Question about Sony Televison & Video
Kdf 60wf 655 soney replacement lamp
How hard is to replace this lamp and were is it located in the tv, Im pretty mechanicly inclined but dont want to screw anything up in the tv
3 Suggested Answers
  • 1619 Answers
SOURCE: have a KDF 60Wf 655 will not turn on.
Wether it looks blown or not replace it and dont put oil from your fingers on the bulb. Also clean the cooling fans for the bulb and projector (which may mean taking the back off and taking apart projector). Dirt in the projector fans can cause a fault not allowing for the unit to turn on. All the cooling work ins conjunction with a good bulb.
Posted on Apr 24, 2010
SD Tech
  • 14553 Answers
SOURCE: I have a soney kdf-50e2000. The lamp went out a
Sony should have told you this is a common problem. If you remove the door and hold it edgewise look to see if it is warped even a little.
You will notice a small plastic peg on the back of the door, if you look closely you will see a small opening with a lever(usually blue in color) and this is a safety switch which prevents the set from being operated with the door removed.
What happens is the door gets warped just enough so the peg does not engage the lever switch.
If you want to confirm this, what I do is use a Q tip or something NOT METAL and wedge it in so the lever is ENGAGED.
If set now comes on with lever engaged, you need replace only the door, some advice here?
Do not operate the set for prolonged time with the door off and the lever engaged, and do not LOOK at the light from the lamp which can damage your eyes, Do not with door off replace front grill as the heat from the lamp can then warp it.
Ebay sells OEM replacement doors for about 20 dollars including shipping, MY MONEY IS THE DOOR IS WARPED, it does not take much for it not to engage the lever.
Please if have any questions or engage of the lever brings the set back online let me know, I am here to help.
REGARDS, SD TECH
Posted on Dec 04, 2010
e-Guru
  • 3917 Answers
SOURCE: I replaced my optical block on my Sony
Hi
Please check this link to get an idea about replacing optical block and see if all the settings inside have been done properly or not:-
http://www.ehow.com/how_7694194_replace-optical-block-sony-wega.html
However the blue CRT is most likely shorted and if the TV is more than a few years old, replacing all three tubes may be necessary.
If your Projection TV is rolling vertically or horizontally when you watch either cable or over the air broadcasts, try the following:
Make sure that all your cables are connected correctly and securely. For example, if you have mistakenly connected a Component output from a set top box to a standard video or AV input on your TV, the resulting picture will be distorted.
If you are watching over the air broadcasts, make sure your antenna is aimed so that you are receiving the strongest signal.
If you are watching standard cable, make sure that the cable is connected firmly at the wall jack and the back of the TV.
If you have a set top box that lets you adjust the output resolution (to 480p, 480i, 720p, or 1080i), make sure that the resolution you have chosen is compatible with the input jack to which you've attached the set top box.
Please get back to us if you have further query or else please accept the solution.
Posted on Sep 01, 2011
Have a KDF 60Wf 655 will not turn on. Green light comes on then red light with 7 blinks any suggestions? Took bulb out but the bulb light never lit and the bulb doesn't look blown.
Apr 24, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony wega power problems
Replace lamp in TV as this is clear symptom of weak lamp and TV needsnew lamp, did you replaced lamp in 4 years? Lamp replacement procedureis written in user manual of TV, pretty easy job, make sure to buy Sonyoriginal lamp and avoid aftermarket/ cheaper/ alternative lamps for TVsafety.
Click Sony Support to download user manual copy (KDF-42WE655)if required.
Thanks.
Oct 17, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have a KDF-E50A10 soyn tv and need to replace the lamp. can you yell me how and if it is located in fornt or back
Lamp compartment at right side of TV, there is plastic cover that can be removed by pressing its lock at top and you can see Lamp there.
Lamp replacement procedure is written in user manual page-87 in details.
Click Sony Support if you need to download user manual copy of KDF-E50A10
Thanks.
Oct 05, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Changing lamp
Lamp replacement is not difficult in Sony KDF-E60A20 TV and procedure is written in user manual.
Unscrew two thumb screws at lower corner at back of TV and take off lower front panel, in approx center of lower front of TV, lamp cover is located, unscrew it, remove it and lamp is there, unscrew lamp with hex key (supplied in new lamp box) and take out old lamp, put new lamp and put things back in reverse order.
Click Sony Support if you want to download user manual copy of TV.
Thanks.
Sep 30, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
How do i install a replacement xl 2400 lamp within a housing unit into my sony wega kdf46e2000 tv??????
how do I REPLACE THE LAMP IN THE kdf-42WE-655 WEGA TV. i PURCHASED THE REPLACEMENT LAMP, PART NO. XL-2100U>
Sep 16, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
How to replace bulb on sony kdf-55000
there are 2 hand screws on the back of tv, both sides, loosen them, them remove the lower front plastic cover, it is tight, you will need to pull on it hard after you loosen the screws, when you remove the front cover you will see the lamp access door, one hand screw removes it. 2 allen screws remove the lamp, if you buy a sony lamp, it will come with the allen wrench. if the glass is busted on your lamp it is definately bad, if it's not busted, you might have another problem.
Sep 14, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
I heard a pop and screen wet black. red lamp
Lamp inside TV is broken and requires replacement. Pop sound was its breaking sound.
Lamp replacement procedure is written in user manual, pretty easy.
Please buy Sony original lamp for TV safety and avoid aftermarket/ cheap lamp.
Let me know if you need to download user manual copy.
Thanks.
Sep 12, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Sonykdf 60wf 655 has blue colormostly on the screen
is it on every input? If so, you need a repair.
Jun 15, 2009 | Sony KV-36FS12 36" TV
How to replace lamp for sony kdf55xs955
Click Sony Support and download instruction manual to know how to replace lamp in Sony KDF-55XS955 TV. It is very easy to replace lamp and procedure is written in manual along with where is lamp located.
Apr 02, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Lamp keeps burning out. I have had the tv 2 years. The original lamp burned out in 1 year. I have since replaced the lamp at least 3 more times in the following year. Help!
Hi.
Im not at all familiar with your sony model but I do know that when A lamp is replaced you must reset the lamp timer if it is not reset it will cause premature lamp failure.
This is normally in the engineers menu as I said I dont know your model its not one I recognise so im sorry but I cant tell you how to enter service mode.
Hopefully one of the techs on here will know how and help you.
http://dysonmanuals.inc.io/
Chris.
Nov 17, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
Televison & Video Logo
121 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
