Audio cable for lcd monitor for cpu
Samsung 19" lcd monitor for cpu audio cable .which type?
  • Hjalmer Lamminen
    Hjalmer Lamminen May 11, 2010
    A usb cable is what you would use. This should give you video and audio.
    What ports were you trying to use for it?
    President:
  • 1,314 Answers
A USB cable????? How about just a regular audio cable. Plug one end into the audio input on the monitor and the other one into the audio output (usually green) on the back of the tower.
One just like this.
Posted on Jun 23, 2008
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Audio Player... Master
  • 1,001 Answers
  • High Sound Quality ensure the cleanest sound experience possible; No need to remove cases during use; 3.5mm Auxiliary Audio Cable for Headphones, iPods, iPhones, iPads, Home,Car Stereos and More
Chornic Premium 3 5mm Auxiliary Audio Cable for Headphones iPods iPhones...
Posted on Dec 07, 2016
Samsung flat screen computer monitor will not turn on.
check power cord also the cable from the monitor to the cpu
Jan 20, 2011 | Samsung 192n 19 in. Flat Panel LCD Monitor
When i plug to the cpu monitor cut off the power and green light is blinc
Do one think just plug out Monitor to CPU cable , just on monitor only if so can you able to see one small icon go top to bottom its like keyboard, if you can see that, you don't have any problem on your monitor.
step 1 - just remove ram slot and insert again try to ON your system now
step 2 - take your cpu and connect to other monitor and check where it getting on or not , if monitor get ON and work good mean you don't have problem with your CPU , problem was in monitor to cpu cable ,so change your monitor cable its just cost of 4 to 5 $.
step 3 - take your monitor connect to another CPU , check weather you getting same problem if it work good mean, your CPU motherboard have problem just call your hardware engr to solve it,
GOOD LUCK ! if your problem solved don't forget to rate
Dec 31, 2010 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Can't find the place to put in speakers for syncmaster 192n monitor
lemoncaketre, 192N is basic VGA only type monitor!!!! No AUDIO capabilities!! Use a set of external speakers for audio!!!
12fixlouie
Sep 14, 2010 | Samsung Syncmaster 192N 19" LCD Monitor
Hi , I own a viewsonic LCD monitor model va1912w. My system has Windows XP. There is no sound from the monitor even after connecting the sound cable from CPU to monitor's audio jack. I have already...
http://www.viewsonic.com/support/downloads/drivers/?prod_name=1912
Try the above link for Vista or XP drivers which may be used with Windows 7 in some cases.
The va1912wb came up when I searched under 1912.
This driver is available directly from the viewsonic.com site.
Uninstall the other driver if possible.
Aug 08, 2010 | ViewSonic VA1912w 19" LCD Monitor
No signal
check whether signal cable is connected or not connect it properly and latch the nuts also.the fault may lies in the cpu not in the monitor
Apr 11, 2010 | Samsung SyncMaster 940MW 19" LCD Monitor
Monitor speakers
you have to connect the Audio cable from audio out the back of your CPU ...into the back of the monitor ...
Sep 12, 2009 | Hannspree 19" Widescreen LCD Flat Panel...
Monitor doesn´t work
1 MAKE SURE THE DATA CABLE IS CONNECTED TO THE CPU.
2 MAKE SURE TO TURN THE MONITOR ON.
Aug 05, 2009 | Samsung SYNCMASTER 943B 19" LCD Monitor
HP 19 IN. LCD MONITOR
its so simple problem on screen what come no signal rigt
so u have to do this just chek ur monitor cable its not pulg in cpu
so reconnet ur monitor cable in your cpu
thnx using fixya
Mar 30, 2008 | HP f1905 19" Flat Panel LCD Monitor
Turns off when a signel is connected to it
Try to connect LCD to another computer.
If it is ok something then went wrong with your PC.
Either your display card defect or the CPU need to reinstall the OS (operating system).
Nov 19, 2007 | Samsung SyncMaster 913V 19" Flat Panel LCD...
396 people viewed this question
 Grubhead
Grubhead
