FixYa.com
Tags:
JVC AV-56WP74 56 in. Rear Projection HDTV-Ready Television
JVC AV-48WP74 48 IN
posted by zerp on Jun 23, 2008
My TV has a red image like 3D or a red shadow. I've read other people have had the same problem and what they needed was the STK 392-110. I appreciate any assistance you can give.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jun 27, 2008
Not Rated (0)
easyab
Rank:Wiz Wiz
Rating: 80%, 6 votes
Hey Zerp,
You need Convergence IC's. It is more difficult than batteries on a remote.
You access the convergence board through the inspection plate that is located behind the front speaker grill.
You remove the board, determine if any resistors are burnt, replace any burnt or out of tolerance resistors, replace 1 or 2 IC's and re-install the board.
Now you have to adjust it to look like new.
If you live around Calgary, try me instead:
http://calgaryconvergencerepair.weebly.com/convergence-explanation.html
or try the find a repair person part of this website, maybe you will be lucky and someone is listed nearby.
Most rookies doing this job will cause damage and not be successful, and pay double for someone to fix their mess.
easyab
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Projection Televisions problems?
JVC AV-56WP74 56 in. Rear Projection...
JVC AV-56WP74 Convergence part...
My TV's convergence went out... Answer This...
red color trouble
my projection tv has a red... Answer This...
JVC 56in. is broken
My rear projection tv isbroke... Answer This...
52 inch jvc projection tv, cant...
i cant get any movie to fit the... Answer This...
Flashing green power light on...
It?s a 52? RCA HDTV SRS Focus... Answer This...
Repair Service
Find Projection TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
