keys until the desired pen number is displayed on the lower line of the LCD, then press the Enter key. The plotter will retreive the selected pen from the pen changer.
The Pen Select key is also used in the Configuration Menu,
Oct 16, 2009 | Computers & Internet
Canon ipf 8000 Error Code E161-403F
Feb 21, 2009 | Canon imagePROGRAF iPF8000 Printer
HP DesignJet 1050c InkJet Printer Logo
309 people viewed this question
Seeker5211
Seeker5211
